| Would you prefer one PCB with 3 VCOs a la JH-5A, or 1 VCO per PCB with more features |
| One PCB with Oscillator Driver and 3 VCO cores (like JH-5A - cheap!) |
63% |
[ 58 ] |
| 1 PCB = 1 VCO (with many waveforms and inputs) |
36% |
[ 33 ] |
| Total Votes : 91 |
JoeMorris
Posted: Tue Jan 05, 2010 8:11 am Post subject:
| PS thanks for another great design JH, I finally built myself a midi CV interface and the two oscillators that are working sound fantastic, even without any additional processing |
jhaible
Posted: Tue Jan 05, 2010 12:57 pm Post subject:
| JoeMorris wrote: | right... I haven't had much luck with replies to my silly issues recently which is fair enough because i realise people are busy...
But i'm hoping as this is quite precise i might be able to get some response here...
I'm getting there, but one of my oscillators seems to be running at a very high pitch compared with the other two... (at the lowest frequency pot setting it's still very high pitch)
I've fiddled with the T trimmer but that doesnt have a huge range and cant be the problem... Ive also checked the components visually with the other two oscillators that seem to work fine, and cant see any discrepancies..
Is there a simple problem that could explain this issue? |
It's almost always a simple problem, once you've found it, but finding from "remote" is nearly impossible. But ... with 3 identical circuits, and almost identical layouts, it should be easy when you sit in front of it: compare voltages between VCOs, not just visual appearance. A scope and two probes for probing a good and a bad VCO in parallel will certainly turn something up!
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
JoeMorris
Posted: Wed Jan 06, 2010 6:07 am Post subject:
Thanks for your reply JH,
I was just hoping that the symptom might shed light on a rather obvious problem someone else had come across or something I suppose.
But never mind - I'll just go back and give it a meticulous going over - only got one probe for the scope, but should manage it...
PS, did you see my question about the 1uf and 10uf caps in your transent gate schematic? I was just wondering whetehr they can be electrolytic?
Thanks
Joe |
JoeMorris
Posted: Thu Jan 07, 2010 7:28 am Post subject:
Gah...
Not having much luck here! Now the driver circuit - which worked perfectly before - seems to have gone down!
I can trace my changing v/oct signal to the CVs-in point in the driver section fine, but measuring the voltage on the driver out, it's just a static 5.5v, leading to an unpleasant tuneless drone...!
I switched all the chips in the section for fresh ones just in case one had blown for some reason, but, still not working!
I'm not expecting someone to solve this for me, just venting my spleen - I'm finding this circuit a bit hard to get up and running... due to my crude building abilities, I'm sure... just frustrated because it sounds LOVELY when it works!
Joe |
jhaible
Posted: Thu Jan 07, 2010 9:34 am Post subject:
| JoeMorris wrote: | Gah...
Joe |
Have you connected the portamento potentiometer?
(Mistake *I* ran into, once. No pot => CV path open.)
JoeMorris
Posted: Thu Jan 07, 2010 4:00 pm Post subject:
| Thanks for the tip JH, but yes, the Portamento pot never left its socket, so in this case it's unfortunately not the issue. Once I get some time I'll give it a proper analysis with the scope. I haven't made things easy for myself by wiring all the ins and outs into a case already though. |
numbertalk
Posted: Sun Jan 17, 2010 10:33 am Post subject:
Hi JH. I just noticed that the vibrato on my Living VCOs with rate all the way up is less than 1Hz. Is this normal?
Thanks. |
jhaible
Posted: Sun Jan 17, 2010 2:00 pm Post subject:
| numbertalk wrote: | Hi JH. I just noticed that the vibrato on my Living VCOs with rate all the way up is less than 1Hz. Is this normal?
Thanks. |
No. Whrong resistor or capacitor, somewhere?
numbertalk
Posted: Sun Jan 17, 2010 2:54 pm Post subject:
EDIT - I found it - I have a 1uf cap for C31, which is supposed to be 47nf. How on earth did I manage to do that?!?
| jhaible wrote: | | numbertalk wrote: | Hi JH. I just noticed that the vibrato on my Living VCOs with rate all the way up is less than 1Hz. Is this normal?
Thanks. |
JH. |
JoeMorris
Posted: Mon Jan 25, 2010 1:44 pm Post subject:
got all oscillators running - bizarrely, i swapped out the tl072 of the faulty oscillator with another oscillator's chip, and then they both worked... must have been a temperemental connection i guess.
anyway, this thing sounds massive. |
jhaible
Posted: Mon Jan 25, 2010 2:06 pm Post subject:
| JoeMorris wrote: | got all oscillators running - bizarrely, i swapped out the tl072 of the faulty oscillator with another oscillator's chip, and then they both worked... must have been a temperemental connection i guess.
Glad you like it!
Luka
Posted: Sat Jan 30, 2010 8:40 pm Post subject:
| jhaible wrote: | | Luka wrote: | just doing some testing before i fully power my vco up
jurgen what should the rails see on the 3046?
my vco 1+2 have +/- 15 on pins 1 and 13 but my vco3 has about +/-5
i have +15 going to R83 but for some reason it drops to 5v
is that correct? |
There are no power "rails" on this chip - it's just a transistor pair, with 3 unused transitors included, and the substrate connected to the most negative voltage (about -0.7V, on pin 13).
Pin 1 sees (+15V) minus (0.7V fom eb drop of Q15) minus (the zener voltage of reverse biased Q16). The latter isn't exactly specified, but somewhere between 5 and 10 volts.
So your VCO3 looks ok, but the full supply voltage on the array in VCO 1 and 2 seems very wrong.
JH. |
jurgen i just re-set up my studio and have been playing with this some more
i removed R13 (68k) and R12 (2k) and Q1, Q2 (and associated components within each vco) to compare and they are all the same and to spec. i checked the resistance and continuity between the rails and the points that intersect R13 and R12 and how those resistors hit the bc560s and lm3046 socket pins. i couldnt see any difference so i put the components back in the pcb and the problem is still there
im not sure why this is happening, everything else seems to measure up around the pcb
the one thing that i have noted when taking measurements on the pcb is that when i chain the power from VCO1 to VCO2 the resistance between the rails drops from about 18k to 9k. But i get the same high measurements at the LM3046 no matter whether VCO1 is isolated or chained to VCO2 via power connector
im a bit stumped as i matched everything across all VCOs when populating and ive confirmed that the resistors are the same within this section of the circuit what could cause the zener diode drops not to work in VCO1 and 2?
some diagrams
vco3
vco1 and vco2
 _________________ problemchild
melbourne australia
http://www.last.fm/user/prblmchild |
jhaible
Posted: Sun Jan 31, 2010 1:08 am Post subject:
| Luka wrote: | | jhaible wrote: | | Luka wrote: | just doing some testing before i fully power my vco up
is that correct? |
JH. |
some diagrams
vco3
vco1 and vco2
Measuring Resistance inside the circuit won't bring you anywhere IMO.
But the voltage measurements and your pictures are helpful.
The Zener drop across Q2 seems to be different in both pictures, but that's expected, and within the range where the expo converter should work. (But in the lower picture, Q2 isn't drawing any current, except what flows into your voltmeter, because of a defective 3046 - see below.)
In the lower picture, the 3046 isn't working properly. Bad connection, blown transistors, whatever - the transitors aren't even conducting.
The upper picture is strange. -5.75V at the emitters of the transistor array is unexpected. With Base2 (pin 4) at GND, Emitter2 (pin 3) should be around -0.6V. Conclusion: That 3046 has a problem as well.
jhaible
Posted: Sun Jan 31, 2010 1:14 am Post subject:
Here's an idea what might have happened: You may have created a short between pin 3 pof the 3046 and -15V on one channel (lower picture), killing that chip. Swapping chips between channels, you would then have killed the other chips as well. Inserting such a chip into an otherwise good channel would then produce the strange voltages shown in your upper picture.
Luka
jhaible
Posted: Sun Jan 31, 2010 12:04 pm Post subject:
| Luka wrote: | i dont have any IC in the circuit as of yet, just transistors and passives
should i pop one in to try stir up some current? |
Wait a minute - you want to say you never even had a 3046 in the circuit???
Then what are we debugging here?
Luka
Posted: Sun Jan 31, 2010 1:26 pm Post subject:
before i insert IC into pcbs i usually go around and check to see if all voltages look correct. since there was such a drastic difference between the voltages at the lm3046 between the different vcos i decided to ask why to see if it was a problem _________________ problemchild
melbourne australia
jhaible
Posted: Mon Feb 01, 2010 12:53 am Post subject:
| Luka wrote: | | before i insert IC into pcbs i usually go around and check to see if all voltages look correct. since there was such a drastic difference between the voltages at the lm3046 between the different vcos i decided to ask why to see if it was a problem |
That's good for opamps. But the 3046 is just a set of 5 npn transistors, and it's an integral part of a transistor-based (no opamp here!) expo converter.
Luka
2thick4uni
Posted: Sun Feb 07, 2010 7:08 am Post subject:
How can I get hard and soft sync on my Living VCO's?
I've built my Living VCO PCB and everything is working as it should, however as this is going to be the only (three) vco's in my modular I'd like more waveshapes and hard and soft sync. Sin and Tri waveshapes are easy, I'll just use MFOS VCO pcb's with just the waveshaping circuitry in place to get the full complement of waveshapes as per Bill and Will's Dragonfly Alley mods.
I'd really like to have hard and soft sync for the living VCO's, I've had a look at the schematic and as it is based on a standard integrator / comparator sawtooth oscillator so it should certainly be possible, however I do not have sufficient knowledge to implement it. I'd guess I need to apply sync to pin 2 of the LM311, however I don't know the implications of this..........
Has anyone done this already or can anyone give me some ideas to start experimenting?
Allan |
bennethos
decaying.sine
Joined: Aug 31, 2009 Posts: 68 Location: New Haven, CT, USA
Posted: Sun Feb 07, 2010 10:09 pm Post subject:
Hi Folks,
Wanted to check in with those who have ordered PCBs recently. Did you use the email form several pages back that JH posted? From what I can tell this seems like the mechanism for ordering JH designed PCBs. |
jhaible
Posted: Mon Feb 08, 2010 12:10 am Post subject:
| decaying.sine wrote: | Hi Folks,
Copy an order form from here:
http://electro-music.com/forum/topic-26164.html
Send it with your data filled in to my emal adress.
(Don't forget th eemail subject line; it's important!)
You'll get an invoice mail that tells you how to send money.
When payment arrives, boards get shipped within a few days.
bennethos
Posted: Mon Feb 08, 2010 2:57 pm Post subject:
need some help |
I've been troubleshooting VCO1 for a couple of hours (see pics in my previous post).
I've changed all ic's --> same problem
Ive changed all small ceramic caps --> same problem
checked all diodes --> they were OK
checked all transitors --> they were OK
changed my 10 turn dial --> same problem
Still have this little bump when my sawtooths starts, and at 3/4 my sawtooth flattens, it becomes worse when I increase the freq range.
I can't compare the other 2 vco's as they all have different kind of problems :p... I don't have a single one that is working...
One thing I'm concerned about, the tiny caps on the back of the pcb, I think I heated them too much when soldering them on the board...
Could you guys give me some advice ?
thx
Ben |
decaying.sine
Posted: Mon Feb 08, 2010 5:22 pm Post subject:
| jhaible wrote: | | decaying.sine wrote: | Hi Folks,
JH. |
I guess it is stickied!
I sent the multiple PCB order form to the email address on your website.
Thanks for the info and PCBs.
Brian |
