  faux pas quartet and friends Music From Last Thursday
what synth next ???
Page 2 of 4 [84 Posts]
sizone
Audio files: 46
PostPosted: Fri Nov 06, 2009 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
ChucK could be used as a sequencer of sorts (check the ChucK forum), Csound too I think. Both are free, but both are also programming language/environments and not dedicated sequencers so there's a learning curve. The microwave has a user definable and fairly powerful arpeggiator. It's also really easy to set up sustatando patches with it that will sound like they're sequenced. So while you may not be able to sequence a cover of Axel Foley on it right away, you'll be able to get a ton of sound to play with until you get your sequencing setup squared away (or learn how to ChucK). Re. the bcr, I don't know offhand, but using a daw mixer as a step sequencer is a -really- -really- good idea and I wouldn't be surprised if someone has hacked something together to do just that. That may be a good subject to do some research on.
DETOX
PostPosted: Wed Nov 11, 2009 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
damn ! either my microwave does not work properly or the power supply i use for it doesn't supply enough power. the voltage needed is 12 volts, thats okay for the universal power supply i have (the original one did not ship with the unit) but it only can supply 200 mA insted of aprox. 1000 mA needed.
when i turn the synth on it instantly makes strange noises (like an lfo driving a filter - popping or klicking) and when i'm shutting the supply off thereÄs a sweep even without pressing a key. BTW: the display, all buttons, knobs and even the midi status led seem to work as they should.
is there a way to set it back to factory condition? i might have pressed any buttons or changed any settings causing this problem...
helpme,pleaaaase.
maybe (hopefully) it's just a matter or amperes, so it miht work wih a different PS but it could also be a short or something in the osc section, right?
Korg POLYSIX/Korg POLY-800/Yamaha DX-7/Waldorf MICROWAVE II/Roland JV-1080
Audio files: 95
G2 patch files: 310
PostPosted: Wed Nov 11, 2009 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
You cant expect a 200 mA supply to work for a device that needs 1000 mA ... the synth will try to go on and then the power will collapse ... you'll have to get a proper one, and then it will work ok probably.
nobody
PostPosted: Wed Nov 11, 2009 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
My understanding, and I once asked my electrician sister about this, is that the voltage must be exactly correct and the current density can vary - but only somewhat. So Jan is right, you'll need to get one at least close to the correct amperage. I'm guessing some devices are more exacting than others, though, so close still may not do it.
xjscott
PostPosted: Wed Nov 11, 2009 8:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Get a proper power supply and stop messing with the 200mA. Using a 200mA wall wart for a 1A device is just going to burn out the power supply, and the fluctuating erratic brown out voltages you are feeding it as a result can destroy the device.
DETOX
PostPosted: Thu Nov 12, 2009 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
allright, thanks for your replies !!! i hope it works, will buy a new power supply
tomorrow.
but my original question is still up to date: what synth next? my current status of gear is:
Yamaha DX7
Korg Poly-800
Korg Polysix (yet broken but hopefully repaired soon)
Waldorf Microwave II
as i already mentioned, i might get a virus synth or a nord modular g2 (engine) but i stumbled across the studio electronics atc-1 and i am now quite interested in this unit.
REPLYYYYYYYYYY
Audio files: 15
PostPosted: Thu Nov 12, 2009 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I use Cubase SX3 and have been very pleased with it.
sizone
Audio files: 46
PostPosted: Thu Nov 12, 2009 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're fine with what you have. In answer to the question of "what synth next?" Be satisfied with what you have for the time being. Get a proper p.s. for the mw 2, get a battery and some replacement ram chips for the polysix so you have some knobs to twist, figure out what you're going to use for a sequencer, start patching and playing. Between the Korgs, the dx7 and the mw you already have enough polyphony and varied sound sources to produce some awesome stuff. Focus on learning your way around them and squeezing what you can out of them.
DETOX
PostPosted: Mon Nov 23, 2009 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, finally i was able to break my daily lazy-after-work routine today and bought some universal power supplies. the mw II works and sounds grrrrrrrrrreat !!! yeah yeah yeah !!! i might buy another synth for now, a roland jv 1080 or 2080, hehe !
DETOX
PostPosted: Sun Nov 29, 2009 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok ok ok, i somehow got addicted to synth collecting.....the result is a jv 1080 bought 1 minute ago....this will be the last synth for some months now...will buy a pair of monitors, an audio interface and a computer next.....okay, stop me from buying more synths Very Happy.
DETOX
PostPosted: Wed Dec 09, 2009 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, i finally recieved the synth and i have to say it's something else than i expected but a nice synth anyway, haha.
laura woodswalker
Audio files: 9
PostPosted: Fri Dec 11, 2009 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
sizone wrote:
I find sequencing a lot easier to do with hardware, RM1X or possibly electribe. If you don't mind covering the shipping I have an Alesis metavox I'm trying to sell.
I just bought a used Electribe MX1!!! It's awesome!
The first day i got it I was setting up backing tracks. So much easier than trying to come up with stuff on Reason. Like someone else said on a forum, soft synths like Reason just give you too much choice. I spend an hour just looking for the right sound & I'm overwhelmed.
The Electribe is easy, contained, straightforward, and the effects Rock!!
I also have an Alesis Micron and a yamaha MM6. I sometimes wonder if I could sell these and find one synth that rolls the capabilities of these 2 into one. Like maybe the Alesis Ion....
The most important music equipment is what's in front of the instrument.
nobody
PostPosted: Fri Dec 11, 2009 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have an Ion and I can tell you I constantly under-appreciate this nifty little machine. I don't know if it rolls the above-mentioned synths into one, but it's great, especially considering the price tag. You get up to four parts, separate per MIDI channel and/or spread across the keyboard. The main stuff can be done right on the top panel via clearly labeled pots. The only stuff you need menus for is the mod matrix. The effects are kind of limited, but its other strengths make you almost not care.
laura woodswalker
Audio files: 9
PostPosted: Fri Dec 11, 2009 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well as far as my gear: the Yamaha MM6 is just a basic, bread & butter keyboard. Turn the dial & get a sound. That's great for the simple Musician in me. If I want to go jam with my Deadhead friends, that's the keybd I'd use.
The Alesis Micron? Well I love some of the sounds, very powerful & edgy. I like being able to create patterns & setups. I don't like the "all in one knob" feature. I have been able to learn very little about oscillators, Modulation & all that, because with just one knob you can't get that "cause & effect' learning curve. It isn't very User friendly for beginners. Also, the fact that it only has 38 keys, makes most of the 'setups' and 'splits' kind of limited. (As for MIDI... I really don't use it, except in Reason. It is kind of beyond me.) What I really like about the Micron is the "latch". I figure I can latch a pattern & my hands can be free to tweak the electribe & vice versa. With 2 gadgets like this I could almost see how it would be possible to do a solo performance.
(I watched the soloists at E-M and said 'how the heck are they doing that??" now I'm just starting to figure out the tricks). See, I am a Big Newby if y'all haven't guessed Wink
As for the Ion...I guess the only way to get one would be on ebay??
laura woodswalker
Audio files: 9
PostPosted: Fri Dec 11, 2009 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
audiodef wrote:
I have an Ion and I can tell you I constantly under-appreciate this nifty little machine..
Actually you got me thinking about the whole issue of synths and which ones are good for which folks.
I googled the Ion to try & learn what it was all about. First off, is it still in production or not? Second, does it really do the same things the Micron does ? (patterns, setups, latch).
It has a lot of filtering knobs & suchlike. A confession: I really don't care that much about all that sound-modeling. I don't really know what most of it is. Wink There is a continuum of folks, on one side are the huge electronics geeks who know everything about voltage & filtering. On the other side are the folks who just dig Music.
I'm actually more on the Music side of it. Sure I love a spacy effect, but if you give me 10 filtering modulators I won't know what to do with most of them.
On the other hand, I really like functions that enable me to get more music! Like 'latch', patterns, I guess you would call it 'sequencing'.
I first joined this forum 2 years ago & I wanted some advice on my FIRST synth/keyboard. Now that I've been playing for 2 years (and have spent a good deal of that time just learning to PLAY, as in Bach, Beethoven, Beatles) I wonder what would be the best synths for me when it was time to "upgrade".
What synth next???
Audio files: 173
G2 patch files: 76
PostPosted: Fri Dec 11, 2009 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just in case you haven't figured - the Ion is just a Micron with fewer effects, more keys and a couple more knobs. I say "a couple more knobs" because everything isn't editable by using them, and you need to enter the menu system quite a lot if you want to patch up modulations etc.
Curiously and sadly, my take on the perfect newbie synth is one of those big expensive ones that gives you loads of knobs. You have a kind of instant effect of wondering what something does, tweaking it and finding out immediately. The DSI Evolver comes to mind (I have a PEK which is loads of fun).
I almost thinking of recommending something like a Roland JP8000. Soundwise it's primitive (being a 90s VA, meaning it's like a PC from the 90s compared to a PC from the present), but it has that big interface and it should be pretty cheap on ebay (even if these machines have started to acquire nostalgy-fueled prices). I haven't tried it myself, mind, just thinking aloud, judging it by its looks and talk elsewhere. There may be similar machines out there that are more suitable.
(Just noticed the new reply - this may just be off-topic rambling. I'll post anyway Smile
/Stefan
xjscott
PostPosted: Fri Dec 11, 2009 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've always liked the features (12 bit knob controllers, hurray!) and styling of the Micron (great feel to the keyboard and wheels), but the limit to 4 part multitimbrality rather than 8 was a problem for me.
Akai has licensed the Micron sound engine from Alesis and produced a 8 part multitimbral Micron for a similar price which they've called the "Miniak". It came out a few months ago. But it's not in a nifty orange color. (Sigh.)
Audio files: 173
G2 patch files: 76
PostPosted: Fri Dec 11, 2009 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hm, yes the latch feature. Curiously, these things aren't focused upon a lot by synth makers, I think. I agree that that kind of stuff holds a lot potential.
/Stefan
nobody
PostPosted: Fri Dec 11, 2009 8:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Crap... I just looked at alesis.com. I guess they don't make the Ion any more. WTF? The micron, from what I can see, can't hold a candle to the Ion. I don't think they made a good decision on that one. So yeah, you might need to look on ebay.
That's a shame.
nobody
PostPosted: Fri Dec 11, 2009 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Ion's definitely got your patterns, setups and it latches. Cool You can just turn it on and play, if that's your bag, or really get into the nitty-gritty, if that's your bag. It's an instrument that I think serves both worlds equally well. Like I said, all the main knobs being right on the front makes it easy to tweak anything - or not! - at any given moment. I don't see that on the micron.
nobody
PostPosted: Fri Dec 11, 2009 8:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just looked at the miniak on the Akai web site. I have to say: what is the deal with companies producing one main synth that looks like a dinky 80's Casio and purports to be a full-fledged "professional" studio/performance synth (micron, miniak, makes me wannayak)? The gear-geek in me is not buying this seemingly bizarre trend.
I'm gonna stick with my full-size keyboards with as many knobbies and potsalots on top as I can possible twirl my fingers around. I don't mind menus, but I mind the Casio-nostalgia look. Bleagh. puker pukel angry Thumb down
laura woodswalker
Audio files: 9
PostPosted: Fri Dec 11, 2009 9:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't care about looks, but yeah, I wonder what is the deal with all these mini-synths with only 37 keys! I guess they appeal to the budget-conscious.
Actually I guess they are for someone who already has a full size keyboard and just want something extra for the bells & whistles. I suppose that was my idea... get a double keyboard stand, play the MM6 with one hand and the Micron with the other.
But to play with 2 hands, I had to get into serious musician training, as in "Bach, Beethoven".
xjscott
PostPosted: Sat Dec 12, 2009 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, when the 25 key keyboards came out I thought they were ridiculous and silly and wondered who would buy them since obviously nothing much can be played on only two octaves.
But I now have a 37 key controller because it sits next to my typing keyboard on my desk, and I can access it easily, and also drag it around since it is lightweight. Also, works to carry easily around to places, and can be powered by a laptop's USB. It also has knobs with programmable LCD labels, aftertouch, a joystick, and an x/y touchpad, I had not had a touchpad before and wanted one and it is useful. And also has release velocity, and is the only controller I have that has that. So for me, it has its uses, and 3 octaves with easily accessible transpose buttons is pretty reasonable to do a lot of things. I still don't understand the 25 key ones.
I still have my various 5 octave synths I have accumulated over the decades, and really how many of those do I need. All of them are too big and heavy to fit on the desk with the computer. Would have been nice if one of them was a 6 octave model though.
Although my controller is a controller and not a synth, I can see the advantage of the small synths. They don't take up a lot of space, but you still have a keyboard to mess around with and get sound out of it. For other work it is assumed you have a studio with a larger keyboard for more serious work. The little standalone modules by themselves with no keyboard at all are slightly inconvenient when one has to do work because you have to turn on a bunch of equipment to do anything at all. With a small keyboard, things are happening after pressing only one on switch.
Muied Lumens
Audio files: 142
PostPosted: Sun Dec 13, 2009 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a few comments on the Micron/Ion/Miniak issues:
The Miniak is exactly the same as the Micron on the inside. The Miniak has a couple of outer enhancements, one being that the flimsy sliders on the Micron is replaced with wheels on the Miniak. I think the mic is included on the Miniak too.
The Micron does a lot more than 8 parts! It can do up to 26 parts including drum parts, but it still has the same 8 voice polyphony like the Ion, and programming these will be a pain.
Also, the Ion does not really have a sequencer, but an arpeggiator. Maybe a later update has sorted this, and the missing reverb too?
There are a number of software editors out there for the Micron if you get worried about the wear of that knob. I imagine these would work with the Miniak, although I have not heard anything of the sort on the web. Some are free/donation based, some are cheap.
http://midictrl.com/
http://www.hypersynth.com/ion-editor.html
http://mysite.verizon.net/retroware/
http://www.bizune.com/
...these are just of the top of my bookmarks - there are a lot of Micron editors out there.
Muied Lumens Base Star
laura woodswalker
Audio files: 9
PostPosted: Sun Dec 13, 2009 10:56 am    Post subject: Alesis Micron Reply with quote  Mark this post and the followings unread
Yeah, about the Micron.
After owning one for about a year I'm starting to think it's not for me. Mainly it is just too clumsy to use. Having one knob to set every parameter for every oscillator...what were these designers thinking?? I can't even figure out how to set stuff like Filter sweeps. It is a synth for geeks.
If I sold it on Craigs or ebay, I wonder what would be a good replacement in the used market around $400-500. A few I was looking at a few years ago: the Juno D, the Korg x-50. (I think that is the one you can pick up with one hand?) I would want some of the basic filters and a latch/pattern feature, but I don't need the whole menu of modulation that the advanced synths have.
Yeah, the latch feature would be hard to find. In fact, the latch is what made me want the Micron in the first place.
