alphacore76
Posted: Sat Jul 11, 2009 12:28 am Post subject:
Sample chance Composition Design |
Hello Everyone,
I was up late watching Documentaries on john cage and Sound Art and the ideas of letting chance determine the output of compositions or form of art.. So i came up with this simple method or idea.. and wrote a simple explanation of how i thought it would work and wrote a simple ruby example..
Code: |
# Builds Compositions based off Folder and sample hiarchie
# chooses the number of the sample based on postion with the folder..
# The key to this working is the random method as a ruby programmer
# the random method is ccreated using the rand() form of syntax
# samp=rand(42)+1
#number of channels to be played will be detrimened by the role of a dice
#in computer terms and for show of example the random method can be used
dice_roll=rand(5)+1
# puts "The Dice rolled a #{dice_roll}"
# puts "The sample to be added is the #{samp} down"
# this is that concept inside created into a simple application
# That in ruby at least is a single method that looks like this
def sample_chance_composition_designer
dice_roll=rand(5)+1
puts "You rolled a #{ dice_roll }"
dice_roll.times do
puts "The sample to be added is the #{rand(42)+1} down"
end
end
# in ruby this runs the method
by school training I'm a ruby programmer. I'd like to hear what people think on this subject and maybe even simple code examples in other programming languages. I will be writing a full example of this concept and providing a few audio examples at my blog by tomorrow afternoon.. _________________ Within Literature there are endless sonic possibilities
Alphacore Blog Site |
Posted: Sat Jul 11, 2009 3:35 am Post subject:
A program that randomly finds samples on the disc and plays them... that's a pretty neat idea!
alphacore76
Posted: Sun Jul 12, 2009 10:58 am Post subject:
Audio Example Added |
I added a Audio sample of this concept to my blog if your interested in hearing the output..
the link is in my signature
thanks and chat with everyone later.. _________________ Within Literature there are endless sonic possibilities
dewdrop_world
Joined: Aug 28, 2006 Posts: 858 Location: Guangzhou, China
Posted: Sun Jul 12, 2009 11:43 am Post subject:
You could do this in SuperCollider pretty easily, which will also do the audio rendering in realtime or by batch. Instead of telling the user which sample to add, SC would play it at the right time with no other intervention.
James _________________ ddw online: http://www.dewdrop-world.net
sc3 online: http://supercollider.sourceforge.net |
Inventor
Audio files: 267
Posted: Sun Jul 12, 2009 2:12 pm Post subject:
Last week I made a ChucK drum sequencer that has a random initialization button. It was amazing to me how good a randomly generated sequence could sound.
The sequencer is an 8-step sequencer simulating a two-handed drummer playing on a drum set with 8 drums. _________________ "Let's make noise for peace." - Kijjaz |
alphacore76
Posted: Mon Jul 13, 2009 11:49 am Post subject:
Last Night I was inspired by equations and serial music.. |
Last night i was watching a video on fractals and serial music and got me thinking and programming so knowing that music or midi falls in the range of 0-127 I wanted to write a simple program that created a serial composition that stayed within this range yet stay random in its output so this is what i came up with after a hour of playing around
Code: |
composition=[] #creates a Array to store the notes generated
x=rand(2)+2
z=rand(5)+1
a = rand(3)+1
# equation is x = rand(2)+12 + rand(2) + 1 * rand(x) + 3 - a
200.times{|y|composition << x=rand(2) + 12 + rand(2) + 1 * rand(x)+3 - a }
puts "The Notes with the composition"
puts serial_2
# send the array and creates the midi file
# serial_2.to_midi("song.mid")
This is the midi example of the above code..
[url] http://midishrine.com/midi/29748.mid [/url] _________________ Within Literature there are endless sonic possibilities
dewdrop_world
Posted: Wed Jul 15, 2009 8:27 am Post subject:
If you like ruby, I think you could get into SuperCollider pretty easily.
First a direct translation:
Code: | c=List.new; //creates a Array to store the notes generated
x=rand(2)+2;
z=rand(5)+1;
a = rand(3)+1;
// equation is x = rand(2)+12 + rand(2) + 1 * rand(x) + 3 - a
200.do{ c.add(x = rand(2) + 12 + rand(2) + rand(x) + 3 - a) };
c.postln;
c.asArray.plot; |
But you can make it tighter even than explicitly adding items to a List.
Code: | x = rand(2)+2;
z = rand(5)+1;
a = rand(3)+1;
// the following two lines do exactly the same thing
c = Array.fill(200, { x = rand(2) + 12 + rand(2) + rand(x) + 3 - a });
c = { x = rand(2) + 12 + rand(2) + rand(x) + 3 - a } ! 200; |
If you want to stream values out on demand instead of precalculating a whole array:
Code: | // pattern-routine, lazy style
p = Prout {
var x = rand(2)+2,
z = rand(5)+1,
a = rand(3)+1;
loop {
(x = rand(2) + 12 + rand(2) + rand(x) + 3 - a).yield
// get a bunch
p.asStream.nextN(200); |
Playing is easy, no intermediary midi file necessary (though you could write one using Wouter Snoei's SimpleMIDIFile class).
Code: | // automatically render using 'default' SynthDef
q = Pbind(
// Pfin self-limits to 200 notes
// you could use just "p+48" here and it'll play forever, until you stop it
\midinote, Pfin(200, p) + 48,
\dur, Pwrand([0.25, 0.5, 0.75, Pn(0.125, 2)], #[0.4, 0.3, 0.2, 0.1], inf)
).play;
q.stop; // when done |
The awesome kickass thing about patterns is how malleable they are. Three part polyphony with so little code, it blows my mind.
Code: | q = Pbind(
// Ppar handles the polyphony
// Pset assigns different panning to each strand
// note the Ruby-esque function argument syntax |i|
r = Ppar({ |i| Pset(\pan, (i-1) * 0.75, q) } ! 3).play;
r.stop; // when done |
Have a look - http://supercollider.sourceforge.net
BTW the equation is way cool - somehow it seems to modulate among different modal areas!
mysticalfairy
