 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Happy New Year!
Thanks for a great live streaming floating concert and party.
Nord Rack 2X Shift Functions
Page 1 of 1 [6 Posts]
Shane O'Donovan
PostPosted: Sat Aug 16, 2008 6:20 am    Post subject: Nord Rack 2X Shift Functions
Subject description: Secret shift fonctions
Just bought a new Rack 2x yesterday and when I was programing it I noticed that if you hold the shift button and then hit the filter type button it turns on all the filters, or something like that. Whatever it is it sounds pretty cool. I couldn't find a description of this in the manual so I became curious and started hitting all the buttons while holding shift. Funny things started happening that I don't quite understand. I can't find any info in the manual about these secret shift functions so maybe someone who knows more than I do could help me out here.
Also, you know the way notes get stuck and they won't stop playing. That keeps happening to my Rack 2X and it never happened to my Rack 2, what's up with that. Thanks for the help.
Wout Blommers
Audio files: 94
G2 patch files: 11
PostPosted: Sat Aug 16, 2008 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Shane O'Donovan
Some info about the secrets at http://nm-archives.electro-music.com/020_NordLead2/023_Miscellaneous/NordLeadSecrets.htm
About the stuck notes. Does the Rack receives more Midi data then just one?
Wout
Shane O'Donovan
PostPosted: Sat Aug 16, 2008 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply. Yeah, I'm sending midi to all four parts but that shouldn't be a problem. I'm pretty sure this was never a problem with my Rack2.
Wout Blommers
Audio files: 94
G2 patch files: 11
PostPosted: Sat Aug 16, 2008 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Try to set the Midi Global to a higher channel then the 'normal' Midi. Maybe this helps...
Wout
Shane O'Donovan
PostPosted: Sat Aug 16, 2008 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, cool, I'll give that a go. Thanks.
Wout Blommers
Audio files: 94
G2 patch files: 11
PostPosted: Sat Aug 16, 2008 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
If this doesn't help be sure only Slot A is active (blinking)
Wout
Once You Know, You Newegg
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
