  faux pas quartet and friends Music From Last Thursday
WvOut Recording
Page 1 of 1 [6 Posts]
DrumAliens
PostPosted: Tue Jun 30, 2009 12:17 pm    Post subject: WvOut Recording Reply with quote  Mark this post and the followings unread
I have tried using WvOut to record stereo from the web. (OK slightly naughty). To get this to work I have had to connect the adc to WvOut which seems counter intuitive. Any ideas
Also I have tried this on another computer and it doesn't record any sounds what ever I do (adc, dac and turning up the volumes). Again any ideas
rec_stereo.ck
rec_stereo.ck
 Filename:  rec_stereo.ck
 Filesize:  1.01 KB
 Downloaded:  92 Time(s)
Inventor
Audio files: 236
PostPosted: Tue Jun 30, 2009 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
kewl. This should go into the examples directories of the distribution.
Also, sometimes there is a file permissions problem in saving the WvOut output. Make sure you've specified the current directory in the preferences of miniAudicle.
No matter how much society beats it out of me, I STILL want to make the world a better place. I am sick of the abuse yet I am powerless to stop it.
DrumAliens
PostPosted: Tue Jun 30, 2009 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
The code is basically a copy of the rec-auto.ck which is in examples\basic
Just added in the left and right channels so that I can drop the two wav files into Audacity so that I can make one stereo wav file
The files that I get out are the right length in terms of time but contain no signal
Inventor
Audio files: 236
PostPosted: Tue Jun 30, 2009 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, i had that problem. It was because I wasn't terminating the recording the way that miniAudicle wanted me to do it. Now I just click on stop virtual machine when I want the recording to end. Not sure what will work best for you, i.e. you can't stop the virtual machine on windows...
Inventor
Audio files: 236
PostPosted: Tue Jun 30, 2009 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I recognize the program. Was just sayin' a stereo version should be there also...
gsanchez
PostPosted: Tue Jun 30, 2009 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
had similar problem...
some of the examples from the wiki don't seem to work on windows... here is how I got it to work:
http://electro-music.com/forum/download.php?id=15921
just some modifications to rec-auto.ck
change the dac to adc, change to desired duration and it should work.
hope it helps.
