Randomizing an array
Page 1 of 1 [13 Posts]
djdaphalgan
PostPosted: Fri Jul 20, 2007 12:09 am    Post subject: Randomizing an array Reply with quote  Mark this post and the followings unread
Is there an easy (fast) way to randomize an array? Suppose I have an array of ints [1,2,3,4]. I want that this algoritme radomizes the array (so the output can be for example [4,2,1,3]). I have made a little function that can swap to numvers in the array, and I run this function a few times in a for loop to randomize the array. This kind of works, but isn't there an easier way to do this? (In Java, there is a shuffle functions for Array objects build in to the language)
PostPosted: Fri Jul 20, 2007 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
No, sorry, you'll have to build one yourself. We don't have automatic array sorting yet either, that could come in handy as well.
kijjaz
PostPosted: Sat Jul 21, 2007 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. This is one think I'd like to practice also.
I guess I'll make a simple function for this kind of shuffling.
I consider it a homework heheh, here's my result.
Here's one way I'll do the shuffling:
Code:
fun void IntArrayShuffle(int array[])
   for(int i; i < array.cap() - 1; i++)
      // randomize the position to swap
      Std.rand2(i, array.cap() - 1) => int WhichToSwap;
      // swap
      array[i] => int dummy;
      array[WhichToSwap] => array[i];
      dummy => array[WhichToSwap];
[1, 2, 3, 4, 5, 6, 7, 8] @=> int array1[];
<<< "Original Array:", "" >>>;
for(int i; i < array1.cap(); i++) <<< "Array[", i,"] = ", array1[i] >>>;
IntArrayShuffle(array1);
<<< "Shuffled Array:", "" >>>;
The algorithm is really easy to understand:
for each member, swap randomly with any positions that's still not swapped.
hmm I guess this is quite a brute-force algorithm.
but very easy to understand.
PostPosted: Sat Jul 21, 2007 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
My take (I just wrote this, didn't try to run it).
What I'm doing is that I'm putting each value of the original array back in a random new spot. If the new spot is already taken I'll go to the next free one, looping round if nesicary. Not sure if this is more random then swapping locations in general BUT it's not a full 100% random, this wouldn't be sutiable for crypto, for example. I'm sure the "swap" way has issues too because that algorithem is always going to return the same array as the input was if the input was a array of length 2.
Code:
//keeps track of what locations we already wrote to;
int tracker[array.cap()];
//This is what we'll return
int result[array.cap()];
int temp;
      // randomize the place to write to
      Std.rand2(i, array.cap() - 1) =>  temp;
     //avoid writing to the same spot twice
     while (tracker[temp]) ++temp%array.cap();
      array[i] => result[temp];
     1 => tracker[temp];
 //write out again
 for(int i; i < array.cap() - 1; i++) result[i] => array[i];
The issue is that after the first value is placed to the new array, then next value is twice as likely to end up im the spot after is as it is to end up on any other spot (etc).
The alternative would be something like this;
Code:
Std.rand2(i, array.cap() - 1) => int temp;
     while (tracker[temp])  Std.rand2(i, array.cap() - 1) =>  temp;
     1 => tracker[temp];
 //write out again
However, that version will react spectacularly bad to very large arrays, it's going to take that poor algorithem quite a while to find the last empty spot in a array that's a million locations long and worse; there is no guarantee that it will ever finish.
A compromise might be using the top version two or three times? Maybe some people with "cs" in their email adress can help us, this is hard stuff.
PostPosted: Sat Jul 21, 2007 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
WHOOOPS! I take back what I said about the swapping method. I had overlooked that it allows for swapping a entry with itself so it shouldn't always return the same thing for arrays of length 2. Sorry about that.
kijjaz
PostPosted: Sat Jul 21, 2007 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh oh no problem. That is one thing we can improve more on that model..
hmm... but it's pretty fast for today's cpu ^_^"
PostPosted: Sat Jul 21, 2007 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, after thinking about it some more, I think your try is better then both of my own examples. In your example everything gets swapped once (possibly with itself but that's the same for everything) and on all other steps it has a equal chance of being swapped as well. Right now my gut says that should be utterly random so doing more passes shouldn't improve the randomness but it's a hard thing to think about.
However when you wrote; "for each member, swap randomly with any positions that's still not swapped.", that's not what avtually happens (you are swapping with any other member) which is a good thing, I don't think it's that "bruteforce" either. Of cource looping over a big array will take some time but we'll need to loop over it anyway, no way around that and four writes plus generating a random number seems entirely reasonable.
Definately a cool excersise!
kijjaz
PostPosted: Sat Jul 21, 2007 9:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm yeah I guess so.
That // comment doesn't go with the actual process -_-"
Hmm..
I still can't think of any more easy ways to jump around the array
with significantly less looping.
What I haven't done is some more complex / faster sorting.
I guess what I've been doing all the time is the bubble sort hahha
cute -_-"
PostPosted: Sat Jul 21, 2007 10:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nah, I think it's good like this. It definately can't get a lot smaller and everything else I can come up with is less random.
About sorting; Wikipedia has some nice articles about different sorting algorithems with visualisations. I have been thinking about those; if we look at those like small buffers they all morph from cyclical noise to a saw wave but different algorithems do so in a different way.
I was thinking it might be cool to implement those algorithems in some timed way and playback the buffer in the meantime, then compare their different sound as they morph from noise to a (imperfect) saw.
BTW; for smaller arrays I don't think the ineficiency of Bubblesort matters that much, if you'd like to -say- sort the last 10 MIDI notes and turn that into a sorted scale Bubble sort should be fine,
It'd still be cool to have eficient sorting (for int and float) and randomising (for all arays) of arrays in a real build-in labrary.
dewdrop_world
PostPosted: Mon Jul 23, 2007 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
The supercollider scramble algorithm is to loop through all elements except the last one and swap it with a value that occurs after it in the array.
In sc code (sorry for not writing in chuck but the algorithm is self-explanatory anyway):
Code:
~scrambler = { |array|
   var   out = array.copy;   // non-destructive
   if(array.size > 1) {
      for(0, array.size - 2, { |i|
         out.swap(i, i + rand(array.size - i))
   out
a = [1, 2, 3, 4, 5];
~scrambler.(a);
outputs: [ 4, 2, 5, 1, 3 ]
hjh
kijjaz
PostPosted: Mon Jul 23, 2007 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
eh seems like that's kinda the same as my proposed algorithm..
hmm interesting.
it looks easy to understand hmmm.
dewdrop_world
PostPosted: Mon Jul 23, 2007 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm interesting.
Oh, yes, you're right, I didn't read yours carefully enough.
hjh
kijjaz
PostPosted: Mon Jul 23, 2007 8:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
dewdrop_world, thanks for the algorithm from SC.
I'm dreaming up some more ideas now -_-"
