tiptaptempo
Joined: Jul 15, 2012 Posts: 53 Location: Nantes, France
G2 patch files: 16
Posted: Sun Sep 02, 2012 2:17 am Post subject:
Sequencers/mux/8 counter story Subject description: suggestions |
Hi Everyone,
Here is my first perf, some guys help me a lot to do that,
It's all about sequencers notes. I'm tweaking drums into g2.
There is 16 sequencers in the slot A, at the end of these i would like to go directly in the slot b, then c, and d. How can in do this ?
I read about the NoteSend or ControlSend module and
NoteRcv or Control Rcv . Maybe that "midi" solution optimize the slots and eat less ressource ? Would be great ...
I think there is an easier way to do this, i need some suggestions of fellow patchers here.
Oh, and the G2, my first synth, is A COMPLETE F...... MACHINE, it's HUUUGE !!!!!!!!!!!
 Download |
| Filename: |
TURRICAN l1.2.prf2 |
10.09 KB |
| Downloaded: |
143 Time(s) |
Roland Kuit
Joined: Sep 29, 2003 Posts: 991 Location: The Hague, The Netherlands
G2 patch files: 124
Posted: Sun Sep 02, 2012 3:16 am Post subject:
No time now for your .perf.
But congrats you got your G2 working again  _________________ Roland Kuit
http://rolandkuit.com/ |
Joined: Apr 03, 2004 Posts: 19583 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sun Sep 02, 2012 3:33 pm Post subject:
Re: Sequencers/mux/8 counter story Subject description: suggestions |
| tiptaptempo wrote: | There is 16 sequencers in the slot A, at the end of these i would like to go directly in the slot b, then c, and d. How can in do this ?
I think there is an easier way to do this, i need some suggestions of fellow patchers here. |
Another way to do it is by using audio busses (on the in/out modules) ... but you only have four of those, the MIDI option would be more efficient and you can have more signals to go from one slot to another then as well. _________________ Jan |
Roland Kuit
G2 patch files: 124
Posted: Sun Sep 02, 2012 11:25 pm Post subject:
Bluehell is right here. Go for the midi option. Midi note/control outs in your sequencer patch. Midi note/control receive in the listening slots. You can use as many as your dsp-load allows. For some example go here:
http://electro-music.com/forum/forum-79.html
These are controllers for other instruments, but instead those you can use your listening slots. _________________ Roland Kuit
tiptaptempo
G2 patch files: 16
Audio files: 116
G2 patch files: 317
Posted: Mon Sep 03, 2012 1:52 pm Post subject:
Re: Bus Audio Subject description: Note sequencers are detuned by using bus audio |
| tiptaptempo wrote: | | My question is : Is there a way to use audio bus by not detunig notes ? |
What do you mean by detune? I see no reason for it being detuned. _________________ Jan |
tiptaptempo
G2 patch files: 16
Posted: Tue Sep 04, 2012 9:03 am Post subject:
Hi BLue Hell,
I solve the problem, i have rerouted all my signals, now the notes are not detuned.
BTW Do you know how can i chain two multiplexers ? |
Roland Kuit
G2 patch files: 124
Posted: Wed Sep 05, 2012 1:13 am Post subject:
Do you want to add them or one after the other and why this last one? You can use a clocked step sequencer or if you want to scroll in those 16 steps, you can use a Control Sequencer. _________________ Roland Kuit
tiptaptempo
G2 patch files: 16
Posted: Thu Sep 06, 2012 12:08 pm Post subject:
Hej Roland,
Yes, i would like to play one after the other.
And i'm already using a ctrl sequencer. but there is only 8 steps for now i'm using.
Now i'm at the end of my 8 multiplexer input and 8 "8counter" output.
I don't really know how to "chain" this.
For example, after the end of my first multiplexer, i would like an other goes directly and so on. For now i've only 8 sequencers and i need at least 24 or more to play a whole song.
Anyone knows how i can chain these damn sequencers ?  |
Roland Kuit
G2 patch files: 124
Posted: Thu Sep 06, 2012 1:00 pm Post subject:
Something with switches or cross-faders  _________________ Roland Kuit
varice
Joined: Dec 29, 2004 Posts: 626 Location: Northeastern shore of Toledo Bend
G2 patch files: 46
Posted: Thu Sep 06, 2012 11:26 pm Post subject:
| tiptaptempo wrote: | ...Anyone knows how i can chain these damn sequencers ?  |
An example of chaining multiple sequencer modules is provided in the G2 Editor Help for the sequencer modules under the title “Sequencing examples; Serial Connection 1”.
You should also check out the G2 factory preset perf “RedMonday_DZ”, which has chained (serial) sequencers along with a Variation sequencer to expand the sequencing possibilities…  _________________ varice |
tiptaptempo
G2 patch files: 16
Posted: Mon Sep 10, 2012 2:29 am Post subject:
where is the trick |
| Roland Kuit wrote: | Something with switches or cross-faders  |
Do you mean that a switch module could "stop" the last (8)output of the 8 counter and then (or an other module for that) go to the next 8 counter ? |
Roland Kuit
G2 patch files: 124
Posted: Mon Sep 10, 2012 9:42 am Post subject:
Not stop multiplexer 1 but switch to the second, otherwise the output value of the first is added to the 2nd. But for more steps you can easily chain the sequencer module. _________________ Roland Kuit
tiptaptempo
G2 patch files: 16
