  DarthBuddha Meat Pinata http://meatpinata.com
Updated chuck-mode for Emacs
Page 1 of 1 [10 Posts]
kcfelix
PostPosted: Thu Jul 02, 2009 11:27 am    Post subject: Updated chuck-mode for Emacs Reply with quote  Mark this post and the followings unread
Hello folks,
I've announced this on the chuck-users list and they told me it would be nice to announce it here too.
I've just discovered and started learning ChucK and It's very neat. As I'm an Emacs user I downloaded the emacs mode for editing ChucK files. It was rather old and was missing some functionality so I've made an update.
http://bitbucket.org/kcfelix/emacsd/src/tip/my-lisp/chuck-mode.el
Features of this update:
  • Syntax highlight more consistent with other languages supported by Emacs
  • Added all keywords, types and library functions listed on the documentation.
  • C-c C-c inside a ChucK buffer will send the buffer code to the VM. If there's no VM process one will be created
  • C-c C-d remove a shred from the VM by a numeric id
  • C-c C-r replace a shred with the code on the current buffer
  • Easy customization for the path of the chuck executable, so you don't have to edit lisp code to change it.
Class and method name highlighting is not working yet, but I plan on adding it soon.
Well, I'm planning to update it frequently to make it better according to my use of it, but if there's anyone using Emacs for ChucK and want to give some advice it would be very nice Smile
If you use it and test it send feedback to the issue tracker: http://bitbucket.org/kcfelix/emacsd/issues/new/
Sugestions for enhancements are welcome as well as bug reports.
Right now it has been tested under Windows Vista and GNU Emacs 23. Future testing under Ubuntu Jaunty will be done soon too.
mrcold
PostPosted: Thu Jul 02, 2009 8:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is really cool.. too bad i don't like emacs Smile
but really.. nice work.
Audio files: 173
G2 patch files: 76
PostPosted: Thu Jul 02, 2009 10:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome kcfelix.
Thanks for this update. thumleft I think I'm going to try it out in Aquaemacs on OSX, see how it works (been meaning to try out another text editor on the Mac for a while).
/Stefan
Audio files: 173
G2 patch files: 76
PostPosted: Sat Jul 04, 2009 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
The syntax coloring works nicely in Aquamacs, though something went wrong when I tried to add a shred. I've added an issue report at BitBucket! Smile
/Stefan
kcfelix
PostPosted: Sun Jul 05, 2009 12:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Stefan, thank you for reporting Smile
I'll do my best to get around the issue. I have some theories about this, but it's a little difficult because I don't have access to a Mac to test it right now. I'll try under linux to see if it behaves similar to that. As soon as I have some answers I'll report back to you.
Kao
Audio files: 173
G2 patch files: 76
PostPosted: Sun Jul 05, 2009 2:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah it's not the most ciritical of bugs for me - I'm used to keeping an open terminal where I run the chuck application anyway. Besides, I often need to run with arguments (to get multiple in/out working) - but not always, and to have that work I'd need to edit the chuck-mode.el file. Could there be a simple way to load arguments - maybe by an environment variable or something?
Found an indentation thingie, adding that too to bitbucket.
Anyway, I think this syntax coloring makes things easier, and it's fun to try out emacs again (been 10 years or so). Smile
/Stefan
Audio files: 173
G2 patch files: 76
PostPosted: Sun Jul 05, 2009 2:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Blast! The colouring just stopped working! It no longer colours .ck files I open. The only thing I did was edit the "(defcustom chuck-exec "chuck"" line... Could you help a rusty emacser with a command that shows modes I have installed and/or what's wrong with them?
/Stefan
kcfelix
PostPosted: Sun Jul 05, 2009 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
That's really odd. Is it just with chuck files or is it happening with other type of files too? The modeline is indicating that ChucK mode is active? It could be that emacs is not more associating ck files with chuck-mode, but I have no idea why would that be the case.
Well, normally if something is wrong with anything loaded by your .emacs, the *Messages* buffer should contain something about it. Starting Emacs with the --debug-init option should also give you the complete stack trace of the error. You could also try to run the chuck-mode command to activate chuck-mode on your file and see what kind of message you get. If emacs says the command doesn't exist it's a signal that it didn't even could parse chuck-mode.el and you should check the file for errors.
If you edited the chuck-mode.el by hand, check if you didn't leave any open string quotation or parens around the lines you changed. The syntax highlight for elisp should made it obvious in the case of a string, so it's most unlinkely, but in the case of an unclosed paren you will have to check them manually. Emacs highlight matching pairs of pares when you put the cursor on an opening paren or right after a closing one, so it should be easy to check if there's any unbalance. You can always download a clean version of the file on the repository anyway Smile I've added some few new stuff in the last few days, but they aren't very dramatic changes. I should probably setup an wiki page somewhere to document the updated features of the mode.
Well, you should also know that you can change the value of the chuck-exec variable by means of an nice interface called "Easy customization". Just do M-x customize-variable <RET> chuck-exec and a buffer will open where you can change the variable value and then set it in many different ways (just for now, save it for future sessions, revert to the default, etc). If you choose to save it, it'll be written at the end of your .emacs with some special comment annotations so that the custom interface can find where to write all it's customizations. The nice thing about easy customization is that you can change a LOT of options without having to code any lisp by yourself. Type an M-x customize and you will be presented with a list of links of "customization groups" and each of those have many related options put together. It's a very nice feature IMHO, and it's also easy to make your package support it (the defcustom form is exactly for that).
Well, hope it helps!
Kao
Audio files: 173
G2 patch files: 76
PostPosted: Sun Jul 05, 2009 4:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
I copied ~/.emacs.d/init.el to ~/.emacs.el and then it started working again. Could be something weird going on with Aquamacs maybe...
Anyway, I have a method for solving this problem that I can probably use to troubleshoot if it happens again. Thanks for your explanation of things Smile I'm starting to rediscover why I used to like emacs.
/Stefan
kcfelix
PostPosted: Sun Jul 05, 2009 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fixed the indentation bug Smile
Also, I've added a specific page on the wiki for using ChucK on Emacs:
http://wiki.cs.princeton.edu/forums.html/ChucKWithEmacs
I'll document the features of my mode there, updating when I add anything new, so keep an eye on it!
And glad you are liking Emacs again. I think it's a wonderful editor. Amazing how easy it is to add support for editing any language! Updating this mode is being a great experience for me. I was trying to put myself on learning elisp, but never found the proper motivation.
Kao
Niio2
