Nordleadagent
Posted: Sun Jan 25, 2009 12:14 pm Post subject:
Arpeggiator and percussion sounds in Nordlead 2x |
How can I produce percussion sounds in the Nordlead 2x? Can I use the arpeggiator for percussion sounds like in a workstation? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Jan 25, 2009 1:31 pm Post subject:
Re: Arpeggiator and percussion sounds in Nordlead 2x |
Nordleadagent wrote: | How can I produce percussion sounds in the Nordlead 2x? | You've been in Percussion mode already? These sounds can be changed. They don't have to be percussion sounding like, but any sound the NordLead can produce, like storm, rain and sea waves, used as an effect. Quote: | Can I use the arpeggiator for percussion sounds like in a workstation? | Yes, but with limitations. You have to program the Arpeggiator in Percussion mode first, for each sound you like to use with the Arpeggiator.
The first restriction is the Arpeggiator setting of the last playing note will be heard, so if you want to use all eight sounds, they have to have to same parameter settings (Is done by Shift+LFO1 Wave form).
The second restriction is the 'Amount' setting of the Arpeggiator, so it will function as a normal arpeggiator, which means it can sound the octave higher or two higher.... Am I clear?
BTW the Arpeggiator is rather dull as a rhythm provider, but you can silence a Percussion mode sound and use two Percussion files in a Performance using different Rates. I know, it's a puzzle, but some like to do this kind of things.
It is fun and I use it a lot.
Wout |
Nordleadagent
Posted: Sun Jan 25, 2009 1:35 pm Post subject:
Could you please post an example (mp3) of what you mean? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Wout Blommers
Audio files: 123
G2 patch files: 12
Wout Blommers
Audio files: 123
G2 patch files: 12
Wout Blommers
Audio files: 123
G2 patch files: 12
Wout Blommers
Audio files: 123
G2 patch files: 12
Wout Blommers
Audio files: 123
G2 patch files: 12
Nordleadagent
Posted: Sun Jan 25, 2009 4:20 pm Post subject:
Thanks a lot Wout,
that gives me a real nice impression of what can be done with the Nordlead 2X!
Number 4 was was very nice indeed! |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Jan 25, 2009 4:26 pm Post subject:
Nordleadagent wrote: | ... that gives me a real nice impression of what can be done with the Nordlead 2X! | You can do much more with it
To investigate the possibilities of the Arpeggiator in Percussion mode will keep you busy for a couple of weeks...
Using the keys is very unpredictable.
Fun for may hours during a German rainy afternoon
Wout
BTW things like example 4 can be done in a normal Program too! It's the Hold function which is important in this. |
Nordleadagent
Posted: Sun Jan 25, 2009 4:43 pm Post subject:
I hope so, this gives me great inspiration to buy this Synth! _________________ Andreas
Nord Lead3, CS6x, SonicCell,
Wavestation-SR,Tenori-On,
Rm1x, E-MU XL1
Hear my music: http://www.last.fm/music/Soundagentenori?setlang=en |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Jan 26, 2009 12:38 am Post subject:
Nordleadagent wrote: | ... this gives me great inspiration to buy this Synth! | Beware! Using the Arpeggiator this way is not easy! I advice you to use a sequencer to run the Percussion mode, although it is possible do do something in that combination... But is asks hard labor! On stage hardly useable... The NordLead isn't designed as a beat box
Wout |
Nordleadagent
Posted: Mon Jan 26, 2009 12:44 am Post subject:
I know that, and I think, I will use my Tenori-On as a stepsequenzer for that.
But is it possible to have one slot for the percussion sounds from an external sequenzer which does´nt sound when I touch the keyboard? _________________ Andreas
Rm1x, E-MU XL1
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Jan 26, 2009 2:56 am Post subject:
Of course!
Just don't activate the Percussion Slot (no LED) and it be controlled by Midi. Just take notice this Slot uses also voices! (set all sounds to Mono and no Unison)
Wout |
Nordleadagent
Posted: Mon Jan 26, 2009 3:32 am Post subject:
Thanks Wout! I am quite happy about that and have now ordered my Nord Lead2X.
I am very grateful for your help and advice. Surely I will come back with more questions in a few days, when I ´ve got my new NL. _________________ Andreas
Rm1x, E-MU XL1
