MFB modules...compatability with Doepfer
Page 1 of 1 [3 Posts]
stoooooo
PostPosted: Mon May 25, 2009 5:20 am    Post subject: MFB modules...compatability with Doepfer Reply with quote  Mark this post and the followings unread
Really like the look of this MFB module:
http://www.thomann.de/gb/mfb_modul_seq01_drumsequencer.htm
I cant find too much info about them though. Does anyone know if they will work with a Doepfer Case/PSU?
Stoooooo
Eav
PostPosted: Mon May 25, 2009 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it's perfectly compatible: look for it on the Scheidersburo website: http://www.schneidersladen.de/english.html
best
yves
Electronic battle
PostPosted: Wed May 27, 2009 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the MFB SEQ-01 trigger sequencer; it's excellent. I also have the MFB MIDI/PSU which is fully compatible with Doepfer modules, seeing as it powers the EQ-01 and also a Doepfer quantiser and clock divider. The MFB MIDI/PSU means that you can derive analogue clock pulses from a MIDI clock.
I had a minor problem with the MIDI/PSU, namely it wouldn't provide stable clock widths to drive the SEQ-01. So Manfred (Mr MFB himself) immediately sent me free of charge a replacement Atmel which solved the problem.
The SEQ-01 is very versatile and I aim to get other MFB modules. They're nicely made and they look good and seem robust to me.
Niio2
