  faux pas quartet and friends Music From Last Thursday
The Thomas Henry Mega Percussive Synthesizer
Page 20 of 27 [658 Posts]
Goto page: Previous 1, 2, 3, ..., 18, 19, 20, 21, 22, ..., 25, 26, 27 Next
magman
PostPosted: Fri Jun 05, 2009 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I think this is the tool you are looking for.
http://www.mouser.com/Search/Refine.aspx?Keyword=571-598031
You shouldn't have to bend the wire at all, just rest it on top of the connector and push down with the insertion tool. You also have to be careful not to use too thick a gauge of wire, or this can splay the connector and give an unreliable connection.
These connectors are known as IDC's, or Insulation Displacement Connectors, the idea being that when you push the wire down into the connector, the sharp edges of the connector cut through the insulation and make contact with the conductor inside the wire. It is actually a very good method of connection in some ways. Apart from being very quick in a production environment, the insulation is displaced by the connection process, which gives a gas tight seal between the conductor and the contact, which reduces the oxidation of the contact leading to a relatively long lived connection.
Regards
Magman
hendrixworkshop
PostPosted: Fri Jun 05, 2009 6:28 am    Post subject: Thanks for the clarification Magman Reply with quote  Mark this post and the followings unread
Magman,
Thanks for the quick answer. I'm ordering that tool now.
Andy
hendrixworkshop
PostPosted: Tue Jun 16, 2009 12:34 pm    Post subject: ...yet another bug related (front panel) question Reply with quote  Mark this post and the followings unread
I'm assuming that the input/output jacks in these pics are banana plugs? I've seen how partial bugbrand is to these.
The parts list off the Stites website calls for "1/4 " phone jack, n.c.". The Mankato calls for 1/8" jacks. And here I see the banana jacks on the Bug MPS. Am I caught up in what boils down to different preferences? I'm planning on building 2 MPSs, a TH101, TH201 and a TH301. Should I be putting 1/8" jacks in all of them?
I'm almost ready to wire up the panels (still designing MPS front panel ala the Bug MPS 3 space frac). I think this is the point in which I should standardize (if need) for the future.
I appreciate any help on this subject.
Andy
 Filesize:  115.95 KB
 Viewed:  93 Time(s)
 Filesize:  154.26 KB
 Viewed:  84 Time(s)
wmonk
Audio files: 9
PostPosted: Tue Jun 16, 2009 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Andy,
it all depends on your taste. If you like 1/4" jacks, use them on all panels, if you like bananas, use bananas. You can use different connectors in one project, but most people out here standardize to their preference.
It doesn't really matter which type you use, but when using bananas you must sometimes add a switch to get the same results. On the other hand, with bananas you don't need multiples in a modular system.
Hope it's clear,
Thomas Peter
nadafarms
PostPosted: Fri Jun 26, 2009 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
if anyone has a finished mps drum synth I'll buy it! I'm in Berkeley, CA
I can't even tighten screws... but I want one of these bad.
Funky40
G2 patch files: 5
PostPosted: Mon Jun 29, 2009 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello:
my MPS Boards are in progress, two things:
1. the 820pF cap is poly. Whats meant ? polystyrene ? ( or polypropylen)
2. Has somebody tips how to group the knobs ?
what belongs together ? ( I must admit that i havn't had a closer look exept of following thiis thread back then, but infos where not much )
thanks
hendrixworkshop
PostPosted: Mon Jun 29, 2009 8:43 am    Post subject: Source/part number for "L" bracket Reply with quote  Mark this post and the followings unread
Does anyone know a source/part number for the "L" brackets (and hardware) used to anchor the pcb to the front panel? I need a few sets for all the Thomas Henry modules I have in the works, but mainly to finish my 2 MPSs.
Thanks,
Andy
Audio files: 36
PostPosted: Mon Jun 29, 2009 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd try poly(proylene) that's what I used. It's not very critical as far as I remember.
Here's a look at my layout.
 Filesize:  267.99 KB
 Viewed:  135 Time(s)
My only rule of music production is that there are no rules.
Funky40
G2 patch files: 5
PostPosted: Tue Jun 30, 2009 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks uncleK
funkyfarm
PostPosted: Tue Jun 30, 2009 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's what I've planned !
no impact cv potentiometer (attenuator) but a cv socket on rear panel.
And maybe three separate trigger sections Smile
will remove ENV I, N and S serigraphy through it helps understanding ; or just put ENV under SWEEP and DECAY pots.
maybe i'll put white pots on top (pitch/filter)
grey ones on decay
or brown
black elsewhere.
as you can see i'm real excited !
MPS030.fpd
 Filename:  MPS030.fpd
 Filesize:  2.25 KB
 Downloaded:  121 Time(s)
Audio files: 36
PostPosted: Tue Jun 30, 2009 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry funkyfarm,
I can't read .fpd s Sad
funkyfarm
PostPosted: Tue Jun 30, 2009 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
you know what ? you're lucky !
I came to see if swiss Funky40 was still awake in the night and to know if he saw the .fpd and
I've just imported a screeprint of it in illustrator to play with colors Smile
it will lie in a box (to put on a table...next to the klee seq)
funkyfarm
PostPosted: Tue Jun 30, 2009 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I said "colours" ?
(okay, that's too much and awfull)
funkyfarm
PostPosted: Tue Jun 30, 2009 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the SHELL section, can I put X PITCH (for main pitch) Y PITCH, Y DEPTH and X/Y BALANCE (and X SWEEP and X DECAY...) ? or Carrier and modulator ? that is it ?
That's really hard to get clear distinct sections...
creatorlars
PostPosted: Wed Jul 01, 2009 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my silkscreen layout. I am building two of these. I wanted to get a little more ornate than my usual layouts because I LOVE my Clangora so much and am expecting the same out of these...
I wish I had spent more time looking at the schematics and put send/receive on each section. But I already have two MOTM 2U panels drilled with this layout, so oh well! Smile
 Filesize:  32.79 KB
 Viewed:  144 Time(s)
funkyfarm
PostPosted: Wed Jul 01, 2009 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
(this is real art !)
Funky40
G2 patch files: 5
PostPosted: Thu Jul 09, 2009 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
hey, thanks for posting Very Happy
I just came back now to this to start now my Frontpanel.
I have two Boards populated, some more in backlog.
My plan is to build two modules with all the Pots and jacks, and patch then with those,
and then to work out some "preset Sounds" so that i can make some of my modules with much less pots.
I guess i will make trimmers in the back of the Module so that i can change Presets Laughing
mods ? uff, too much of a thinking for me now.
i'll follow you with much interest french funkyfarm Cool
Funky40
G2 patch files: 5
PostPosted: Thu Jul 09, 2009 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
Sorry funkyfarm,
you get the program for free here:
http://www.schaeffer-ag.de/en/download/front-panel-designer.html
Funky40
G2 patch files: 5
PostPosted: Thu Jul 09, 2009 11:22 am    Post subject: Re: Source/part number for "L" bracket Reply with quote  Mark this post and the followings unread
yup. some guys here turn out as real artists.
Thanks,
Andy
I just know the Motm style brackets.
i guess you would have to drill them by yourself that they suite.
check out www.bridechamber.com and maybe contact Scott ( see parts )
Funky40
G2 patch files: 5
PostPosted: Thu Jul 09, 2009 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I had a look to the panels, now i'm puzzled.
So much different all your Panels Shocked
hway23
PostPosted: Thu Jul 09, 2009 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just ordered a board yesterday. Really looking forward to building it out!
Funky40
G2 patch files: 5
PostPosted: Sat Jul 18, 2009 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
concerning all the connectors:
is the square pad the Pad #1 ?
thanks
Funky40
G2 patch files: 5
PostPosted: Tue Jul 21, 2009 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
funny, whenever i say thanks in advance i get no answer.
Danno Gee Ray
PostPosted: Tue Jul 21, 2009 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks
That should be the case. Without having mine to look at readily, I would say it is a safe bet that it is indeed Pin #1.
Funky40
G2 patch files: 5
PostPosted: Wed Jul 22, 2009 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks
yup it is, thanks.
I finished wiring now.
I thought it is #1, but then i thought it would be stupid if it isn't Laughing, so i asked
Niio1
