whomper
Posted: Mon Jul 28, 2008 2:42 pm Post subject:
Dual Drum Envelope |
I have built the Dual Drum and found sound A to resemble a BD and as such I am looking to use it as such.
In order for it to sound more like a BD, I need to shorten the sound, naturally an EG comes to mind but I am looking to handle it on board.
Is there any way to shorten the sound? Perhaps change a resistor value? _________________ Erez Yaary
Home Page: http://www.yaary.com
Buy my CDs at http://www.mellowjet.de |
Cat-A-Tonic
Joined: Mar 24, 2008 Posts: 42 Location: Yokohama, Japan
Posted: Mon Jul 28, 2008 5:04 pm Post subject:
I think sound A is really more of a floor tom and sound B is a higher tom, but for lack of other options I try to make them sound like a bass and a snare.
I've tried processing the 'bass' with octave down, pitch shift down, and bass parametric EQ. I think the EQ was probably the most natural and effective of the 3, but now that I have more pedal power I may try it again with a combination of these.
The 'snare' is obtained by (klangwerk) ringmodulation with digital noise, and white noise as CV.
This one is really nice because you can use the switches on the Klang to jump between different drum sounds.
I don't know of any on board mods that'll yield what we're looking for.
Good to know I'm not the only one thinking along such lines, and suffering without a dedicated bass drum module. |
whomper
Posted: Tue Jul 29, 2008 1:32 pm Post subject:
Well, I have played some with the trimpot and found some setting that reduce the envelope to a satisfactory level while maintaining the bass elements.
Although not an envelop with a log response, it provides something comparable. _________________ Erez Yaary
fluxmonkey
Posted: Tue Jul 29, 2008 6:19 pm Post subject:
whomper wrote: | Although not an envelop with a log response, it provides something comparable. |
when you mention log response of a drum sound, i'm thinkin something like this:
heh _________________ www.fluxmonkey.com |
ericcoleridge
Posted: Tue Oct 14, 2008 10:07 am Post subject:
I found that the two circuits are related and changing the timing caps for one effects both. I was trying out different sized caps on drum2, and got an incredible bass-kick sound on drum 1, when using caps too small to work on drum2. I had 1000pf caps in drum 1, and something like 22pf caps in drum 2.
I decided not to sacrifice drum 2 however (it was making no sound with 22pf caps), and replaced the 'normal' 470pf caps. This also changed drum 1 back to more of a low tom sound. I think I liked the kick sound much better tho. |
Rykhaard
Posted: Tue Oct 14, 2008 3:21 pm Post subject:
Out of the 2 or 3 BD circuits that I've built (both or more were t-filter variations) the best BD sound that I've found so far, is from the SSM2044 4 pole LPF just below resonating, being triggered.
Leaving the Filter Cutoff fairly low for the oscillation frequency when the filter is triggered, you get a really nice deep boom.
At the same time, I send it a VERY fast Attack Decay envelope to 1 of it's CV inputs, to give it something more of a 'click' at the beginning of the trigger as well.
I have currently only 2 of that filter setup, so I haven't dedicated 1 of them to it. I DO have a 3rd chip though on a completed PCB and will be mounting it to a panel in MAIN consideration for a BD sound, though still usable as normally expected.
To hear it well - you also need speakers that are able to reproduce low frequencies well. My Yamaha NS10's can't really handle it. My higher end Sony headphones though, reproduce it beautifully. |
ericcoleridge
Posted: Thu Oct 16, 2008 9:24 am Post subject:
Sorry to continue this OT, but Ryk's comment reminded me of the amazing kick drum and tom-tom sounds produced by self-resonating MS20 dual VCFs. Best drum sounds I've ever made or heard, actually. These filters are very simple to reproduce as well. There's a great MS20 VCF clone in the general forum even. |
