VCA for the 21st Century
Page 1 of 2 [43 Posts]
numbernone
PostPosted: Tue Oct 16, 2007 12:31 pm    Post subject:  VCA for the 21st Century Reply with quote  Mark this post and the followings unread
In hunting down a nice simple VCA I found that the example from the book had a nice low parts count, and could be laid out in a small footprint. However it was pointed out to me that it is a combo VCF/VCA.
From what I can see they are only sharing the SSM2164, with no real interdependence from each circuit. Am I on the right track?? I plan to breadboard it over the weekend, but if I am barking up the wrong tree I could much better spend the time on the 8038 VCOs.
Tim Servo
PostPosted: Wed Oct 17, 2007 7:38 pm    Post subject: Re: VCA for the 21st Century Reply with quote  Mark this post and the followings unread
Hey Number,
Yes you're right. You can easily wire up just the VCA (sheet 2 of the schematic / page 17 in AS21C). Only half of the 2164 is used in the VCA (so you could build a dual VCA without too much effort), and IC3 only uses sections b, c and d. Still, very easy to build only the VCA. On the unused op-amp section, I'd probably ground the + input, and connect the - input to the output.
Tim (no unused sections) Servo
numbernone
PostPosted: Thu Oct 18, 2007 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Tim,
I am aiming to make 4x VCA boards, I need lots and lots of them. And this is a very low parts count circuit, which I love. And Thomas' assertion in the intro that these are among his best circuits, is a very reassuring statement.
Matthew
philpeery
PostPosted: Fri Oct 19, 2007 9:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I breadboarded the 2164 as a dual VCA about a month ago or so. It worked very well, and sounded great even on the breadboard. It was rather trivial to "map" a second VCA to the other side of the chip. For the opamps, I used a tl074 and a tl072.
As I said, it worked great, so now all I need to do is layout a pcb. Yup, in my spare time!
Phil
PostPosted: Wed Jan 02, 2008 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
i am now starting to build a dual VCA from this schematic.
i wonder if there is any limitation to the amplitude of the input signal? i was not able to extract this information from the SSM2164 datasheet.
if not i would omit the input attenuation to spare some frontpanel space. in fact i only wanted 5 frontpanel elements for each VCA (input, initial, cv in, cv att., output).
fonitronik at
Tim Servo
PostPosted: Wed Jan 02, 2008 9:38 am    Post subject: VCA for the 21st Century Reply with quote  Mark this post and the followings unread
Hey Fonik,
It looks like the input resistors to the 2164 (30k in series, 510r and cap to ground) attenuate the input signal properly. I haven't looked at the 2164 data sheet, but is it possible that it's a current in rather than a voltage in (therefore the max input level will be listed in mA)? I'm assuming that it would still be possible to overdrive the 2164 with this setup, so you may want to include a PCB mounted trimmer to attenuate the signal if you find you're consistently getting distortion.
Tim (a little distorted) Servo
philpeery
PostPosted: Wed Jan 02, 2008 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi everyone,
I breadboarded this when the AS21C book was released. It's a great sounding VCA. I did not use attenuating pots on the audio input, and had no distortion issues when running a 10 volt peak to peak (+/- 5v) VCO square and triangle signal through it. These signals were not mixed, they were separate tests. I didn't get the chance to try to push it or run CV's though, which I wanted to do, before I needed my breadboard for another test however. But everyone should have at least one of these in their modular!
And I STILL have to get back to the PCB (single sided) design! There's never enough time in the day for all the modular stuff I want to do!
Fonik - if you come up with a press 'n' peel layout, will you share it? I do think you need Tim Servo's okee-dokee first as he's got the rights. As I said, everyone should build one of these! It's a great sounding VCA!
Happy New Year, E-M!
Phil
PostPosted: Thu Jan 03, 2008 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you boys. i am currently working on a single sided press'n'peel layout for a dual version (sharing the SSM2164).
i will leave off some components, though: the attenuated CV in and the AC/DC switch. that would be no big issue, i guess, since these parts are frontpanel mountable...
will be finished next week. i will have to ask thomas first and if he said yes i would create a building documentation. it won't come without any schematics, these are already available from magic smoke Wink
fonitronik at
Coriolis
PostPosted: Thu Jan 10, 2008 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik, that would be great!
And you're right about the cv-attenuators and the ac/dc switch - beter suited for panelmounting imo.
Looking forward to a layout!
C
PostPosted: Fri Jan 11, 2008 12:33 am    Post subject: Reply with quote  Mark this post and the followings unread
it's actually finished, even i had not the time to etch it yet. i will have to do some documentation next week and then i will post it...
fonitronik at
Luka
PostPosted: Sat Jan 12, 2008 8:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
great, i have a 2164 spare! and i'm in need of some more vcas!
problemchild
melbourne australia
PostPosted: Mon Jan 14, 2008 2:36 am    Post subject:
Subject description: PCB layout for a dual VCA
so here we go. i triple checked my work as usual but i have not had the time to etch a board and test it.
anyway you will find the layout here:
TH_dual_VCA.pdf
fonitronik at
creatorlars
PostPosted: Thu Jan 31, 2008 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I may build this with your layout -- any results yet? It's either this or the VCA-1. Know anywhere to get those SSM2164s? I know I can order them directly from ADI, but just wondering if there was a better price elsewhere...
PostPosted: Thu Jan 31, 2008 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
the PCB is etched and drilled. have not had the time to populate it though.
i ordered the ICs from bridechamber
fonitronik at
Tim Servo
PostPosted: Thu Jan 31, 2008 2:26 pm    Post subject: VCA for the 21st Century Reply with quote  Mark this post and the followings unread
Magic Smoke also carries the 2164 Quad VCA chip for $3.50 (or less if you buy more than two).
Thomas' AS21C book is also available through our print-on-demand service at
http://www.lulu.com/content/1065518
Tim (now if I could just print the chips) Servo
philpeery
PostPosted: Mon Feb 11, 2008 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I just finished etching Fonik's design for this board, and will be loading it with parts in the next few days. I'll report back, hopefully with pic's, on my build. Also, I had to hack in, using photoshop, an MTA156 connector for the power, which is what I use. Turns out it wasn't as tough as I thought it was going to be.
As I always say, the more VCA's you have, the better!
Phil
frijitz
Audio files: 54
PostPosted: Mon Feb 11, 2008 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Does this have linear or expo control?
Ian
Tim Servo
PostPosted: Mon Feb 11, 2008 12:28 pm    Post subject: VCA for the 21st Century Reply with quote  Mark this post and the followings unread
Linear. The VCA uses the four sections of a 2164 Quad VCA chip (each section with expo control) to create two linear response VCAs. The 2164 chip is very quiet and has a VERY wide dynamic range.
Tim (not very quiet) Servo
frijitz
Audio files: 54
PostPosted: Mon Feb 11, 2008 2:35 pm    Post subject: Re: VCA for the 21st Century Reply with quote  Mark this post and the followings unread
OK, so it's the old Mike Irwin trick?
I always thought it would be fun to try antilogging the input CV to get a linear response, rather than dedicating a VCA stage to be a servo.
Ian
Audio files: 21
PostPosted: Fri Feb 15, 2008 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ian, I have used the basic Mike Irwin circuit for my VCA design and it works very nicely. When I saw the TH VCA circuit, I knew exactly where it came from. Not that it was a bad thing, the Irwin circuit is very clever. I just changed a few things in my front end for my circuit. I really like this chip because it runs very quiet, as has been mentioned, and it has fantastic dynamic range. The CV response time is very good also.
Boy, I thought the same thing myself Ian. A cool approach. Wink This way I could get 4 linear VCA sections from one IC. Or use one SSM2164 for two LIN/LOG VCA's and one VC "Stereo Panner" using the other two sections. Very Happy
Bill
Sound
PostPosted: Tue Mar 18, 2008 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
locking at the schematics, I have a question.
For what is used a negative voltage initial?
PostPosted: Tue Mar 18, 2008 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
i'd thought you may want to compensate an offset of another cv source.
fonitronik at
Sound
PostPosted: Tue Mar 18, 2008 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks fonik... but the most useful is the positive voltage, so positive to ground? is it?
When we will use the negative initial? Any example?
Coriolis
PostPosted: Tue Mar 18, 2008 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik: did you have success with this layout?
C
Scott Stites
Audio files: 94
PostPosted: Tue Mar 18, 2008 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
One reason would be that if your control voltage, say an ADSR EG, for whatever reason, has a positive offset on it, the only way you could close the VCA while the CV is connected would be to mix a bit of negative voltage with it.
Cheerio,
Scott
My Site
