blank preset fuctory patches
Page 1 of 1 [10 Posts]
petery
PostPosted: Thu Jul 10, 2008 1:51 pm    Post subject:  blank preset fuctory patches
Subject description: blank preset fuctory patches
H everyone,
I've got used A6 which works great... But only recently I had time to go through factory preset patches (the ones you can not change)... Some of them are blank... Means that I can initialize the patch (and of cause can not save it since it's factory one) but there is no sound until I initialize it... No nobs responce too... There are lots of them in the first factory bank and some in the second one... Is there something wrong with my A6? Do I have to reload them since I've reloaded the OS once?
Thanks,
Peter
Audio files: 28
G2 patch files: 299
PostPosted: Thu Jul 10, 2008 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
You mean you are afraid you fucked the factory presets Question
petery
PostPosted: Thu Jul 10, 2008 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
No they just blank? You press any key or turn any nob and press any key there is no sound coming out... If you initialize the blank patch it's makes noise and becomes normal but of cause you can not save it... you go to diffrent patch and back - same story, it becomes blank while patch next to it is OK... only some factory patches do that and mostly in the first bank... I know I've reloaded OS once so I was woundering if that has something to do with it...
Thanks,
Peter
petery
PostPosted: Thu Jul 10, 2008 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's like you need an external imput for those...
soundwave106
PostPosted: Thu Jul 10, 2008 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the default user banks do come with some external filter processing patches. Can't remember offhand.
petery
PostPosted: Fri Jul 11, 2008 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Well how many? Is it like most of the first bank or something?
soundwave106
PostPosted: Fri Jul 11, 2008 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Only a few at the end, like in the 120 range of one of the banks.
It actually sounds like you have a screwed up factory bank to me, either that or someone rewrote their preset bank with a whole lot of external input stuff. While you can't change individual presets you can replace an entire *bank* via Sysex if I remember right.
Mark-io
PostPosted: Fri Jul 11, 2008 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
check your voice status in the Global page. the patches that do not sound may be mono patches tied to Voice 1 and this voice may have been disabled by the Tuning procedure
author of the Andromeda Banker and Mix Maker utilities.
petery
PostPosted: Tue Jul 29, 2008 11:18 am    Post subject: i Reply with quote  Mark this post and the followings unread
Is there any way to overwrite preset programs? Like using MIDI dump or something?
Mark-io
PostPosted: Tue Jul 29, 2008 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
you can overwrite the preset banks, not individual presets. BUT you can only do it "internally"; first upload the bank to the User Bank, then it can be flashed to one of the Preset banks. it is mentioned somewhere in the manual
