  faux pas quartet and friends Music From Last Thursday
Auto-tune?
Page 1 of 1 [8 Posts]
jamos
G2 patch files: 33
PostPosted: Sat Nov 21, 2009 1:10 pm    Post subject: Auto-tune?
Subject description: You'd think it would be easy...
Hey all -
I'm trying to make an autotune patch for vocals - yes, it's poor taste, but so what? I'd think it would be easy: use a pitch tracker to extract pitch, quantize that, take the difference between the quantized and unquantized signals and use that to drive a pitch shifter. But, alas, it doesn't seem to do anything: as near as my ears can tell, the difference between the two is always 0, so no pitch shift occurs.
The sub-patch is below; can anyone tell me what I'm doing wrong?
 Filesize:  30.12 KB
 Viewed:  1570 Time(s)
Audio files: 95
G2 patch files: 310
PostPosted: Sat Nov 21, 2009 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice idea!
I patched it up and some quantization does seem to occur to me, although glides are not fully eliminated ... thinking
BTW, couple of weeks ago I was listing to autotuned singing with gypsy scales .. used in hip hop like music ... I liked that Smile
jksuperstar
G2 patch files: 18
PostPosted: Sat Nov 21, 2009 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting! I've had this type of thing on my idea-plate for a while. I wanted to play a didgeridoo, but send in a sequence to pitch shift it, but do it based on the difference between the didge sound and the sequence. Very similar! I'll try to play with it tonight.
Audio files: 173
G2 patch files: 76
PostPosted: Sun Nov 22, 2009 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Why are you taking the difference between the original signal and the note quantized one? When I've tried my hands at this I've taken a pitch detector, note quantized its output and then plugged that straight into an oscillator pitch input, which then goes into a vocoder. I've had varying results (it's really tricky to get the pitch to "stay on target" for me), but I don't usually have any problem with the pitch itself.
/Stefan
Tim Kleinert
G2 patch files: 174
PostPosted: Sun Nov 22, 2009 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Auto-Tune, an interesting subject. Smile Hope nobody minds if I chime in.
AFAIK there is already a patch in the factory preset bank called "pitch correct" (or something like that) which does this kind of thing.
However, keep in mind that the pitch-shifter is based on a delay line, and therefore naturally has an amount of latency. This causes slurs and other artefacts when correcting notes. The patch mentioned above also suffers from this.
Some time ago, I attempted to build a pitch correction patch that is based on a different approach, extracting individual wavecycles of the incoming signal, pitching them according to the correction scheme, and redistributing them along the time-axis, which results in an artefact-free pitch shift (under the condition that the incoming signal is strictly monophonic and periodical).
The basic pitch shifter circuit:
http://www.electro-music.com/forum/topic-27228.html
The concept of the auto-tuner itself works, but the pitch detection isn't bullet-proof. I've since attempted to design the "maximum zero gradient" pitch detection algorithm on the G2, but got fed up with it at a certain point. Laughing That technique isn't optimal for voice anyway. The best would be AMDF, but that is simply impossible to patch on the G2.
Here's the first version. It has some issues (mentioned above), but anyway...
http://www.electro-music.com/forum/topic-26222.html
I made another one, based on a similar idea. This works better:
http://www.electro-music.com/forum/topic-26247.html
Maybe this is of use to someone.
t
jamos
G2 patch files: 33
PostPosted: Sun Nov 22, 2009 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
/Stefan
It's because I'm using the pitch shifter, rather than an oscillator and vocoder (though I think I will try that as well). The idea being that when the pitch matches the quantized value, there is no pitch shift; but when the pitch is off, it is shifted to compensate.
jamos
G2 patch files: 33
PostPosted: Sun Nov 22, 2009 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Chime away!
Yes, I guess the delay line could cause slurring which would mask the steps. I'd still think I'd hear a bit more in the way of stepping, but..
Your intonation patch is sweet. Lots of control and sounds good. I'll try adapting that and see what I get. Thanks x 10^6!
Jim
Audio files: 173
G2 patch files: 76
PostPosted: Sun Nov 22, 2009 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
jamos wrote:
/Stefan
Ah of course, sorry and thanks for explaining. I agree, it's a neat idea!
/Stefan
Niio2
