TL074BCN for Mankato....
Page 1 of 1 [4 Posts]
kas
PostPosted: Fri Sep 12, 2008 2:04 pm    Post subject: TL074BCN for Mankato.... Reply with quote  Mark this post and the followings unread
Hi everyone,
I've started building my Mankato filter form MagicSmoke and I bought the components from a local store here in Thessaloniki-Greece..The thing is that instead of the TL074BCN I received the TL074CN chip.I know that it's a stupid question but does anybody know if there is a difference that will be a problem for the filter, or I can use this chip?
Thank's Loukas
Audio files: 231
G2 patch files: 319
PostPosted: Fri Sep 12, 2008 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Kas,
nothing to worry about I'd say regarding the different 074 suffix letters.
Tim Servo
PostPosted: Fri Sep 12, 2008 5:22 pm    Post subject: TL074BCN for Mankato.... Reply with quote  Mark this post and the followings unread
Hi Loukas,
The short answer is "yes." Any flavor of TL074 will work in the Mankato. The difference between the various grades is the amount of "Offset Voltage." This is the voltage that appears at the output when the two inputs are equal. In an ideal op-amp, when the two inputs are the same the output voltage should be 0. However in the real world, there is usually some offset voltage that appears at an op-amp output. The "B" grade has the lowest offset voltage, and so I specified those for use in the Mankato to keep the performance of the four filter stages as closely matched as possible. Also, the different grades are very close in price so I thought it couldn't hurt to spec the "better" part. My guess is that you won't see any difference in performance with the "C" grade parts, or if you do, it would be very minor. By the way, the grades are C with a ~10mV offset, A with a ~6mV offset, and B with a ~3mV offset. The second digit in the grade has to do with the temperature range, I believe. The various data sheets available will spell all of that out.
Tim (funny that a B is better than an A) Servo
kas
PostPosted: Sat Sep 13, 2008 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Thnk's for the answers,
I think I will start with the CN and maybe later I will buy the B type ( it's easy to replace it ...)
