<on air> faux pas quartet and friends Music From Last Thursday
Andromeda patch parameter sheet
Page 1 of 1 [10 Posts]
scd
PostPosted: Thu Dec 04, 2008 3:01 am    Post subject: Andromeda patch parameter sheet Reply with quote  Mark this post and the followings unread
For my own use, I created a 4 pages patch parameter sheet which covers every possible parameter on the A6, except for the analog and digital effects section. Working on that one as well...
For anyone interested, here is the PDF file
A6 patch sheet.pdf
 Filename:  A6 patch sheet.pdf
 Filesize:  103.38 KB
 Downloaded:  213 Time(s)
Something Completely Different
http://www.synthmusic.info
scd
PostPosted: Thu Dec 04, 2008 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
We're talking 497 parameters so far Shocked
andyval8088
PostPosted: Thu Dec 04, 2008 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I would think this would of been a nice addon to the manual. Thanks for posting.
scd
PostPosted: Fri Dec 05, 2008 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry folks, here is a more user- and printer friendly version AND one page less Razz
A6 parameter sheet_A6.pdf
 Filename:  A6 parameter sheet_A6.pdf
 Filesize:  35.63 KB
 Downloaded:  162 Time(s)
HrastProgrammer
PostPosted: Fri Dec 05, 2008 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Good work! I didn't look into details but, at the first sight, it seems like you forgot steps IJKLMNOP for the sequencer Wink
scd
PostPosted: Fri Dec 05, 2008 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
You're right, thanks! Actually, nobody feel hindered to do suggestions: Iwant a good sheet to fill in for certain sounds, so I can rebuild them on other synths for instance, and to "see" the tricks going on.
So... shoot.
Jyoti
PostPosted: Sat Dec 06, 2008 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
Wow, that's very cool, both that you've created it and also that you're sharing it! thumb up
My music: here!
scd
PostPosted: Wed Dec 10, 2008 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a sort of final version (without the FX parameters, that will become a separate document).
Added the sequencer missing steps, the missing sync parameter and corrected various little text errors.
A6 parameter sheet_A6-v3.pdf
 Filename:  A6 parameter sheet_A6-v3.pdf
 Filesize:  35.92 KB
 Downloaded:  271 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Thu Dec 11, 2008 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you ! lot of work
fr.gr. sunny
sven kalmar
PostPosted: Wed May 06, 2009 1:28 pm    Post subject: thanks Reply with quote  Mark this post and the followings unread
yea thanks a lot , very use ful to memorize funtions
Niio2
