  faux pas quartet and friends Music From Last Thursday
 Forum index » DIY Hardware and Software » eChuck - Miniature Modular Synthesizer System
The Karplus Strong eChucK DIY Project
Page 8 of 22 [534 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8, 9, 10, ..., 20, 21, 22 Next
Dan Lavin
PostPosted: Thu Nov 26, 2009 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
oops...I didn't read your second paragraph.
I think you could generate a pulse and use an op amp to mix in a little audio signal. Any idea of how much modulation we're talking about? I'm guessing in the mV range instead of volt range.
Synth DIY since 1977!
Inventor
Audio files: 236
PostPosted: Thu Nov 26, 2009 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Dan, thanks for your questions, stuff like this makes it fun for me.
The input pulse amplitude controls the output amplitude linearly, so send in softer pulses for softer sounds, etc...
To patch in audio, just send it in on the Stim input. I have an extra opamp to provide the voice / audio input if you like.
Les
No matter how much society beats it out of me, I STILL want to make the world a better place. I am sick of the abuse yet I am powerless to stop it.
Inventor
Audio files: 236
PostPosted: Thu Nov 26, 2009 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Tell you what, let's have a little fun here. Howard won't like it, but how about a little competition?
Let's say that everyone who gets a Karplus Strong board does some experimentation and makes design suggestions. After some time we all vote and the winner gets a free second run circuit board!
I see this as a way of boosting the energy level of your brain power, nothing like a little competition, eh?
Les
Dan Lavin
PostPosted: Thu Nov 26, 2009 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Les,
OK, so the amplitude of the stim pulse is critical...if you want harmonics not to be static. Desirable but not critical. But to make it interesting, it should be done.
Right now, you've got it tied to the CV out, which makes it permanently tracking the pitch. This will give it a more acoustic feel since harmonics generally increase in acoustic instruments as the pitch goes up. However, it may be desirable to not track pitch. The stim should have a mixer so that pitch, velocity, noise, LFO, etc can be mixed into the signal.
My power chord guitar idea would definitely require a velocity input. But maybe I should just shut the heck up so I have a chance to win your contest!
Inventor
Audio files: 236
PostPosted: Thu Nov 26, 2009 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dan, I sure hope I didn't tie Stim to CV, that wouldn't work at all. The board has jumpers which when populated short the two CV inputs together. Also if the eChucK circuitry is present, a PWM on the right channel sets the CV level for the current note. Stim comes in on the left channel directly into the summing amp. So that's the deal on that...
Les
Inventor
Audio files: 236
PostPosted: Thu Nov 26, 2009 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dan Lavin wrote:
Les,
Oh, wait a minute, disregard my previous comment, I thought you were talking about KS, not BS. Yeah, I'm not happy with the stim circuit. I'd like to work it in with a one-shot or something. Maybe you can come up with something and win the contest? Haha
Les
Inventor
Audio files: 236
PostPosted: Thu Nov 26, 2009 7:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
In other plans about the BS board, the clock and reset need to be synchronized among many boards. It needs to be set up so that many boards can all receive clock and reset from one board, or run independently. I think we need a switch for this, not sure - you tell me.
Les
Inventor
Audio files: 236
PostPosted: Thu Nov 26, 2009 8:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I generated a bill of materials (BOM), attached. This is just the default BOM that bom.ulp generates, and I have not added DigiKey part numbers. Anyway, it's a BOM.
Les
KS7BOM.txt
KS7 BOM
 Filename:  KS7BOM.txt
 Filesize:  4.36 KB
 Downloaded:  47 Time(s)
Dan Lavin
PostPosted: Fri Nov 27, 2009 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Les, Yes you will need a switch for the clock and reset signals on each of the boards. I like the idea of "Master" and "Slave" settings for the switches, but nomenclature is up to you.
Inventor
Audio files: 236
PostPosted: Fri Nov 27, 2009 10:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dan, upon closer inspection there may be a simpler way to do it. The reset line doesn't need a switch. It's set up so we can hook all the lines in parallel and then all the switches work. Hit any reset to get a reset. The problem is the clock.
I could put a spdt clock switch with master and slave positions, yes. But what of an automatic way to do it? Like the clock only works when the clock input is not wiggling. I dunno, a switch is simpler and more foolproof. Then there are the connectors, not sure what to do about that. It will take some more pondering...
Les
Inventor
Audio files: 236
PostPosted: Sat Nov 28, 2009 12:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I put in a clock selection switch, but there are still details about how these things will be wired up. Specifically, in the eChucK configuration we need some jumper wires that have a low pcb footprint. I was thinking of headers. We would need to daisy-chain the reset i/o and clock in and out lines somehow. I think the cable needs a twist in it or something, but I really haven't thought it out.
For the stim I'm thinking of using the two spare TLO74 opamps as comparators and then only when stim is high AND clock is low do we generate a stim pulse. There is no room for an AND gate, but I can make one out of RDL or RTL or LEDIL or something. We'll see how that goes.
Any thoughts? Suggestions?
Les
wmonk
Audio files: 9
PostPosted: Sat Nov 28, 2009 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
You don't have to use the switch if you use switched jack sockets. You need a clock out jack on board A, and a switched clock in on board B.
Inventor
Audio files: 236
PostPosted: Sat Nov 28, 2009 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, i thought of that but there is no room on the board for switched jacks. Sad bummer man!
Les
wmonk
Audio files: 9
PostPosted: Sat Nov 28, 2009 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
The jacks don't have to be board mounted. Then you only need three holes for a jack, and one can choose which type of jack he wants.
Inventor
Audio files: 236
PostPosted: Sat Nov 28, 2009 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK that works for me. I'll design it that way, good one wmonk!
Les
Inventor
Audio files: 236
PostPosted: Sat Nov 28, 2009 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, and by the way I've received payment for four of the ten boards and I need one for myself, so there are only five left on a first-come first-serve basis. This should work out just about right I think, no boards to spare and everyone gets one, but place your order early to ensure you get one.
Les
wmonk
Audio files: 9
PostPosted: Sat Nov 28, 2009 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps you can do that with other components that have to be 'panel mounted'. Saves some space and in this case it would be nice to implement all the needed features.
You didn't post the layout you have now for the BS, but I can imagine there are some other space-saving tips. Like using vertical mounted trimmers instead of the standard horizontal mount.
And for spacing: use standard 0.1" header spacing for panel mount components.
Keep up the good work! Smile
Inventor
Audio files: 236
PostPosted: Sat Nov 28, 2009 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
wmonk, here are the updated BSG schematic and board layout. As you can see the board is very tight, but there is some room for a few 0.1" vias to connect to those fancy switched jacks.
I believe that the counter, the LEDIL, and the CV circuit are fine. The clock and reset circuit needs attention as does the Stim circuit. Comments welcome.
Les
BS7sch.pdf
BS7 Schematic
 Filename:  BS7sch.pdf
 Filesize:  46.04 KB
 Downloaded:  63 Time(s)
BS7pcb.pdf
BS7 Printed Circuit Board
 Filename:  BS7pcb.pdf
 Filesize:  81.47 KB
 Downloaded:  55 Time(s)
Inventor
Audio files: 236
PostPosted: Sat Nov 28, 2009 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Does anyone have a manufacturer and part number for those switched jacks? I can't seem to find one in DigiKey search.
Les
wmonk
Audio files: 9
PostPosted: Sat Nov 28, 2009 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
What about using rectangular LEDs (2 x 5mm)?
That would save some rows of space!
I use Switchcraft 112A 1/4" clones as jack. Always use switched type, and most of the time I don't use the switch, but hey, then they all look the same! There are many types available.
Inventor
Audio files: 236
PostPosted: Sat Nov 28, 2009 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, thanks to wmonk's help here and in the chatroom, we have better LEDs, a switched jack solution to clock/reset synchronization, and some other features. Still working on it though...
Les
Inventor
Audio files: 236
PostPosted: Sat Nov 28, 2009 8:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are the BS8 schematic and pcb pdf files for your review. The reset switch needs to be changed to a SPST but aside from that it's about done. Or so I hope. I guess I'd better prototype it before sending it out, huh? Oh well we have time, no rush. Please review the documents and offer your critiques if any, thanks.
Les
BS8sch.pdf
BS8 Schematic
 Filename:  BS8sch.pdf
 Filesize:  39.74 KB
 Downloaded:  56 Time(s)
BS8pcb.pdf
BS8 Printed Circuit Board
 Filename:  BS8pcb.pdf
 Filesize:  72.97 KB
 Downloaded:  73 Time(s)
mrcold
PostPosted: Mon Nov 30, 2009 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey les.. just listened to your Tuesday Show... Nice work!
looking forward to more!
Inventor
Audio files: 236
PostPosted: Mon Nov 30, 2009 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Cody, glad you liked it!
Les
Inventor
Audio files: 236
PostPosted: Mon Nov 30, 2009 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
By the way, on the BS board I have set up three sizes of DIP switches for the logic matrix: 12, 8, and 4. Each has two terms, so that the total number of terms is 12, 12, 8, 8, 4, and 4. In contrast, I could go back to the earlier way of doing it with six equally sized DIP switches of 8 bits each.
The trade-off here is that with only 8 bits, and clocking at 4 Hz, we get a 64 second song which is kind of short. Using all 12 bits we get a song 16 times longer, or 16 minutes. That's the timing, and the second trade-off is the flexibility. With the existing arrangement there is not as much that you can do with those 12 bits of song compared to six 8-bit terms. So that's the compromise.
Do you think I should leave the board as-is or change it to six 8-bit terms?
Les
Niio2
