Stepping through an array on key press
Page 1 of 1 [5 Posts]
yoshima
PostPosted: Mon Apr 26, 2010 3:08 pm    Post subject: Stepping through an array on key press
Subject description: How do I make it loop?
Hello,
I'm trying to get ChucK to step through an array each time a key is pressed on the keyboard. It works but it only goes through the array once....
How can I get it to keep looping through?
Thank for any help....
Heres my code so far.....
Code:
// HID
Hid hi;
HidMsg msg;
// which keyboard
0 => int device;
// get from command line
if( me.args() ) me.arg(0) => Std.atoi => device;
// open keyboard (get device number from command line)
if( !hi.openKeyboard( device ) ) me.exit();
<<< "keyboard '" + hi.name() + "' ready", "" >>>;
// Patch
FMVoices v => JCRev r => dac;
0 => v.gain;
[ 0, 0, 3, 5, 5, 6, 9, 3, 4, 2, 1, 5, 7 ] @=> int song [];
int i;
// infinite event loop
while( true )
    // wait for event
    hi => now;
    // get message
    while( hi.recv( msg ) )
    if (msg.isButtonDown())
        Std.mtof(60+song[i++]) => float freq;
        freq => v.freq;
        <<<song>>>;
        1 => v.noteOn;
        0.5 => v.gain;
        0.2::second => now;
    else
        0 => v.noteOff;
vrachnasormora
PostPosted: Mon Apr 26, 2010 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, try changing this line:
Code:
to:
Code:
Std.mtof(60+song[++i%song.size()]) => float freq;
yoshima
PostPosted: Mon Apr 26, 2010 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
It works!! Thanks for the help...
But I have to remove the line:
Code:
<<<song>>>;
What code do I need for it to print the number in the array?
Thanks,
vrachnasormora
PostPosted: Mon Apr 26, 2010 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could again use:
Code:
<<< song[i%song.size()] >>>;
but because the modulo operation is quite expensive CPU-wise to re-express as you have already compute it, I would suggest:
Code:
                Std.mtof(60+song[i]) => float freq;
                freq => v.freq;
                <<<song[i]>>>;
                ++i%song.size() => i;
                1 => v.noteOn;
                0.5 => v.gain;
                0.2::second => now;
plus now you don't lose the first element of the array at the start of the program.Bye
yoshima
PostPosted: Mon Apr 26, 2010 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow... thanks...
you have been really helpful...
cheers... Very Happy
