<on air> Asheville electro-music festival live stream
16 Step Sequencer Problem
Page 1 of 1 [2 Posts]
ultramar1976
PostPosted: Sun Aug 17, 2014 6:30 pm    Post subject:  16 Step Sequencer Problem
Subject description: Dont Work!
Hi Everybody! Smile
Say "end" is the 16-step sequencer.
I put a switch were to occur it becomes 8 steps, that is, to use the first 8.
"Innocently" put the leg 13 of the first 4017 to land ground had to 8.
But ... actually having any armed, I see up to 8 does not count if it has up to 9.
That is, the LED 8 is off, there is a "step ghost" and then back to 1.
I noticed that for this purpose, I had to connect the leg 9 of the first leg 15 to 4017, but in doing so, the "ghost step" but will account 2-8 (not ignite LED 1)
Les image below as I have armed
I reiterate: HELP !!!!!!!!!!!!!!
Thank you
 Filesize:  49.2 KB
 Viewed:  83 Time(s)
yoho
PostPosted: Sat Aug 22, 2015 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
For those who still remember this topic: the switch is shorting out pin 9 Q8.
And I think it is better to use the reset pin for only 8 steps, ie using the nineth step as a signal.
