  faux pas quartet and friends Music From Last Thursday
Flimsy Knobs?
Page 1 of 1 [12 Posts]
Obzenity
PostPosted: Thu Dec 10, 2009 3:01 pm    Post subject: Flimsy Knobs? Reply with quote  Mark this post and the followings unread
I've had my A6 for a short while now and while I love the sound, I have to say the knobs range from being sturdy to really flimsy and "wobbly". Is this normal for the A6? What are your units like?
soundwave106
PostPosted: Thu Dec 10, 2009 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
No problems with mine here...
wildbill
PostPosted: Thu Dec 10, 2009 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
They're not 'rock solid', but they're not 'sloppy loose' either.
A little bit of wobble, but not enough to make me overly concerned I'd say.
pinealapoptosis
PostPosted: Fri Dec 11, 2009 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
My andromeda is the same as wildbill.Some of the knobs a re little more "loose" feeling than the others and have a little bit of play,but nothing to substantial.
The Gnomes have learned a new way to say Hooray
sunny pedaal
Audio files: 12
PostPosted: Fri Dec 11, 2009 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
voyagers are better, never bother much with the a6's knobs though
Numina
PostPosted: Fri Dec 11, 2009 11:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting. None of my knobs are flimsy or wobbly at all. - J.
www.numinamusic.com
www.myspace.com/numina
pinealapoptosis
PostPosted: Tue Dec 15, 2009 10:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I wouldnt use the words flimsy or wobble to describe how my knobs feels.Its just that some of them seem to have a bit of "play" in them.The OSC semitone knobs dont wiggle or move at all but the smaller knobs like the cents and fine knobs are little bit more "loose".You can grab them and sort of wiggle them side to side.Not a lot of movement but it is noticeable compared to say,my master volume knob or the filter frequency and semitone knobs,which are completely stiff.
The first andromeda I had(which I returned for a stupid reason) also had the same trait.
I was so paranoid right after I bought the andromeda that sent it back and exchanged for a different one because I thought something was wrong with it.Now I actually have a real problem with mine and I kinda wish I had kept the first one because in reality it probably had nothing wrong with it.
As soon as the second one got here I had to take it apart and adjust the mod wheel because it wouldnt stay in place at all.It slowly roll to the completely off position or if it was more towards on it would roll completely on.There was no middle.All it took was a bit of adjusting though and now it stays in place well.
Numina
PostPosted: Wed Dec 16, 2009 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
What you're describing sounds normal. Some knobs on mine are slightly less 'solid-feeling' and have a little play in them than others. Nothing terribly concerning though.
www.numinamusic.com
pinealapoptosis
PostPosted: Wed Dec 16, 2009 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah ha, that is what I thought! Smile
kpatz
PostPosted: Sun Dec 20, 2009 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think this is normal. The knobs have different sizes/types, and possibly makes of potentiometers underneath them, so they will each have a different "feel". Some will be stiffer than others. Some of the knobs may have 2-gang pots which tend to be a bit stiffer than single-gang pots.
I would think multiples of the same function knob (e.g. filter 1 cutoff vs. filter 2 cutoff) would have the same feel.
Tim Kleinert
G2 patch files: 174
PostPosted: Mon Dec 28, 2009 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
The pot shafts aren't screwed to the front panel, that's why they wobble a bit. That's normal and nothing to worry about. Securing 72 pots (!) to the panel would have increased the manufacturing price considerably, as it has to be done by manual labor. Also, in case of having to replace a pot (or a button), it would be alot more hassle first having to unscrew all the remainig pots in order to remove the panel board. So it's a reasonable compromise.
Just be careful (and use a dust cover too).
Shreddie
PostPosted: Wed Dec 30, 2009 7:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm terribly sorry but this thread has had me in stitches... All you lot talking the stiffness, sizes, types and wobbliness of your knobs! Mr. Green
