 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
Curtis Lite. Granular synthesis for iPhone/ Touch
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [20 Posts]
PostPosted: Fri Jun 05, 2009 2:04 am    Post subject: Curtis Lite. Granular synthesis for iPhone/ Touch Reply with quote  Mark this post and the followings unread
Looks and sounds pretty mental!
http://thestrangeagency.com/?page_id=39
iTunes Link
ACHTUNG!
Audio files: 212
PostPosted: Fri Jun 05, 2009 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried it?
PostPosted: Fri Jun 05, 2009 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
You bet! I sampled Dorothy from the Wizard of Oz this afternoon, and freaked out the kids!! Shocked Laughing Laughing
It could do with a few more options like setting markers and triggers for various points on the waveform, and perhaps some sample memory, but it's a lot of fun already- and for 59p Exclamation (about one US dollar!)
ACHTUNG!
PostPosted: Sat Jun 06, 2009 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Thsi looks very interesting. I have used CrusherX on my PC which is a fine VST for granular experimentation but the application looks good for my iTouch. Hmm, will it work for iTouch minus the record facility?? Hmmm The name is interesting as it is probably named after the one of the fathers of Granular synthesis, Curtis Roads Wink
Bill
Audio files: 278
PostPosted: Sun Jun 07, 2009 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Sweet Smile
Audio files: 278
PostPosted: Tue Jun 09, 2009 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a little bit of my iPhone rehearsal of tonight. It starts with the Curtis granulaizer mentioned here, then around 1:00 some G2 sequencing comes in and then around 1:40 there is a silly duck solo thingie done with Android (75th birthday of the duck man after all). This was done in one take, into some delay loops and added a bit of reverb later.
reh-001.mp3
A bit of my iPhone rehearsal
 Filename:  reh-001.mp3
 Filesize:  2.95 MB
 Downloaded:  2026 Time(s)
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue Jun 09, 2009 11:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
excellent Jan Exclamation I do like it. It's pretty mental indeed Wink You make me want to buy an iPhone Shocked
Audio files: 212
PostPosted: Wed Jun 10, 2009 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jan, great piece. What do you use as the input for the Curtis program? I haven't had as good results just speaking or singing into it.
Audio files: 278
PostPosted: Wed Jun 10, 2009 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys, glad you like it.
For input I just mumble and whistle into it ... but ... I find it to be working well when having some different vowels ... and some sharp s, t, k sounds are nice too. But I try to keep some silence between the sounds, as that makes it easier to explore them. Pitch doesn't matter too much, unless you also want to play it like a mini sequence (by dragging from beginning to end over the entire sample).
iPassenger
G2 patch files: 78
PostPosted: Fri Jun 12, 2009 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice work that Blue, makes me feel quite uneasy, that bass sweep makes me feel quite ill. good stuff.
iP (Ross)
PostPosted: Tue Jun 16, 2009 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh wow what a piece Jan! Really f**king creepy!!
It's rather humbling to know that all you really need for wild experimentation, these days, is sitting right there in one's own pocket! Very Happy
ACHTUNG!
Audio files: 278
PostPosted: Fri Jun 19, 2009 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
There will be more tomorrow :-)
http://bluehell.electro-music.com/ss09/
Audio files: 276
PostPosted: Thu Nov 12, 2009 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
anyone using this with the touch?
EdisonRex
Audio files: 172
PostPosted: Thu Nov 12, 2009 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I only have it on my iPhone (and I use Heavy).
Garret: It's so retro.
Audio files: 276
PostPosted: Thu Nov 12, 2009 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
It looks like Heavy lets you import samples via wi-fi, which might be better than trying to get some sort of mic attachment for the touch
Audio files: 495
PostPosted: Thu Nov 12, 2009 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I have Heavy on iTouch and have imported a few samples, it is easy enough once you have done it a couple of times.
Audio files: 495
PostPosted: Thu Nov 12, 2009 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just remembered a problem I have had with this app - it never seems to load the entire sample, just a certain fraction of it, no matter the length of the sample...
Audio files: 278
PostPosted: Thu Nov 12, 2009 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe it can only handle mono samples?
Audio files: 276
PostPosted: Thu Nov 12, 2009 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
on the SA site it says
Currently short 44.1kHz 16-bit WAV files are supported. Curtis will use the first four seconds of longer files.
Audio files: 495
PostPosted: Fri Nov 13, 2009 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah...
That might just be it! Embarassed
