  DarthBuddha Meat Pinata http://meatpinata.com
LooneyBoard 1--general purpose CMOS oscillator PCB
Page 1 of 2 [35 Posts]
fluxmonkey
PostPosted: Fri Nov 27, 2009 7:45 pm    Post subject: LooneyBoard 1--general purpose CMOS oscillator PCB
Subject description: preview--coming soon
I'm working on a series of CMOS/Lunetta-ish building block PCBs, which i'm hoping to offer for sale shortly. here's a preview of the first one: 6 oscillators based on a 40106; 4 more gated oscillators on a 4093; a digital ringmod on a 4011, and an LM386 audio amp... plus some utility mixer arrays and a prototyping area.
anyone interested?
b
screenshot
 Filesize:  22.72 KB
 Viewed:  145 Time(s)
www.fluxmonkey.com
General Elektrick
PostPosted: Sat Nov 28, 2009 8:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, I may take one or two depending on the price and shipping costs to germany.
Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage.
Danno Gee Ray
PostPosted: Sat Nov 28, 2009 8:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I too could be interested.
synthmonger
PostPosted: Sat Nov 28, 2009 8:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried using a 4070 or 4030 instead of the 4011 for "ring modulation"? I tend to like the sound of those chips more.
Youtube!
modular demos!
Whacky tunes!
DGTom
PostPosted: Sat Nov 28, 2009 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
& with 10 Osc.s it would make alot more sense (to me at least) to use a Quad XOR chip... 4 "ring mods" hell yes!!
The only other thing that occurs to me is the Amp / Proto section; the proto area is a little small, it would only just fit another 14/16 pin DIP right?
I think it would be neat to make the 386 amp a seperate board & expand the proto section into a nice big space for adding 1 or even 2 more ICs.
That way the amp board could have some extra bells & whistles as well, maybe a 385 for an active mixer; with summing node(s) to link into the mix sections.
Either way, its a cool idea & I'd grab a few; would make putting together little noise makers for friends alot easier, everytime I show off my lunetta / weevil I always get a request or 2.
sizone
Audio files: 46
PostPosted: Sun Nov 29, 2009 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not really all that keen on the lm386 myself. Seems like every time I try to use on my regulators start getting really hot. It also just does not sound good, not very useful unless you absolutely need to drive a small speaker.
fluxmonkey
PostPosted: Sun Nov 29, 2009 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
i haven't... but looking quickly via google, it looks like all 3 of those have the same pinouts, so they should be interchangable?
edit: just tried both of these out, and all 3 chips seemed to work fine... i did not hear much difference myself, but i was listening thru the cruddy 386 amp... Laughing
www.fluxmonkey.com
fluxmonkey
PostPosted: Sun Nov 29, 2009 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
the main reason for including it, as you say, is to drive a small speaker... in the workshops i've been doing, folks need to hear what they're building. but you're right, it's not that great sounding... but maybe good enuf for noize music?
the 386 also draws a lot of power, and you just skip it... but the way i have this laid out, you can link any or all of the sub-modules to a common power buss, or power any of them separately. so you could have 2 batteries, one for the 386 and another for everything else. or, you could add a power-starve option to either of the osc chips. or, you could power one oscillator with the output of one of the others. my goal was to balance flexibility and convenience...
also as mentioned, this is intended as the first in a series. obviously, this is a "voice" board; also have a sequency board and a modifier board sketched out. would welcome input or suggestions as to what you'd like to see...
b
www.fluxmonkey.com
ezekiel
PostPosted: Sun Nov 29, 2009 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool board for a starter lunetta synth!
As for what else...
I imagine a world of sounds not based on complex, scientifically accurate circuits.
I imagine a synth exploration process that isn't solely about schematics but more about combining circuits and making music. By "music", I personally mean noise.
I imagine there could be a series of smaller boards (less than 2x2 inches) for circuits like the ones discussed throughout the lunetta forum. Here are what has caught my attention lately (some on my breadboard). This stuff takes multiple ICs and lots of wires or components (but still less complex than DIY modular synth boards). Also, a lot of these have technical details that are a little over my head:
- analog CMOS stuff using 4007, 4049, 4007
- pseudo FM and pseudo PWM
- pseudo-random digital noise generator
- clocked shift register with XOR feedback loop (4015 + 4077)
- walsh generator (perhaps with outputs for sine, triangle, saw, ramp)
- ring oscillators (multiple rings or varying lengths)
- Nu and Nv neurons (bicores)
- output filters (THIS WOULD BE REAL COOL)
- distortion, fuzz, clip effects
- envelope / VCA
- intermediate-stage mixers
- output mixer and interface to 1/4" standard, RCA line-level standard, 1/8" modular synth, headphones
- R2R networks
- routing/switching matrix?
- controller input processor (for a bunch of switches, buttons, touchpoints)?
- Wolfram's cellular automata (like Rule 30 for chaos or Rule 90 easier) using 40174 + 4070
- exploit "metastability" (see wikipedia) of these ICs
- multiple 4046 PLL / VCO
Actually, I'd be excited to see *any* PC boards for easy-to-build circuits using standard CMOS parts. Harder than just chip-to-faceplate but easier than DIY modular with its rare components and gazillion parts.
Maybe there is a way to start a set of standards with Inventor's eChuck boards and stuff others have done. With 9 volts single supply. Standard input and output impedences. Standard protection for front-panel patching. I'm talking big but that is because these are the things that I have trouble understanding and getting correct.
Further, I think it would be even cooler if someone were to have built as SMT a ton of these circuits onto one big PC board with lots of places for wiring it to a personalized panel.
Thanks for making this. Sorry for getting carried away! What you have shown is great.
glacial23
PostPosted: Sun Nov 29, 2009 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be down for one of these. It would almost provide me with enough inputs for the 40181 ALU IC that I keep thinking about using in a Lunetta-ish context. Shocked
glacialcommunications.com
Inventor
Audio files: 236
PostPosted: Mon Nov 30, 2009 8:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
ezikiel, I have more of those little eChucK Lunetta breakout boards if you want to get started with those. The thing is, the value price point for any of these little boards is like $200 or more each. So if we made these designs it would take thousands and thousands of dollars to do it and we'd have to have 50 customers to make any money.
In contrast, a general purpose board can be used for anything. That's why I was so excited about the eChucK Lunetta breakout boards - it's just one design so you can build what you want.
I'm thinking of making the next batch of boards a little bit bigger to accommodate more potential designs. I'm open to suggestions there.
For the Lunetta board described here, how is the interconnect done between the different modules? Is it hard wired or configurable?
I think there is room in the Lunetta world for some Lunetta noisemakers like this board as well as the little breakout boards. They serve different purposes. I'd be interested in developing a simple noisemaker board if anyone wants me to do such a thing. What would you like me to put on it?
Les
No matter how much society beats it out of me, I STILL want to make the world a better place. I am sick of the abuse yet I am powerless to stop it.
fluxmonkey
PostPosted: Mon Nov 30, 2009 8:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
configurable... all 10 oscillator outputs are available separately, no hardwired connections between any of the oscillators, ringmod, or amp. right now, i have one of the prototypes wired so the 40106 is doing a sort of angry bee swarm sound while the 4093 is doing a rhythmic click track both straight and into the ringmod.... the other prototype has a powerstarve pot on the 40106 configured with low-mid audio range caps and photocels... one of which is a VLFO feeding power to the 4093 via a big electrolytic... sickness.
unlike the complete blank slate of the echuck board, these layouts will provide building blocks of some standard configurations, like oscillators or sequencers... hopefully making it easier for folks to build composite collections of circuits into flexible instruments, without locking 'em into a single design.
agreed; these projects have different goals an potentially different audiences. the first batch of these will be available in about a week.
b
www.fluxmonkey.com
Inventor
Audio files: 236
PostPosted: Mon Nov 30, 2009 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
bbob, cool man. On future boards, you may wish to look into the screw terminals that we are using on the eChucK Lunetta breakout boards. All you have to do is put your I/O in rows and make the holes big enough. There are different style s of screw terminals available. They are a hint pricey but you don't need too many of them.
This way you can do your interconnect in a non-permanent fashion, fully configurable. If someone wants to make a more permanent arrangement (and save money on screw terminals), then s/he can just solder wires in place of the screw terminals.
Les
knittingram
PostPosted: Tue Dec 01, 2009 11:31 pm    Post subject: Re: LooneyBoard 1--general purpose CMOS oscillator PCB
bbob wrote:
anyone interested?
b
Definitely! Count me in for 2 of everything you make!
aerogramma
PostPosted: Wed Dec 02, 2009 1:29 am    Post subject: Re: LooneyBoard 1--general purpose CMOS oscillator PCB
-snip-
anyone interested?
b
definetely! The building blocks approach makes a lot of sense
Wink
electri-fire
G2 patch files: 4
PostPosted: Wed Dec 02, 2009 11:57 am    Post subject: Re: LooneyBoard 1--general purpose CMOS oscillator PCB
aerogramma wrote:
-snip-
anyone interested?
b
definitely! The building blocks approach makes a lot of sense
Wink
I like the building blocks approach. That's why I prefer inventor's e-chuck boards. One IC per board, totally modular. Easy to prepare for 14pin and 16pin CMOS.
I'm inclined to use the headers as well. But just because I have loads them in stock.
aerogramma
PostPosted: Wed Dec 02, 2009 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see Cool
Personally I like a lot the idea of having a pcb already designed to be filled with all those elements you tend to do over and over (like 40106 oscillators).
takes a lot time out from repetition and gets you a lot of time back to experiment with the ... bigger picture Wink
i'll always pay for time...
plus some of the blocks suggested here are really cool! Shocked
aero
fluxmonkey
PostPosted: Wed Dec 09, 2009 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Boards are on their way... some additional info here: http://www.fluxmonkey.com/electronoize/looney1.htm
b
www.fluxmonkey.com
aerogramma
PostPosted: Wed Dec 09, 2009 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
great stuff!
aero
droffset
PostPosted: Wed Dec 09, 2009 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for a couple as well.
https://docs.google.com/Doc?docid=0AZIwOP-PR9sSZDlidzgzbV8wY3RjenJqanY&hl=en
Edit: Spelling mistakes.
RF
Audio files: 29
PostPosted: Wed Dec 09, 2009 10:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Neat project bbob!
Way to go.
bruce
www.sdiy.org/rfeng
chutneyfarmer
PostPosted: Wed Dec 16, 2009 5:30 pm    Post subject: Still available?
Subject description: Still available?
Are there any of these boards still available? Really interested in taking one or two off you! What's the cost incl. shipping to Ireland?
fluxmonkey
PostPosted: Thu Dec 17, 2009 8:45 am    Post subject: Re: Still available?
boards should be in this week. i am updating the documentation and setting up an ordering process... i want to make sure everything goes smoothly from the start. i expect to start taking orders by the first of the year, i will post announcements here. thanks for your interest & patience.
b
www.fluxmonkey.com
Tim Servo
PostPosted: Thu Dec 24, 2009 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey BBob,
Looks like a fun circuit. I might offer a few suggestions for the PCB:
1) Try to move the designators (silkscreen legends with things like R10, C4, etc.) so that they are still visible when the component is in place. It takes a little extra room, but it makes assembly and troubleshooting a lot easier.
2) Maybe outline the separate sections of the board with a line on the silkscreen layer. This is just a graphical aid to show people where the separate sections are.
Neither of these is critical, but they might be nice graphical aids for your users. Just a thought. Smile
Tim (has the occasional thought) Servo
Inventor
Audio files: 236
PostPosted: Thu Dec 24, 2009 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey bbob, would you like me to feature your board on my radio show "Inventor's Inventions"? The next show is January 5th. I am covering various inventions ie circuit boards that people at electro-music create. Just let me know...
Les
