Happy New Year!
Thanks for a great live streaming floating concert and party.
OS Update
Page 16 of 19 [453 Posts]
Goto page: Previous 1, 2, 3, ..., 14, 15, 16, 17, 18, 19 Next
G2 patch files: 301
PostPosted: Tue Jun 10, 2008 9:31 am    Post subject: Re: clavias site is down Reply with quote  Mark this post and the followings unread
buzzr wrote:
Today i went to clavias site. Both the main page and the downloads for G2 software parts are down. I wonder if today is the day????????? Laughing
Server error Shocked
Audio files: 87
PostPosted: Tue Jun 10, 2008 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Server error - I know the feeling... Sad
G2 patch files: 301
PostPosted: Tue Jun 10, 2008 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
We're all doomed ... Laughing
Anyway, Clavia is up again as well, still no new G2 software Crying or Very sad
Parkol
PostPosted: Tue Jun 10, 2008 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tell me please.
Does anyone try Nord with Logic 8 on Itel Mac?
I am ready to test but still got no answer...
http://www.parkol.nm.ru
http://www.myspace.com/parkolmusic
seraph
Editor
Editor
Audio files: 15
PostPosted: Tue Jun 10, 2008 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Parkol wrote:
Tell me please.
the G2 editor works just fine on a MacIntel running Leopard. For Logic 8 the G2 is only another hardware synth connected via MIDI so, no problems Exclamation
homepage - forum - myspace - virb - berkleemusic
I am so clever that sometimes I don't understand a single word of what I am saying. - Oscar Wilde
Parkol
PostPosted: Tue Jun 10, 2008 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
So do I need to wait for a MacIntel Editor or I can just connect Nord to USB and play it in Logic?
G2 patch files: 301
PostPosted: Tue Jun 10, 2008 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
The USB connection is for the editor only, Logic can not use the USB port to do anything with the G2.
nuriel77
PostPosted: Tue Jun 10, 2008 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Use your Midi In and Out connections on the G2 in order to communicate with logic, either as midi contoller or as external instrument (u can record it into logic if you open an audio track, make sure all your midi settings and audio settings are set properly in logic).
(read logic manual about connecting external instruments)
the editor can work along side logic, no problem. With the editor you control the G2.
I normally use my laptop to run the editor (connected by usb thus) and use my logic on a desktop computer (midi connections)
good luck
Parkol
PostPosted: Tue Jun 10, 2008 11:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, thank you very very much for your help.
Almost 8 years I used Steinberg Cubase till... one week ago I decided to try Logic 8.
It's absolutely different and looks strange. I am confused a little.
But… Logic effected me! Sounds better than Cubase as I noticed.
Interface is quite friendly and I really liked it!
I decided not to use VST instruments so often as I did before, because I have Nord G2.
I hope I connect Nord properly and etc…
Thank You.
I am interested how many people work in Logic and Cubase here…
On Windows XP I had to turn on Editor to make 4 channels work.
Hope I won’t have problems with Logic.
nuriel77
PostPosted: Wed Jun 11, 2008 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank You.
Yes, I also was using Cubase until I discovered Logic... It is confusing in the first week, but once you get to know it, the work flow seems much easier than cubase, and generally a much more professional software.
There is nothing much about connecting the G2, it is same like any other synth or audio hardware connected to your computer.
USB connection to the computer running the editor of the G2, and midi connections the computer running logic/cubase/whatever... It can be the same computer, there is no need to use two computers.
In Logic you can add a new external instrument track, where you can write/record/edit the midi notes for the G2 and the automatization.
Note that in order to assign midi CC's you must assign the respective buttons/knobs on the editor/G2 (you do this yourself, comparing to most synths where the controlls are all pre-assigned). This give the G2 one of its unique powers!
To record the G2 simply add a new audio track, make sure you have Record enabled and that your inputs on this audio track are set to the inputs of your audio interface, where the G2 is connected to.
To sequence the G2 make sure in Logic Settings to send midi clock and time to the G2's midi channel. And make sure in the G2's settings that it is not ignoring external clock and check the rest of the midi settings.
I dont know how many G2 users are using Cuabse or Logic. There are not the only softwares out there, and they are probably more specific.
I use Logic to record the patches I make on the G2 and add some plug ins or some samples here and there.
I find the G2 does most of the work I need, I do all my drums and sounds from the G2, and not using any software plug ins.
To my opinion the G2 sounds great, and it is all a question of right mixing and dynamics. You can get any sound you want out of the G2.
Good luck!
Static Motion
PostPosted: Sat Jun 28, 2008 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I use Logic with the G2 inserted on external...
Works perfect here Smile
dioioib
PostPosted: Fri Jul 11, 2008 9:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I also use the G2 with Logic 8 on an intel mac running leopard, as well I am using a CME VX5 as my midi interface. It all runs quite well.
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
kcinsu
G2 patch files: 6
PostPosted: Sun Jul 13, 2008 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
my setup is basically Logic 8 and 2 nord G2s (one KB, one Engine)
and a few controllers.
love it.
Argosound
PostPosted: Mon Jul 14, 2008 2:46 am    Post subject: logic vs. cubase? Reply with quote  Mark this post and the followings unread
one question to nuriel77(and the others who might be thinking that way):
waht makes logic an overall more professional program for you?
i'm using cubase 4 studio(& g2 engine) and I'm not really missing anything,yet.
what do you prefer using logic?
sorry for being too much ot...
gardening, not architecture...
gomidas
G2 patch files: 6
PostPosted: Mon Jul 14, 2008 2:57 am    Post subject: Reply with quote  Mark this post and the followings unread
seraph wrote:
the G2 editor works just fine on a MacIntel running Leopard.Very Happy
Eating 50% of your CPU Laughing
CLAVIAAAAAAAAAAAAAAA!!!!!!ARE YOU THERE?????????
Development news On January 24, 2008, members of the development team at Clavia began the process on updating the editor and the drivers for the Nord G2 Modular. The team are working simultaneously on a Vista driver and an Intel compatible Mac version of the editor. We cannot estimate on a release date yet, this will be announced later. The Vista driver and the Intel-compatible editor will be available as a free download on this website when they are completed.
THAT WAS TO CALM US!!! Laughing
BobTheDog
Audio files: 10
PostPosted: Mon Jul 14, 2008 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
gomidas wrote:
seraph wrote:
the G2 editor works just fine on a MacIntel running Leopard.:D
Eating 50% of your CPU :lol:
THAT WAS TO CALM US!!! :lol:
The MacIntel editor is in beta at the moment, send a nice email (WITHOUT THE SHOUTING) to Clavia and they may let you in as a tester.
gomidas
G2 patch files: 6
PostPosted: Mon Jul 14, 2008 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the 1.41 beta 272 since 5 month, this BETA IS A JOKE, the development has stoped since this FIRST & ONLY(maybe the last?) release.
I guess the people at Clavia are busy with their OTHER great products....
cebec
G2 patch files: 31
PostPosted: Mon Jul 14, 2008 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I'm a little concerned that this will be a repeat of the NM Classic situation where they leave us with a working beta that only adds operating system compatibility. Pair that with the comment from Clavia that a final release is imminent, it doesn't give me much hope that they addressed any bugs or added any new functionality or they would have released a new beta some time ago.
BobTheDog
Audio files: 10
PostPosted: Mon Jul 14, 2008 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I would say there is little or no chance of bug fixes or added functionality.
The beta editor works very well for me.
seraph
Editor
Editor
Audio files: 15
PostPosted: Mon Jul 14, 2008 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
thay's what I was trying to say Wink
gomidas
G2 patch files: 6
PostPosted: Mon Jul 14, 2008 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
The beta 1.41b272 is FAR from perfect, I've report some BUGS to Clavia few months ago.............., but if that's it......
SO WE CAN CLOSE THIS Evil or Very Mad FORUM THREAD Laughing
BobTheDog
Audio files: 10
PostPosted: Mon Jul 14, 2008 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
What problems do you have then?
gomidas
G2 patch files: 6
PostPosted: Mon Jul 14, 2008 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
When you try to save a patch during playback, it can result in a corrupted patch.
http://electro-music.com/forum/viewtopic.php?highlight=b272&t=24822
Posted: Thu Mar 13, 2008 2:59 pm Wink
BobTheDog
Audio files: 10
PostPosted: Mon Jul 14, 2008 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Never had that one myself, are you on PC or MAC?
gomidas
G2 patch files: 6
PostPosted: Mon Jul 14, 2008 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mac intel
Buy N Save
