klo
Posted: Tue Jul 01, 2008 11:45 am Post subject:
i 6...!
but the singel gate or trigger out.... was a very big feature..!! |
newdendrite
Posted: Tue Jul 01, 2008 7:27 pm Post subject:
Looks like a great project. I'm in for two boards.
Michael |
ryktnk
Posted: Wed Jul 02, 2008 8:15 am Post subject:
Hello
Klo
Quote: | but the singel gate or trigger out.... was a very big feature..!! |
Can you explain more clearly, I don't understand your request.
-ryktnk |
klo
Posted: Wed Jul 02, 2008 10:10 am Post subject:
Quote: | Can you explain more clearly |
for all 8 steps a singel gate out. 8 singel gate out 1-8 and one mix gate out. |
ryktnk
Posted: Sat Jul 05, 2008 2:32 am Post subject:
Hello
Quote: | for all 8 steps a singel gate out. 8 singel gate out 1-8 and one mix gate out. |
Thanks, I understand now.
But I think I will keep the design with just the single "mixed" gate output.
-ryktnk |
endif
ryktnk
slo
Joined: Feb 18, 2007 Posts: 204 Location: Victoria, BC
Posted: Mon Jul 07, 2008 5:36 pm Post subject:
I'd be in for one of these, looks great.
George |
bubblechamber
Posted: Mon Jul 07, 2008 9:04 pm Post subject:
it's looking really good. thanks for all the work you're putting into this. |
Funky40
G2 patch files: 5
Posted: Wed Jul 09, 2008 3:23 am Post subject:
bubblechamber wrote: | it's looking really good. thanks for all the work you're putting into this. |
yes, and thank you for keeping us updated. |
asafnetzer
Posted: Wed Jul 09, 2008 7:13 am Post subject:
Thanks for the update, looks great |
ericcoleridge
Posted: Wed Jul 09, 2008 10:19 am Post subject:
Wow! This is really compact, considering all the functionality. I already have a sequencer, but I wouldn't pass up this PCB if it's offered. Really great work. |
Level5
Posted: Thu Jul 10, 2008 7:08 am Post subject:
I'm in for 2 PCB's and PIC's |
funkyfarm
Posted: Thu Jul 10, 2008 9:41 am Post subject:
Ain't a 6-position slider switch "enough" for repeating mode ?
something like this : mouser 506-SLS260PC
3.84$
http://www.mouser.com/Search/Refine.aspx?Ntt=*506SLS260PC*&N=1323038&Ntx=mode%2bmatchall&Ns=P_SField&OriginalKeyword=506-SLS260PC&Ntk=Mouser_Wildcards |
ryktnk
Posted: Thu Jul 10, 2008 10:04 am Post subject:
Hello
something like this : mouser 506-SLS260PC |
Do you mean the counts per stage switches ?
This is currently working with 1-8 repeats, so you could use
this switch, but only getting 1-6 repeats.
The wiring on the SLS260PC switch would be a little fiddly as
it is not a straight 1pole 6way.
Probably using rotary switches is a good route as you can easily
find 1pole 8way.
The mode per stage switches needs to be 1pole 4way.
-ryk |
funkyfarm
Posted: Fri Jul 11, 2008 12:16 pm Post subject:
ryktnk wrote: | Hello
yes !
rotative switches will take more space on the frontpanel...
a complete second row as for cv potentiometers.
farnell has cool cheap little boxes with aluminium panel (210mmx125mm/8.25x4.92)...
In fact I wonder if a 1pole 4way would be enough, same as for the mode per stage switches. I guess number of counts per stage often vary between one, two and three, maybe four sometimes in a sequence.
"this is how I usually see a bassline..."
can it be a real drawback ?
maybe higher counts per stage numbers are useful for longer note ? or "pause" in a pattern ? |
ryktnk
Posted: Fri Jul 11, 2008 2:47 pm Post subject:
Hello
Quote: | In fact I wonder if a 1pole 4way would be enough, same as for the mode per stage switches. I guess number of counts per stage often vary between one, two and three, maybe four sometimes in a sequence. |
It kind of depends at what beat-division your clock is running at.
If you're driving the seq. from 16ths [all the leds on a 606] then you
will definitely need 1-8 repeats.
I've set a jumper on the board, so you can divide-by-2 the clock pulses
which might help.
I guess count some clock pulses of your intended music, and
see if it's going to fit.
Hope that helps.
-ryk |
funkyfarm
Posted: Fri Jul 11, 2008 2:59 pm Post subject:
Thank you for pointing this.
i will find a bigger box and switch for rotative |
ryktnk
ringer
Posted: Mon Jul 28, 2008 3:14 pm Post subject:
Hi Ryktnk,
MUCHOS GRACIAS for the cv stage selection and the subdivision.
I am upping my order to 6 pcb's with switches please. Paypal is waiting for the go-ahead, thanks.
Regards,
Ringer |
bubblechamber
Posted: Mon Jul 28, 2008 5:14 pm Post subject:
Hi Ryktnk, that's great. I'm really looking forward to this. i've got the feeling i'm going to regret only getting 2 of these. thanks for all the work you're put into this project.
david _________________ You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same. |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Mon Jul 28, 2008 5:20 pm Post subject:
I would be interested in one board PIC combo if still available.
Thanks,
Dan |
Luka
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Mon Jul 28, 2008 10:44 pm Post subject:
I'd love to get 4 |
neandrewthal
Posted: Mon Jul 28, 2008 11:15 pm Post subject:
2 for me please _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
