Audio files: 22
Posted: Mon Jan 18, 2010 10:12 am Post subject:
Thomas Henry Bass++ <QUAD PC BOARD SALE> IN STOCK NOW Subject description: ..... Yes, four of these voices on a single circuit card assembly ..... |
PC BOARDS ARE TEMPORARILY OUT OF STOCK, PLEASE CHECK HERE FROM TIME TO TIME FOR AVAILABILITY --- some parts kits still available so PM me with your requests -
PLEASE GO AND VISIT SCOTT STITES OFFICIAL BASS++ WEB PAGE
NOW YOU CAN HAVE (4) DRUM VOICES ON A SINGLE CIRCUIT BOARD.
http://www.birthofasynth.com/Thomas_Henry/Pages/Bass_Plus.html#Top
The Bass++ is a powerful drum voice designed by Thomas Henry with several front panel controls and jacks to control the various drum parameters. These controls can give the Bass++ a different sound at any given moment from deep bass to tom-tom to wood block sounds.
After Dan “Antman” Lavin approached me about distributing the Bass++ and exchanging alternate ideas about PCB configurations, he and I settled on, and thought, it would be a rather cool idea to have more than one complete Bass++ drum module available on a single circuit board. Keeping each Bass++ independent of each other was an important goal, sharing only the circuit and panel power connections among them. This would create a fairly complete electronic drum “set”.
Having each drum voice independent allows the builder to built one, two, three, or four modules depending on their needs. The number of Bass++ drum modules we agreed to reside on a single circuit board would be four and thus the Quad Bass++ was born. Now that was a handy circuit we thought. Personally, when building drum modules, I had always built more than one and it only made sense that more than one should reside on a single circuit board. This saves space and the trouble of mounting several boards in your cabinet.
After we settled on the idea, we asked for, and received, the blessings from Thomas Henry and Scott Stites to go ahead with the Quad Bass++ project. Dan began the PC board layout process. I was to proof the artwork, and make any necessary changes. I would also create any special silkscreen markings on the PCB to aid in construction, and create the documentation. sMs Audio Electronics will be producing and distributing the Quad Bass++ PCB. Each module or “voice” would need 9 front panel control potentiometers, 3 jacks, one panel mounted LED, parts for the PC board, and cable hardware. The board is small enough, approximately 4.75” square, to allow the user to build it into any standard enclosure.
I have attached the latest revision (REV E) of documentation but you may want to check here every now and then to see if you have the latest. It will always be at the latest revision posted right here on this first posting in this thread.
PARTS KITS FINALLY AVAILABLE FOR QUAD BASS ++ PCB:
QUAD Bass++ Single Voice Parts kit Includes:
(NOTE: These are parts to populate one of four voices A-D on your Quad Bass++ PC Board)
SINGLE VOICE INCLUDES:
(QTY 25) Resistors
(QTY 17) Capacitors
(QTY 5) 1N4148 Diodes
(QTY 2) 2N3904 NPN Transistors
(QTY 2) 2N3906 PNP Transistors
(QTY 1) LM13700 OTA IC
(QTY 1) TL072 Dual Operational Amplifier
(QTY 1) RED LED
(Qty 3) 6 Pin .100" Straight Male Polarized Headers
(Qty 3) 6 Pin .100" Polarized Housing Connector
(QTY 20) Crimp Pins for Housing Connector
(Qty 1) 16 Pin IC Socket
(Qty 1) 8 Pin IC Socket
By special request:
(QTY 2) CONN HEADER VERT 4POS .156"
Used for J1a and J1b power connectors. Only one set required.
PRICING & SHIPPING:
Professional Quality Two Layer, Green Solder Masked with White Silkscreen PC Board ---- $25.00 each
Single Voice Parts Kit ---- $17.00 (BUY 4 VOICES FOR $60.00 and save)
Used for J1a and J1b power connectors. Only one set required per board ---- $1.00 each set.
Shipping: US/CAN $5.00 flat rate
All other destinations: $8.00
Please Paypal me at: billnrob@optonline.net
FULL REV "E" BUILD DOCUMENTATION DOWNLOAD BELOW PCB IMAGE
Thanks !
Bill
2.04 MB |
| Viewed: |
202 Time(s) |
 Download |
| Filename: |
The Bass_REV_E.pdf |
1.19 MB |
| Downloaded: |
724 Time(s) |
Last edited by State Machine on Sat Dec 17, 2011 10:26 am; edited 22 times in total |
Dan Lavin
Joined: Nov 09, 2006 Posts: 542 Location: Spring Lake, Mi, USA
Posted: Mon Jan 18, 2010 10:53 am Post subject:
Bill,
Love the temporary control panel box! You might want to offer that as a kit, too! _________________ Synth DIY since 1977! |
Audio files: 22
Posted: Tue Jan 19, 2010 9:01 am Post subject:
Dan,
Hey funny !!! Hmm, now how much can I get for these white cardboard versions?
Bill |
wmonk
Joined: Sep 15, 2008 Posts: 381 Location: Utrecht, the Netherlands
Audio files: 9
Posted: Tue Jan 19, 2010 11:49 am Post subject:
Go Bill and Dan!
Very cool project guys. Will listen to the show to hear examples. Have to finish some modules first, but then its time for the drums!
Nice temporary case Bill. That truly has the DIY spirit.
wmonk |
ach_gott
Posted: Tue Jan 19, 2010 12:24 pm Post subject:
I'm in for 2 sets. I'm picturing a transistor drum circle.  |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1310 Location: Telford, PA USA
Posted: Tue Jan 19, 2010 4:48 pm Post subject:
| I'll be in for one. |
glacial23
Joined: Apr 30, 2008 Posts: 32 Location: Cleveland, OH
Dan Lavin
Posted: Thu Jan 21, 2010 2:10 pm Post subject:
Bill,
I missed your show on the 19th (always busy on Tuesdays!). Will it be posted in the radio archives? _________________ Synth DIY since 1977! |
Audio files: 22
Posted: Thu Jan 21, 2010 4:12 pm Post subject:
| Quote: | Bill,
I missed your show on the 19th (always busy on Tuesdays!). Will it be posted in the radio archives? |
Sure, I will get that together this evening and post it. I have work to do in the studio this evening anyway.
Bill |
Audio files: 22
Posted: Thu Jan 21, 2010 4:17 pm Post subject:
Here are a few more photos of the Q-Bass++ prototype board. I will also post the Q-Bass++ sound examples demo portion of my radio show from January 19, 2010 right here in this thread.
Bill
2.12 MB |
| Viewed: |
192 Time(s) |
1.98 MB |
| Viewed: |
125 Time(s) |
1.64 MB |
| Viewed: |
130 Time(s) |
PickNick
Posted: Thu Jan 21, 2010 10:13 pm Post subject:
Fish heads fish heads
Roly poly fish heads
fish heads fish heads
eat them up yummm... |
Audio files: 22
Posted: Fri Jan 22, 2010 4:45 am Post subject:
| Quote: | Fish heads fish heads
You know the funny this is, I remember that song. lol !!!
Thanks for the memory.
Bill |
reve
Posted: Fri Jan 22, 2010 11:29 pm Post subject:
| Needless to say, I am totally in for one. |
Audio files: 22
Dan Lavin
Posted: Sun Jan 24, 2010 6:16 am Post subject:
Great demo Bill! I'm glad you did it and not me! My demo would've been more pedestrian. You really pushed the capabilities of this device. Maybe a Quad unit wasn't big enough! Oh well, I guess folks can always get 2 units! _________________ Synth DIY since 1977! |
Audio files: 22
Posted: Sun Jan 24, 2010 10:43 am Post subject:
| Quote: | | Great demo Bill! I'm glad you did it and not me! My demo would've been more pedestrian. You really pushed the capabilities of this device. Maybe a Quad unit wasn't big enough! Oh well, I guess folks can always get 2 units! |
Thanks Dan. I tell you this is only one voice to. One can do a really nice mix of assorted sounds in one take using all 4 voices. I wish I had more control panels for the demonstration.
I would like to create a FRAC/Blacet style panel for these. Are there any interested in a panel of this type? I will most likely design one anyhow and post the Front Panel Express design file. The panel would be for a single voice so 1 to 4 would be required to build a system. If they are cheap enough, I will stock and sell them for anyone who would like to have one.
Bill |
Danno Gee Ray
Posted: Sun Jan 24, 2010 3:30 pm Post subject:
| I would be interested in a Frac or Euro panel for all 4 voices. |
diablojoy
Joined: Sep 07, 2008 Posts: 531 Location: melbourne australia
Posted: Sun Jan 24, 2010 4:32 pm Post subject:
| i am interested in a couple of boards as well |
Audio files: 22
Posted: Tue Jan 26, 2010 2:29 pm Post subject:
In a somewhat related topic originally posted here and subsequently split to a new topic, Stephen Giles posted a question on how to modify an EH Space Drum. Please do take a look here:
http://electro-music.com/forum/topic-39552.html
Bill |
slo
Joined: Feb 18, 2007 Posts: 201 Location: Victoria, BC
Posted: Fri Jan 29, 2010 5:40 pm Post subject:
I'd be in for 1 of these Bill, you're demo sold me.
George |
janvanvolt
Joined: Nov 24, 2005 Posts: 284 Location: Mainz, Germany
Level5
Posted: Tue Feb 02, 2010 12:53 pm Post subject:
| I'm in for 1 PCB |
Audio files: 22
Posted: Tue Feb 02, 2010 3:53 pm Post subject:
OK guys, this is very exciting and sounds like a board run could be really worth it I have been meaning to do just one thing and that decide on some breakouts for "benders" as I may have mentioned before. I shall do this in as short a time as possible. Work has been busy for me
Thanks and keep your eyes on the thread as I post new news.
Bill |
Danno Gee Ray
Posted: Tue Feb 02, 2010 3:59 pm Post subject:
| We look forward to it Bill. |
rosch
Posted: Sat Feb 06, 2010 6:35 am Post subject:
this is awesome!
two for me!!! |
