 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Happy New Year!
Thanks for a great live streaming floating concert and party.
how do you analyse tracks except for spectrum analysis?
Post new topic   Reply to topic Moderators: paul e.
Page 1 of 1 [5 Posts]
younger
PostPosted: Sun Aug 24, 2008 3:38 am    Post subject: how do you analyse tracks except for spectrum analysis? Reply with quote  Mark this post and the followings unread
Hello, I wonder are there anything how you usually analyse your tracks as well as others?
I mean not just looking at spectrum and RMS, but maybe anything else concerning sound ?
Regards
Audio files: 32
G2 patch files: 301
PostPosted: Sun Aug 24, 2008 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome
I do look at the spectrum at times when I made something abstract in the wave editor to see if I can find why things are hurting my ears or why it's sounding muddy ... but it doesn't show too much to me ... actually I find it best to just try some filters and listen what happens.
What would you use RMS values for?
Audio files: 26
PostPosted: Mon Aug 25, 2008 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I use the Soundforge spectrum analysis sometimes, but mainly to find the valleys and troughs in a partial mix. Usually because I'm trying to make something else fit in. This is usually because I've overworked the track and actually need to take some stuff out! Laughing
Sometimes I want to find the "dominant frequency" of a noisy part that might need re-tuning.
I also use the "find" function to make sure the mix hasn't topped out. ie; find -> largest peak. Then if the largest peak has the top taken off, I've mixed it too hot, and I go back and do it again.
If you don't sing in a government choir,
and you forget why you got hired,
you can warm your hands on friendly fire.
- John Foxx
younger
PostPosted: Wed Aug 27, 2008 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for your answers !
Blue Hell, I analyse RMS because its amplitude reflects perceived loudness better than peak amplitude.
EdisonRex
Audio files: 17
PostPosted: Thu Aug 28, 2008 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
RMS with peak metering is pretty common but I don't find it useful for much more than track mixing. I've never really found RMS to be reliable because perceived loudness is biased; energy across the spectrum is perceived as much louder at low frequencies than high, and it is so with the physical output.
I use my ears a lot, to analyse a mix. It's a bit old fashioned but it seems to work for me.
And other than that, I will rarely use spectrum displays (pretty easy to whip up in Max/MSP, I have a patch I keep handy) to view particular phenomena.
Welcome, by the way.
Garret: It's so retro.
Home,Virb,My other place,My tech site,My web cam
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
