electri-fire
G2 patch files: 4
Posted: Thu Jan 14, 2010 6:25 am Post subject:
I got two delivered yesterday. First impressions:
Eight cheesy sounds, most of them with a piano like attack.
1: synthy sound
2: thin piano
3: Rhodes piano (my favorite)
4: thin clavi
5: harp/guitar like
6: reed like
7: bell/metallic
8: sax?
The lenght of the notes increases with slower BPMs. All sounds have a similar (fast) release. I suppose note lenght is shortened at faster BPMs to retain the polyphony for each step.
The bliptronic retains the last pattern when turned off and on again.
I sent it through Reaktor effects and was able to get some soundscaping stuff going. Ah well, even a Tammy Wynette or Willy Nelson record can be turned into a screaming noisefest with effects. Many 80's toy keyboards will give you more versatility and better sound for the buck. There's a serious lack of lows. I wish the designers had opted for a lower octave.
Line out is fairly hot, the volume knob has just sufficient response at low volume. Good to drive distortion devices (even a headphone, albeit at slightly lower volume).
All but one button feel responsive and reliable. Out of 128 (2x64) one I have to hit slightly oblique. Maybe it was somewhat displaced during assembly, there's some sideways slack in them. As the board needs to be pressed sideways to get the in-out jacks into their holes, I'll file some bevels at the inside of those holes first before reassembling.
I hope it works then. Even one slightly less functional button is distracting.
In-out sockets are soldered to the circuitboard, mine dropped 60 cm (nearly two feet) with the headphone attached, and damaged the headphone jack.
So today I opened it up. Four screws underneath the rubber pads: easy. Then remove the knobs. Now careful, the in-out jacks coming through the holes in the case fit rather snugly. I decided to press the jacks in from the outside with the tip of a ballpoint to prevent further damage.
| slacker wrote: | | It's certainly a fun little toy, hopefully it will turn out to be more than just that. |
I'm still content I got them.
(more later?) |
electri-fire
G2 patch files: 4
Posted: Thu Jan 14, 2010 6:44 am Post subject:
Great find Bruce. I registered to that forum to monitor developements. |
michaeluna
Joined: Jan 12, 2010 Posts: 2 Location: Chicago, IL USA
Posted: Thu Jan 14, 2010 8:46 am Post subject:
Greetings all. I was able to bend the Bliptronic's clock using a Getlofi precision timer kit, and I found some bend points on the audio IC that create a rich harmonic drone.
The sync in/out seems to be 5v pulses, and using the HighlyLiquid MD24 kit to translate, I was able to sync the Bliptronic up with Ableton live by sending it a MIDI note at the start of every measure. I need to take some photos and video, but I'll post here when I've got that up. |
RF
Joined: Mar 23, 2007 Posts: 1459 Location: Northern Minnesota, USA
Audio files: 29
Posted: Thu Jan 14, 2010 9:07 am Post subject:
| michaeluna wrote: | I found some bend points on the audio IC that create a rich harmonic drone.
Where? I found nothing like that...?
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
creekree
Joined: Mar 30, 2006 Posts: 165 Location: MÜNSTER, GERMANY
Posted: Thu Jan 14, 2010 12:38 pm Post subject:
yesterday i found out that the bliptronic keys are glow-in-the-dark! nice touch...
anyways, there is this video on youtube where a guy called gjyamada shows off his midi interface for the bliptronic:
http://www.youtube.com/watch?v=Jd-iiyE1lvQ
- and he has the schematics and code for download! i have not tried it myself though, as i do not have a PIC burner (anyone from germany willing to program the PIC for me?)
the midi interface obviously is "only" for syncing. |
slacker
Posted: Thu Jan 14, 2010 1:28 pm Post subject:
| electri-fire wrote: |
Nice find, looks like it's a lot more complicated than I'd hoped. My plan of getting some sort of useful digital signal from the logic board seems to be dead in the water.
I had a poke around those pins with my scope and couldn't figure out what was going on. Have to see what the Arduino boys can make of it.
I not too bothered, the more I play with it the more I like it.
One thing I have noticed is that the headphone out on mine has a couple of volts of DC on it, so you might want to be careful what you go plugging it into. Both of the outputs are really loud as well, I think I might make a little break out box to split the output to a pair of 1/4" jacks and maybe add volume controls or at least some fixed attenuation. |
electri-fire
G2 patch files: 4
Posted: Fri Jan 15, 2010 6:14 am Post subject:
| creekree wrote: | a guy called gjyamada shows off his midi interface for the bliptronic:
- and he has the schematics and code for download! /.../the midi interface obviously is "only" for syncing. |
And it's only for syncing MIDI gear TO the bliptronic, so you're still stuck with just the six BPM options.
I can't reach the schematic and code, because the URLs aren't complete.
Could you post them here? |
urbanspaceman
creekree
Posted: Fri Jan 15, 2010 7:59 am Post subject:
| electri-fire wrote: | | And it's only for syncing MIDI gear TO the bliptronic, so you're still stuck with just the six BPM options. |
curses!
i didnt know that, but it does make sense when i think about it...
there is no way that i will use the bliptronic as master clock source for my live PA rig.
i guess i'll have to wait for someone else to come up with a decent sync option then, as i can not develop anything like that myself. |
electri-fire
G2 patch files: 4
electri-fire
G2 patch files: 4
Posted: Sat Jan 16, 2010 5:35 am Post subject:
| michaeluna wrote: | I was able to bend the Bliptronic's clock using a Getlofi precision timer kit, and I found some bend points on the audio IC that create a rich harmonic drone.
/.../ I need to take some photos and video, but I'll post here when I've got that up. |
Someone called Sylvia had no results with the Getlofi clock, and I fear she (?) has some error there.
So our hopes are set on you for this one. So... questions:
Could you give an indication of the original clockspeed and the usable range for external clockspeed?
Did you remove the chrystal and insert your clock into the OSCI1 pin,or is more work involved? (Or am I totally in error here?)
Can you adjust the BPM now? (Oooh .. that would be nice...and it needn't be all that acurate as we can restart the sequence with the sync input)
Does the "synth engine" react to the clockspeed? |
slacker
Posted: Sat Jan 16, 2010 8:04 am Post subject:
I had a play around with it this morning and still haven't found any interesting bends.
Like RF already discovered the EF pins change the voice and the speed. You don't seem to be able to get any voices or tempos that aren't available from the switches though.
Connecting some of the pins to OUTL or SIGINL through a resistor or cap gives some nasty squarewave buzz on top of the audio. I don't think this really counts as a bend though, You're probably just mixing some logic pulses from the chip with the audio.
Poking around the AB pins and CD0 and CD1, sometimes changes the pattern. So maybe these pins are the ones that talk to the button board, I haven't traced them. Some of the AB pins also affect the speed and voice as well.
Interestingly, the synth board will work without being plugged into the logic board, it just plays whatever the last pattern was. If I'm feeling brave later I might try hooking the Lunetta up to some of the pins and see if I can make it play itself that way. |
electri-fire
G2 patch files: 4
Posted: Sat Jan 16, 2010 11:27 am Post subject:
Subject description: pots marked |
As can be seen BPM and Tone rotary switches are connected, so interaction is bound to occur.
| Description: |
| Filesize: |
130.14 KB |
| Viewed: |
190 Time(s) |
| Description: |
| Filesize: |
93.89 KB |
| Viewed: |
58 Time(s) |
electri-fire
G2 patch files: 4
Posted: Sat Jan 16, 2010 11:35 am Post subject:
| slacker wrote: | I had a play around with it this morning and still haven't found any interesting bends.
/.../ Interestingly, the synth board will work without being plugged into the logic board, it just plays whatever the last pattern was. If I'm feeling brave later I might try hooking the Lunetta up to some of the pins and see if I can make it play itself that way. |
That may well work. I'm sluggish tonight, but I havn't given up on this little toy yet. There's some timing involved in getting the right parameter adressed. |
slacker
Posted: Sun Jan 17, 2010 5:50 am Post subject:
Thanks for posting those diagrams, that's useful stuff.
I tried just firing random logic signals into the "Column" pins of the synth board and you can make it play itself.
Like electri-fire pointed out though, as the signals were not what it's expecting as well as changing the patterns it also changes the tempo and voice.
I also tried bending the clock using the Lunetta's oscillators with some success. My fastest oscillator only goes up to a couple of hundred KHz though so it just resulted in sonic mayhem, seems to confirm that it can be bent this way though. |
electri-fire
G2 patch files: 4
Posted: Mon Jan 18, 2010 3:55 am Post subject:
Memory for bliptronics 5000 switch/LED matrix
I devised some idea of using the switch/LED matrix with external memory, polling the switches, and storing their state. Reading the memory and driving the LEDs has not been addressed yet.
Disclaimer: untested theory, also made to get my head around what's happening. Using parts that may not be the most appropriate, but that I happen to have available. posted for your enjoyment and inspiration. Errors bound to be present..
MM2102A Static RAM (16pin)
Fixed pins:
Pin9= Ground
Pin10 = +5.25V max
Pin13 = LOW: enable
11 = DATA IN (serial in)
12 = DATA OUT (serial out)
pin3 High = read
pin3 LOW= write
5 + 5 address pins ( row x collum):
pins 1 2 4 5 6 7 8 14 15 16
3x3 bits is 8 x 8 bits of memory (64 values)
For convenience: pin 4, 5, 6 for Row and pin 14 15 16 for Collum
(This leaves 4 bits to select 16 additional banks on pins 1, 2, 7, 8 )
xxxxxxxxxxxxxxx
additional parts:
some master clock oscillator for counter
Binary counter like 4040 (6 outputs used to sequentially select memory locations)
4051 8-1 Multiplexer/Demultiplexer to select collum to be "scanned".
a X-OR gate
4 SPDT switches to select one of 16 banks.
xxxxxxxxxx
fixed connections:
4040 binary counter:
pin16 V+
pin 7 Ground
pin 9 (reset): Ground
pin 10 clock in
pin 9 > 4051 pin 11 , 2102 SRAM pin 4
pin 7 > 4051 pin 10 , 2102 SRAM pin 5
pin 6 > 4051 pin 9 , 2102 SRAM pin 6
pin 5 > 2102 SRAM pin 14
pin 3 > 2102 SRAM pin 15
pin 2 > 2102 SRAM pin 16
4051:
pin16 V+
pin 6, 7, 8 Ground
pin 11, 10, 9 is A, B, C binary value from 4040 pin 9 , 7, 6
Inputs: 13,14,15,12,1, 5, 2, 4 to collum pins 1-8 at the Bliptronic header.
pin 3 (output) > NAND gate input a (to toggle current memory state into the opposite value when a switch at the matix is pressed)
NAND gate
in a: from 4051 pin 3
in b: Latched "memory state" bit
NAND output > 2102 SRAM pin11 (input)
Bliptronic 5000 read/write:
remark: U7 is clocked to send power to the switches one row at a time (clock in at U7 pin8 = Bliptronic Header pin 10, as counted at http://www.straytechnologies.com/bliptronic-5000-hacking-full-pin-out-to-
the-64-button-pcb/ . This clock needs to be 1/8 of the master clockspeed into the 4040, so at each Row driven, the 4051 goes through 8 clock pulses to select each collum sequentially.
Therefor the U7 clock is taken from (ehrm..i think ) 4040 output pin 5 QD.
After 8 master clock pulses U7 needs to power the next row of switches, but the serial inputs at pin 1-2 only want a new Hi
step1
2102 SRAM pin12 (serial out (= state)) is the counter clock (to retain (latch) the state value)
state and collum go into a XOR gate, XOR out is write value, so:
state = Hi + collum = Hi : write value = Low
state = Hi + collum = Low: write value = Hi
state = Low + collum = Hi : write value = Hi
state = Low + collum = Low : write value = Low
2102 SRAM pin 3 is Low: write
Ok, done. Next clock.
step2 QB pin 4 is Hi */ Row2 is powered, now read collum 1-8 )
etc., until
step8 QH pin 13 is Hi (now read collum 1-8 )
next U7 selects Row1 again....
EDIT1: memory state and switch condition needed XOR gate (not NAND)
michaeluna
Posted: Tue Jan 19, 2010 2:31 pm Post subject:
| I was able to find some good bends on the Bliptronic and sync it up to a MIDI signal. Details at getlofi: http://www.getlofi.com/?p=2244 |
slacker
Posted: Tue Jan 19, 2010 2:44 pm Post subject:
Cool, thanks for sharing those  |
johnnymad
Joined: Apr 28, 2008 Posts: 40 Location: Gonzales, Louisiana
Posted: Wed Feb 03, 2010 9:38 pm Post subject:
| could the sync in/out be used to clock a modular? it seems like it could if it was sending out 5v pulses. has anyone tried this? |
RF
Audio files: 29
Posted: Wed Feb 03, 2010 10:07 pm Post subject:
It can clock my Klee and my Baby 10 sequencers (and presumably MFOS) - kind of...
Only one pulse out for every eight steps - and it must be in "Loop" mode, with a Y adapter into the "Link In" and "Link Out" jacks of the Bliptronic, and the other end to the clock input on the sequencer.
Without The "Y" you get one pulse out and the loop continues - with no more pulses.
johnnymad
Posted: Wed Feb 03, 2010 10:39 pm Post subject:
| thanks for letting me know. i don't know whether i want it or not after hearing that. |
RF
Audio files: 29
slacker
Posted: Sat Feb 27, 2010 4:46 am Post subject:
| Saw that the other day, looks quite interesting. I wouldn't have a clue what to do with it though. |
Houseman
Posted: Sat Apr 17, 2010 10:27 am Post subject:
Bliptronic 5000 dimensions? |
Hi forum.
I am going to buy a bliptronic 5000 to do a Ableton controller but before spending 99 bucks I would liker to know the external dimensions of the box.
Having think big fingers (hee9 is it useful to type on the pad?
How many room I mean height is available in there? all out except the key pad?
Best regards and thanks to all.
Steve |
