  faux pas quartet and friends Music From Last Thursday
Thomas Henry Bass++ <QUAD PC BOARD SALE> IN STOCK NOW
Page 1 of 6 [145 Posts]
Audio files: 22
PostPosted: Mon Jan 18, 2010 10:12 am    Post subject:  Thomas Henry Bass++ <QUAD PC BOARD SALE> IN STOCK NOW
Subject description: ..... Yes, four of these voices on a single circuit card assembly .....
PC BOARDS ARE TEMPORARILY OUT OF STOCK, PLEASE CHECK HERE FROM TIME TO TIME FOR AVAILABILITY --- some parts kits still available so PM me with your requests -
PLEASE GO AND VISIT SCOTT STITES OFFICIAL BASS++ WEB PAGE
NOW YOU CAN HAVE (4) DRUM VOICES ON A SINGLE CIRCUIT BOARD.
http://www.birthofasynth.com/Thomas_Henry/Pages/Bass_Plus.html#Top
The Bass++ is a powerful drum voice designed by Thomas Henry with several front panel controls and jacks to control the various drum parameters. These controls can give the Bass++ a different sound at any given moment from deep bass to tom-tom to wood block sounds.
After Dan “Antman” Lavin approached me about distributing the Bass++ and exchanging alternate ideas about PCB configurations, he and I settled on, and thought, it would be a rather cool idea to have more than one complete Bass++ drum module available on a single circuit board. Keeping each Bass++ independent of each other was an important goal, sharing only the circuit and panel power connections among them. This would create a fairly complete electronic drum “set”.
Having each drum voice independent allows the builder to built one, two, three, or four modules depending on their needs. The number of Bass++ drum modules we agreed to reside on a single circuit board would be four and thus the Quad Bass++ was born. Now that was a handy circuit we thought. Personally, when building drum modules, I had always built more than one and it only made sense that more than one should reside on a single circuit board. This saves space and the trouble of mounting several boards in your cabinet.
After we settled on the idea, we asked for, and received, the blessings from Thomas Henry and Scott Stites to go ahead with the Quad Bass++ project. Dan began the PC board layout process. I was to proof the artwork, and make any necessary changes. I would also create any special silkscreen markings on the PCB to aid in construction, and create the documentation. sMs Audio Electronics will be producing and distributing the Quad Bass++ PCB. Each module or “voice” would need 9 front panel control potentiometers, 3 jacks, one panel mounted LED, parts for the PC board, and cable hardware. The board is small enough, approximately 4.75” square, to allow the user to build it into any standard enclosure.
I have attached the latest revision (REV E) of documentation but you may want to check here every now and then to see if you have the latest. It will always be at the latest revision posted right here on this first posting in this thread.
PARTS KITS FINALLY AVAILABLE FOR QUAD BASS ++ PCB:
QUAD Bass++ Single Voice Parts kit Includes:
(NOTE: These are parts to populate one of four voices A-D on your Quad Bass++ PC Board)
SINGLE VOICE INCLUDES:
(QTY 25) Resistors
(QTY 17) Capacitors
(QTY 5) 1N4148 Diodes
(QTY 2) 2N3904 NPN Transistors
(QTY 2) 2N3906 PNP Transistors
(QTY 1) LM13700 OTA IC
(QTY 1) TL072 Dual Operational Amplifier
(QTY 1) RED LED
(Qty 3) 6 Pin .100" Straight Male Polarized Headers
(Qty 3) 6 Pin .100" Polarized Housing Connector
(QTY 20) Crimp Pins for Housing Connector
(Qty 1) 16 Pin IC Socket
(Qty 1) 8 Pin IC Socket
By special request:
(QTY 2) CONN HEADER VERT 4POS .156"
Used for J1a and J1b power connectors. Only one set required.
PRICING & SHIPPING:
Professional Quality Two Layer, Green Solder Masked with White Silkscreen PC Board ---- $25.00 each
Single Voice Parts Kit ---- $17.00 (BUY 4 VOICES FOR $60.00 and save)
Used for J1a and J1b power connectors. Only one set required per board ---- $1.00 each set.
Shipping: US/CAN $5.00 flat rate
All other destinations: $8.00
Please Paypal me at: billnrob@optonline.net
FULL REV "E" BUILD DOCUMENTATION DOWNLOAD BELOW PCB IMAGE
Thanks !
Bill
 Filesize:  2.04 MB
 Viewed:  202 Time(s)
The Bass_REV_E.pdf
 Filename:  The Bass_REV_E.pdf
 Filesize:  1.19 MB
 Downloaded:  725 Time(s)
Last edited by State Machine on Sat Dec 17, 2011 10:26 am; edited 22 times in total
Dan Lavin
PostPosted: Mon Jan 18, 2010 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Bill,
Love the temporary control panel box! You might want to offer that as a kit, too!
Synth DIY since 1977!
Audio files: 22
PostPosted: Tue Jan 19, 2010 9:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Dan,
Hey funny !!! Hmm, now how much can I get for these white cardboard versions?
Bill
wmonk
Audio files: 9
PostPosted: Tue Jan 19, 2010 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Go Bill and Dan! Very Happy
Very cool project guys. Will listen to the show to hear examples. Have to finish some modules first, but then its time for the drums! Smile
Nice temporary case Bill. That truly has the DIY spirit.
wmonk
ach_gott
PostPosted: Tue Jan 19, 2010 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for 2 sets. I'm picturing a transistor drum circle. Cool
Danno Gee Ray
PostPosted: Tue Jan 19, 2010 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll be in for one.
glacial23
PostPosted: Thu Jan 21, 2010 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for one.
glacialcommunications.com
Dan Lavin
PostPosted: Thu Jan 21, 2010 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bill,
I missed your show on the 19th (always busy on Tuesdays!). Will it be posted in the radio archives?
Audio files: 22
PostPosted: Thu Jan 21, 2010 4:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bill,
Sure, I will get that together this evening and post it. I have work to do in the studio this evening anyway.
Bill
Audio files: 22
PostPosted: Thu Jan 21, 2010 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are a few more photos of the Q-Bass++ prototype board. I will also post the Q-Bass++ sound examples demo portion of my radio show from January 19, 2010 right here in this thread.
Bill
 Filesize:  2.12 MB
 Viewed:  192 Time(s)
 Filesize:  1.98 MB
 Viewed:  125 Time(s)
 Filesize:  1.64 MB
 Viewed:  130 Time(s)
PickNick
PostPosted: Thu Jan 21, 2010 10:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fish heads fish heads
Roly poly fish heads
fish heads fish heads
eat them up yummm...
Audio files: 22
PostPosted: Fri Jan 22, 2010 4:45 am    Post subject: Reply with quote  Mark this post and the followings unread
You know the funny this is, I remember that song. lol !!! Laughing
Thanks for the memory.
Bill
reve
PostPosted: Fri Jan 22, 2010 11:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Needless to say, I am totally in for one.
Audio files: 22
PostPosted: Sat Jan 23, 2010 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are some examples of using just one voice of this four voice drum synthesizer. It runs for about 15 to 20 minutes with narration.
Bill
QuadBass++Demo.mp3
 Filename:  QuadBass++Demo.mp3
 Filesize:  11.73 MB
 Downloaded:  738 Time(s)
Dan Lavin
PostPosted: Sun Jan 24, 2010 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Great demo Bill! I'm glad you did it and not me! My demo would've been more pedestrian. You really pushed the capabilities of this device. Maybe a Quad unit wasn't big enough! Oh well, I guess folks can always get 2 units!
Audio files: 22
PostPosted: Sun Jan 24, 2010 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Dan. I tell you this is only one voice to. One can do a really nice mix of assorted sounds in one take using all 4 voices. I wish I had more control panels for the demonstration.
I would like to create a FRAC/Blacet style panel for these. Are there any interested in a panel of this type? I will most likely design one anyhow and post the Front Panel Express design file. The panel would be for a single voice so 1 to 4 would be required to build a system. If they are cheap enough, I will stock and sell them for anyone who would like to have one.
Bill
Danno Gee Ray
PostPosted: Sun Jan 24, 2010 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would be interested in a Frac or Euro panel for all 4 voices.
diablojoy
PostPosted: Sun Jan 24, 2010 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
i am interested in a couple of boards as well
Audio files: 22
PostPosted: Tue Jan 26, 2010 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
In a somewhat related topic originally posted here and subsequently split to a new topic, Stephen Giles posted a question on how to modify an EH Space Drum. Please do take a look here:
http://electro-music.com/forum/topic-39552.html
Bill
slo
PostPosted: Fri Jan 29, 2010 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in for 1 of these Bill, you're demo sold me.
George
janvanvolt
PostPosted: Mon Feb 01, 2010 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
To quote my former poster: i take one as well.
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
Level5
PostPosted: Tue Feb 02, 2010 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for 1 PCB
Audio files: 22
PostPosted: Tue Feb 02, 2010 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK guys, this is very exciting and sounds like a board run could be really worth it Wink I have been meaning to do just one thing and that decide on some breakouts for "benders" as I may have mentioned before. I shall do this in as short a time as possible. Work has been busy for me Shocked
Thanks and keep your eyes on the thread as I post new news.
Bill
Danno Gee Ray
PostPosted: Tue Feb 02, 2010 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
We look forward to it Bill.
rosch
PostPosted: Sat Feb 06, 2010 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
this is awesome!
two for me!!!
Niio1
