LED's
Page 1 of 1 [6 Posts]
flab
PostPosted: Fri Jun 22, 2012 7:10 am    Post subject: LED's Reply with quote  Mark this post and the followings unread
ones more i want you to answer on leds problems
-every led i use to my modules outputs are connected -output-10kΩ-ground way and are working fine.
-wright now i rebuild a 4040 and a 4051 putting a -output-10kΩ-ground led arrange but i get an output mess. I tried smaller and bigger res. than 10kΩ but again i can hear the led to the outputs. Crying or Very sad
any ideas?
cheers
JingleJoe
PostPosted: Fri Jun 22, 2012 8:34 am    Post subject: Re: LED's Reply with quote  Mark this post and the followings unread
flab wrote:
any ideas?
cheers
No, I am not sure what your problem is, what do you mean by "i can hear the led to the outputs"? That doesn't make sense Neutral
Audio files: 468
PostPosted: Fri Jun 22, 2012 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
do they light up at random, or not at all ?.
it could be that you have an unconnected input on the 4040/4051.
http://phobos.000space.com/ http://www.acidtrash.com/ Stickney Synthyards
Draal
PostPosted: Fri Jun 22, 2012 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll take a stab at it. For the 4051, I use just one resistor, a 10k because I use superbrite less, between pin 3 and pin 16. All the 4051's outs will work as expected.
Leds on the 4040 are on all the time once you hook a clock on them.
As far as hearing the leds, are you wiring up as diodes, as in diode mixing?
Zontar Prevails!
flab
PostPosted: Sat Jun 23, 2012 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
i bought some superbrite leds today morning-
actually was quite simple- are working just fine without having any sound when are connecting to ground through a 10kΩ.
superbrite made the trick but are really expensive.
thank you people
-minus-
PostPosted: Sat Jun 23, 2012 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
you can buy them cheap on ebay:
http://www.ebay.com/itm/Pack-of-100-5mm-Clear-Amber-LEDs-Super-Bright-LED-/190681729295?pt=LH_DefaultDomain_0&hash=item2c6584490f#ht_3205wt_1189
