crazeydazey
Posted: Thu Mar 05, 2009 5:25 am Post subject:
Booting server Restarts my PC |
I'm complete noob to Super collider..
when I try and start it up I get...
Code: |
init_OSC
compiling class library..
NumPrimitives = 500
compiling dir: 'C:\Program Files\PsyCollider\SCClassLibrary'
pass 1 done
Extension overwriting Char:isPathSeparator
in file '\Platform\windows\extMain.sc'.
Original method in file '\Common\Core\Char.sc'.
Extension overwriting Meta_Score:initClass
in file '\Platform\windows\extScore.sc'.
Original method in file '\Common\Control\Score.sc'.
Extension overwriting Meta_Server:initClass
in file '\Platform\windows\extServer.sc'.
Original method in file '\Common\Control\Server.sc'.
Extension overwriting Server:quitInProcess
Extension overwriting String:newTextWindow
in file '\Platform\windows\extString.sc'.
Original method in file '\Common\GUI\PlusGUI\Collections\StringPlusGUI.sc'.
Extension overwriting String:openTextFile
Extension overwriting String:pathMatch
Original method in file '\Common\Collections\String.sc'.
Extension overwriting Meta_SynthDef:initClass
in file '\Platform\windows\extSynthDef.sc'.
Original method in file '\Common\Audio\SynthDef.sc'.
numentries = 826880 / 11087280 = 0.075
Method Table Size 6543960 bytes
Number of Method Selectors 4698
Number of Classes 2360
big table size 44349120
Number of Symbols 10950
Byte Code Size 348798
compiled 396 files in 5.61 seconds
compile done
Could not connect socket
// History.logFolder: C:\Documents and Settings\darrenp\SuperCollider
Class tree inited in 1.09 seconds
WARNING:
GeneralHID.fromID : The HID scheme 'nil' is not installed
The current scheme is still 'nil'!
StartUp done.
Welcome to SuperCollider, press F1 for help
booting java -Dswing.defaultlaf=com.sun.java.swing.plaf.windows.WindowsLookAndFeel -jar SwingOSC/build/SwingOSC.jar -t 57111 -L -i -h 127.0.0.1:57120
SwingOSC v0.59. receiving TCP at address 127.0.0.1:57111
SwingOSC : server connected.
if I then click the boot button, my PC restarts itself...
any ideas anyone??
Daz |
dewdrop_world
Joined: Aug 28, 2006 Posts: 858 Location: Guangzhou, China
Posted: Thu Mar 05, 2009 8:53 pm Post subject:
We need to do a little work to rule out possible sources of the crash.
What happens if you start scsynth from the command line? To check, first get the default options from supercollider itself (I could tell you the options on the Mac, but they might be slightly different in Windows so it's better to get them yourself):
Code: | s.options.asOptionsString(57110) |
Then open a command line and cd to the location where supercollider was installed. That's probably...
Code: | c:
cd \program files\supercollider |
Then start the next command with scsynth, and a space, and then copy and paste the options string from the SC post window. On my Mac, the command looks like this but again, it might be a little bit different on your system.
Code: | scsynth -u 57110 -b 1026 -R 0 |
At this point, if it works, the command prompt window will seem to hang. That's normal -- scsynth has no typing interface. Also the local host server window should start to show some statistics and switch to "running" status.
If this makes your machine reboot, then we know the problem is in the server process. If that's the case, I would suspect a disobedient audio driver.
If that doesn't reboot the machine, let's try a quick GUI interaction test (to see if the action of clicking the button is the culprit).
Code: | // run the bit inside () in supercollider
w = GUI.window.new("whoopsie", Rect(10, 100, 200, 60));
GUI.button.new(w, Rect(5, 5, 190, 50))
.states_([["Poke me"]])
.action_({ "got poked".postln });
w.front;
Then do what the button says
If both the commandline test and the GUI test are OK, then the problem gets really weird... but let's cross that bridge later.
James _________________ ddw online: http://www.dewdrop-world.net
sc3 online: http://supercollider.sourceforge.net |
crazeydazey
Posted: Fri Mar 06, 2009 1:52 am Post subject:
sorry for been a complete dimwit, but I have tried running the code
Quote: | s.options.asOptionsString(57110) | in super collider and I can't seem to figure out how to run it..
I have followed the tutorial in the helpfile, which says "put cursor on line of code and press enter, (NOT RETURN...)"
tried that with simple Hello world from tutorial.. nothing..
so gave in trying and just moved on to running it with command line, with your settings.. (naughty naughty)... it restarted my PC
I don't usually give in too easy, but I may call it a day soon with SC |
dewdrop_world
Posted: Fri Mar 06, 2009 6:30 am Post subject:
The main help page (Help.html) says:
"To execute code, use the keyboard shortcut: Enter (not Return) (OS X), Ctrl+Enter (Windows), Ctrl+c Ctrl+c (Emacs). For key commands, also see Shortcuts."
(Actually Ctrl+Return is OK too.)
Don't give up too quickly. I think we can be fairly confident scsynth is the one crashing. I still think it's probably an audio driver doing something naughty.
Are you using XP? Vista? Win7 beta? I think System Information should give you the exact OS version (either that or My Computer > Properties).
What audio devices exist in your system? Driver versions?
crazeydazey
Posted: Fri Mar 06, 2009 7:13 am Post subject:
aaah... (I told you I was dumb )
I've now run the first bit of code and got...
to be honest I can't really afford my machine to resart at this moment in time, so I skipped the next bit for now and tried running your other code, which worked..
I'm running win XP sp2, the sound card is built into my motherboard, in the device manager it says Realtek and the properties of this say it's working fine..
btw cheers for your help James.. I'm not gonna give in too easily now.. |
dewdrop_world
ook
Posted: Mon May 18, 2009 8:31 am Post subject:
I get the same error when I start PsyCollider but my PC does not restart when I start the server. Both the tests you stated above pass.
Code: |
// History.logFolder: C:\Documents and Settings\Jean-Marc Jones\SuperCollider
Class tree inited in 1.14 seconds
WARNING:
StartUp done.
When I try to run this code from the tutorials:
Code: |
w = SCWindow.new("Fading").front;
r = Routine({ 200.do({|i| w.alpha = 1 - (i * 0.005); 0.005.wait;}); w.close; });
AppClock.play(r);
I get this error:
Code: |
A primitive was not bound. 0 499
Instance of Method { (037C6530, gc=01, fmt=00, flg=11, set=04)
instance variables [15]
raw1 : Float 2.670109001368235e-307 0048000C 00000000
raw2 : Float 2.437076554554034e-289 04030004 00000400
code : instance of Int8Array (037C6670, size=4, set=1)
selectors : nil
constants : nil
prototypeFrame : instance of Array (037C6620, size=4, set=2)
context : nil
argNames : instance of SymbolArray (037C65E0, size=4, set=1)
varNames : nil
sourceCode : nil
ownerClass : class SCView (0380F450)
primitiveName : Symbol '_SCView_New'
filenameSymbol : Symbol 'C:\Program Files\PsyCollider\SCClassLibrary\Common\GUI\Base\SCView.sc'
charPos : Integer 6403
ERROR: Primitive 'none' failed.
Failed.
RECEIVER:
nil
CALL STACK:
MethodError:reportError 035EFDF0
arg this = <instance>
Nil:handleError 035EFD90
arg this = nil
arg error = <instance>
Thread:handleError 035EFCD0
Object:throw 035EFC70
Object:primitiveFailed 035EFE50
arg this = nil
SCView:init 035EFC10
arg argParent = nil
arg argBounds = <instance>
SCContainerView:init 035EFBB0
arg argParent = nil
SCWindow:initSCWindow 038E0810
arg argName = "Fading"
arg resizable = true
arg border = true
arg scroll = false
<closed> (no arguments or variables)
Interpreter:interpretPrintCmdLine 038DEC30
var res = nil
var func = <instance>
var code = "w = SCWindow.new("Fading").f..."
Process:interpretPrintCmdLine 035EF9D0
Any help I could get would be grate there seems to be little help for windows verssion on psy collider on the net. |
dewdrop_world
Posted: Mon May 18, 2009 1:53 pm Post subject:
You aren't seeing any errors on startup. A warning is not an error. -- So this really should be a separate thread (b/c it's a different question).
Don't use SCWindow - that's Mac only. I'll have to spank the tutorial author for not cross-platform-izing the docs
In 3.3*, use Window instead. But that example doesn't do much because the Java GUI server doesn't support transparency for whole windows. This'll give you a bit more impact.
Code: | w = Window.new("Fading").front;
r = Routine({
200.do({|i|
w.view.background = Color.blue(val: 1, alpha: 1 - (i * 0.005));
0.005.wait;
w.close;
AppClock.play(r); |
* Use SC 3.3a6. It's really a LOT better than Psycollider 3.2. A LOT.
ook
Posted: Tue May 19, 2009 4:13 am Post subject:
Thanks for the help sorry about highjacking the thread just started using Super Collider and it all a bit confusing. Would you say that its worth installing the extenssions from the main super collider site? |
flies
Posted: Thu Jun 25, 2009 2:42 pm Post subject:
Quote: | * Use SC 3.3a6. It's really a LOT better than Psycollider 3.2. A LOT. |
care to comment? I just installed 3.2 on my XP machine and am going through the tutorials. (fwiw i get the same warning.) 3.3a6 is supposedly 'unstable' according to the SC.sourceforge website. |
dewdrop_world
Posted: Thu Jun 25, 2009 8:13 pm Post subject:
"Unstable" in development-cycle terms does not mean "more prone to crash." It just means the code base isn't fully finalized for that version.
3.3a6 actually FIXES some crashing bugs that were there in 3.2.
hjh _________________ ddw online: http://www.dewdrop-world.net
