Nancy Scarangella
Joined: Nov 06, 2009 Posts: 4 Location: Ridgewood, NY
Posted: Fri Nov 06, 2009 9:10 pm Post subject:
Three synthesizer recordings needed. |
Hello: I ask for information to have the following made for me.
I require three unique (inaudible) frequencies. These require the use of a synthesizer to record sustained digital-keyed notes of the following frequencies:
.0003 frequency (hz conversion required)
.067 frequency (1.31 hz)
.043 frequency (2.78 hz)
Oscillation .177 Set to mild pulsation
Also, what model subwoofer will have the capacity to precisely play these inaudible frequencies.
These is an experiment to rebuild bone.
I'm hoping this can be done easily.
Your expertise and response are greatly appreciated Nancy Last edited by Nancy Scarangella on Sat Nov 07, 2009 8:44 am; edited 1 time in total |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Nov 06, 2009 10:45 pm Post subject:
Re: Three synthesizer recordings needed. |
Nancy Scarangella
She wrote: | ... These require the use of a synthesizer to record sustained digital-keyed notes ... | Why a synthesizer? A computer is much more flexible to do something like this.
If it has to be a synthesizer it has to be special build to this need, although I think you're better of with single tone-generators, because I don't see why you want to filter these sounds...
Look for commercial test oscillators or a technician who can build these. Quote: | ... .067 " (1.31 hz) ... | If " means 'second' (1/60 of a minute), than .067" isn't 1.31 Hz [1 Hz = 1 cycle per second, so 67/1000 is less than 1.00 Hz, at least over here in Europe ] Quote: | Also, what model subwoofer will have the capacity to precisely play these inaudible frequencies. | Every speaker you want! You'll see the .0003 (Hz?) 'tone' slowly move forward and backward, if you use a sine like wave form.
BTW if you mean a frequency of 0.0003 Hz it will take 8 hours and 20 minutes to perform just one cycle... Rather long recording
If you'll find somebody who will write a computer algorithm to produce this sound I think the easy way is to use a pulse like wave form.
And last but not least the big question: "What do you want to do with these low frequencies?"
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Nov 06, 2009 11:40 pm Post subject:
Nancy Scarangella wrote: | ... .067 " (1.31 hz) ... |
Wout wrote: | If " means 'second' (1/60 of a minute), than .067" isn't 1.31 Hz [1 Hz = 1 cycle per second, so 67/1000 is less than 1.00 Hz, at least over here in Europe ] | Or do you mean the recording of the 1.31 Hz has to be 0.067 seconds long, which means it will be just a fraction of the tone, to be precise 11/125 of the cycle, a kind of pulse...
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Nancy Scarangella
Posted: Sat Nov 07, 2009 9:53 am Post subject:
Thank you Wout Blommers for your guidance. My responses follow.
These require the use of a synthesizer to record sustained digital-keyed notes ...Why a synthesizer?
.....A synthesizer was recommended as the instrument to create these frequencies........
.....Where can I find a technician who would understand this procedure?.....
.....As these calibrations were given by a "Master", I can only believe that the application of these frequencies to adequately move through the surface layers of skin and muscle, may require filters for clearer resonance. I will present this queston for further clarification and return.....
.....All countries would have identical numbers I believe...This too will be reviewed....
Also, what model subwoofer will have the capacity to precisely play these inaudible frequencies.[/quote]
.....This also will be reviewed for clarification.....
.....To rebuild bone.....
Until the next time, Thank you. Nancy |
Nancy Scarangella
Posted: Sat Nov 07, 2009 10:16 am Post subject:
[quote="Wout Blommers"] Nancy Scarangella wrote: | ... .067 " (1.31 hz) ... |
.....Yes. This combination was given as a conversion from (.067) frequency, converted to (1.31) Hz. for precision and is...a kind of pulse.... |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sat Nov 07, 2009 1:43 pm Post subject:
Using Sony SoundForge, a commercial sound generating program within a normal budget, the 0.067 second of 1.31 Hz delivers the following...
Picture 1: The settings in the program.
Picture 2: The visualisation of the sound, just a part of the sine wave...
Audio file (wav): 0.067 second of 1.31 Hz.
Wout
Description: |
Filesize: |
96.16 KB |
Viewed: |
11927 Time(s) |
Description: |
Filesize: |
51.08 KB |
Viewed: |
340 Time(s) |
Description: |
Download |
Filename: |
0,067_1,31Hz.wav |
Filesize: |
11.65 KB |
Downloaded: |
923 Time(s) |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sat Nov 07, 2009 1:45 pm Post subject:
BTW SoundForge is a HighTech precise program; even astronomic observations are measured it.
Wout |
Nancy Scarangella
Posted: Sat Nov 07, 2009 9:37 pm Post subject:
Sound Forge free download |
Wout Blommers wrote: | BTW SoundForge is a HighTech precise program; even astronomic observations are measured it.
Wout |
Great !!! This week I will focus on working with Sound Forge High Techs' program and let you know what materialized.
This is soooo exciting !! THANK YOU for your wisdom! Nancy |
Audio files: 278
magman
Joined: Feb 04, 2009 Posts: 363 Location: Liverpool, UK
Posted: Tue Nov 10, 2009 3:28 am Post subject:
I doubt it, as this patent mentions ultra-high frequency.
If you think of the size of the small fractures this therapy is targeting, the wavelength would have to be small, and hence the frequency high, to cause resonance in the cavity between the bone fragments.
That's my interpretation anyway.
Magman |
Inventor
Audio files: 267
Posted: Tue Nov 10, 2009 5:51 am Post subject:
I thought speakers had a lower frequency limit, often around 20Hz or so. Wouldn't a special transducer be required for such low frequeancies. Actually 1Hz is more the frequency of massage therapy than audio...
seraph
Editor
Audio files: 33
Posted: Tue Nov 10, 2009 6:15 am Post subject:
Inventor wrote: | Actually 1Hz is more the frequency of massage therapy than audio... |
Les,
I am sure you could locate a masseur/masseuse that can sing and synchronously massage in any frequency range _________________ homepage - blog - forum - youtube
Quote: | Don't die with your music still in you - Wayne Dyer |
Inventor
Audio files: 267
Posted: Tue Nov 10, 2009 6:30 am Post subject:
usw
Joined: Mar 22, 2007 Posts: 27 Location: valence france
Posted: Tue Nov 10, 2009 6:53 am Post subject:
to convert a number x between hz (frequency) and seconds (time), you just have to compute its inverse (1/x), so :
0.043 s = 23.255... hz
just like 0.043 hz = 23.255 s
and 0.0003 hz = 3333.333... s = 55.55... minutes, and I don't think any speaker nor human would catch this one...(or may be as a massage time-out device ?).
_________________ stripped down whishes, healthy regrets and a diversity of fears |
EdisonRex
Audio files: 172
Posted: Tue Nov 10, 2009 11:11 am Post subject:
Inventor wrote: | I thought speakers had a lower frequency limit, often around 20Hz or so. Wouldn't a special transducer be required for such low frequeancies. Actually 1Hz is more the frequency of massage therapy than audio...
Les |
Not really, Les. A DC coupled amp will quite happily make the speakers move around in sub audio ranges. The rolloff of frequency response has more to do with the measurement method, usually. I wouldn't recommend it, but you can put a square wave through speakers via a DC coupled amp. Not for long, as you're likely to smell smoke pretty quickly, but you can watch the speakers pop in and out, and you can most likely hear the thumps. _________________ Garret: It's so retro.
Inventor
Audio files: 267
Posted: Tue Nov 10, 2009 3:42 pm Post subject:
Cool, Paul, thanks for clearing that up, I always wondered about that. One trick I've used in the past is to remove the cone of the speaker with an x-acto knife and remove the cone frame with a Dremel tool. Then you have a transducer that can be placed directly on the skin to induce vibrations. Might work in this application.
