  faux pas quartet and friends Music From Last Thursday
“SN Voice” PCB's for SALE
Page 4 of 5 [116 Posts]
Audio files: 22
PostPosted: Sun Jun 13, 2010 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
it's actually the "Switch of the Opthamologists Gods". I just thought that would be obvious....
Oh nice Cool How could we miss that Wink
Bill
wmonk
Audio files: 9
PostPosted: Mon Jun 14, 2010 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
No, the illustration is correct. The label is just too vague - it's actually the "Switch of the Opthamologists Gods". I just thought that would be obvious....
Laughing
Thanks for fixing Smile replaced the SPDT switch I had for the LFO with one, and now have Hi range too Smile Sounds great Very Happy
Weblog!
Kits for synthesiser modules in Europe
RobotDad
PostPosted: Sat Aug 28, 2010 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Boards still available?
Audio files: 22
PostPosted: Sat Aug 28, 2010 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup, have em' in stock sir Wink
Bill
RSFC
PostPosted: Tue Sep 28, 2010 7:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Out of stock?
hanley
PostPosted: Wed Sep 29, 2010 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
nearly finished wiring up my front panel and have a question about building the connectors from the front panel to the boards, do the wires need to be soldered onto the connectors that go into the connector or is stripping them back a bit and crimping the in enough??
cheers
Audio files: 22
PostPosted: Wed Sep 29, 2010 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Out of stock?
Nope, still in stock ... Wink
Bill
Audio files: 22
PostPosted: Wed Sep 29, 2010 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I believe in the belt AND suspenders approach. I like to crimp the wires and then add a bit of solder to keep them from getting pulled out. If you use flux, clean it with alcohol then insert the pins into the housings.
I usually find that unless you make a perfect crimp, the wires are not secure enough and may pull out. Then again, I am not the best at using a crimper tool. Laughing
Good luck and please do post a picture of your work after completion. Cool
Bill
schmidtc
PostPosted: Fri Oct 01, 2010 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Just picked up 3 of these. That should keep me busy. Thanks!
Audio files: 22
PostPosted: Sat Oct 02, 2010 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got it !! Cool Thanks, your order will ship on Monday.
Thanks Very Happy
Bill
sMs Audio Electronics
Audio files: 22
PostPosted: Mon Oct 25, 2010 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like BG Micro has lowered the price on this chip for a really nice deal !!
http://www.bgmicro.com/search.aspx?find=SN76477
I still have SN Voice boards in stock ....
Bill
jumunius
PostPosted: Mon Nov 08, 2010 9:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I'm finishing up my SN Voice, and I'm to the wiring part. Conveniently I have documentation on wiring from both Bill/SMS and Scott Stites, but unfortunately the pot orientations sometimes disagree. For example, the LFO rate, Attack, and Release. In rear view, does the ground go to the left/center pins of the LFO pot, and the right/center pins of Attack and Release (Scott's way)? Or the reverse (Bill's way)?
(I'm assuming neither Bill nor Scott believe in some alternate universe pot orientation where envelopes get faster at CW, while LFOs get faster at CCW. Perhaps where pitch tracks from right to left even?)
Additionally, I'd love to know what the standard is for reading pot orientation from a schematic. If a pot schematic is viewed so that the arrow is pointing upwards, are you viewing the "rear view" or "front view" of the pot? (I tried to figure this out myself, but I seemed to get conflicting results from two schematics, so better to just ask the question.)
Anyways, I know that all this is done in spare time without copy-editing staffs, and I'm always psyched to have all these diagrams to refer to. (Not to mention nicely-made PCBs.) But I'm still pretty new at this and get mixed up easily, and it's no fun to flip my pot wirings after each build. Embarassed
Audio files: 22
PostPosted: Mon Nov 08, 2010 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi
See if this helps. It all looks OK to me and follows convention. For example, LFO CCW, lower frequency. On the diagram, LFO RATE is R56. If the potentiometer is turned fully CCW, it yields the maximum resistance and thus the lowest rate.
Bill
pot_wiring.pdf
 Filename:  pot_wiring.pdf
 Filesize:  51.06 KB
 Downloaded:  131 Time(s)
Audio files: 22
PostPosted: Mon Nov 08, 2010 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
From the schematic POV, it does not matter as long as you show an arrow and indicate if the pot is going CW or CCW in the direction of the arrow. When viewing a pot from the rear, NORMALLY, the center wiper is connected (lowest resistance) to the leftmost terminal when fully CW and connected (lowest resistance) to the rightmost terminal when fully CCW.
Bill
jumunius
PostPosted: Mon Nov 08, 2010 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Bill. I'll give that diagram a shot. I'm not sure why Scott's doc doesn't match but I'll send him a heads up once I've wired it up.
The only thing I'm still confused about is your statement above, since I can't see where schematics indicate CW/CCW orientations, they just show a zigzaggy resistor symbol with an arrow pointing to its center. This is true for example, the SN Voice schematics from Scott's site (and many other Thomas Henry schematics). So the only way I can see to tell would be if it matters that the arrow always gets drawn as approaching the resistor zigzag from the bottom or the top. Is there something I'm missing?
arsonus
PostPosted: Mon Apr 25, 2011 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you have SN Voice boards in stock? I would be interested to one PCB.
Thanks
Audio files: 22
PostPosted: Tue Apr 26, 2011 7:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure do, I have plenty of boards in stock
Thanks
Bill
tehskull
PostPosted: Wed Jun 22, 2011 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey there. I would like to buy 1 PCB please Very Happy
Audio files: 22
PostPosted: Thu Jun 23, 2011 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure, just go to page 1 of this thread and all the details are there for you to purchase how ever many you need.
Thanks
Bill
loydb
PostPosted: Thu Jun 23, 2011 5:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you also sell the TI chips? I saw reference to it in some earlier posts, but no mention in post #1. I want to get two boards with chips if possible.
williamlee
PostPosted: Thu Jun 23, 2011 6:08 pm    Post subject: Question on Pot Wiring Reply with quote  Mark this post and the followings unread
I am getting ready to build my SN-Voice and am very excited, but am still kind of confused over the pot wiring. I have the PDF that spells it out pretty clearly, but have a beginner question. Some of the pots list connections on J1 to +15/-15 (J1-8,J1-9). I understand that part, but others just show +15/-15, and there are a lot of connections to ground. I'm just wondering the best way to wire up these other ones. Where do people recommend I bring all the grounds together or am I wiring the ground on all of the pots to each other and then one final one to the J1-10 ground, etc.
Sorry if this is a rookie question, but I want to avoid mistakes, and the only other thing I've built with a fair number of pots on a panel is a Weird Sound Generator.
Thanks in advance!
mark_olson
PostPosted: Fri Jun 24, 2011 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome , williamlee!
It's been a long time since I built my SN Voice so I'm not positive how I did it. But I probably did what I usually do when there isn't a designated board connection, which is to connect to the nearest panel component iteration of whatever it is that's called for. So, if I need +15V and it is present on a lug of a nearby pot or jack, I'll just hook up to that. Mind the schematic, though, to be sure the point you connect to will always have what's called for, that is, don't connect to a point that, because of the position of some other pot or switch, will sometimes present something other than the desired value. When doing panel wiring I would not take all ground connections to a single point, but instead connect to wherever ground is nearest. I have no idea if this violates any "best practices" but so far it's always worked for me.
Good luck!
Mark
jumunius
PostPosted: Fri Jun 24, 2011 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
In my (limited) experience it seems wise to add some redundancy into your power wiring, especially the ground. So if 8 pots require a connection to ground, rather than just daisy chaining them in series, you should add a loop point or two. That way if one connection is bad or intermittent, it won't cause bugs in half your pots, but hopefully only a single pot (or none at all). Easier to isolate in troubleshooting.
I'm not sure what the official best practice is, but again, this has worked for me.
(That said, I have yet to wire my SN-Voice and now am probably going to wait a while as my current case is getting full. Sad, but it will be one of the first in my next case I'm sure.)
Audio files: 22
PostPosted: Mon Jun 27, 2011 5:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I don;t sell the chips anymore but here is where you can purchase the PCB's
http://electro-music.com/forum/topic-32942.html
Bill
Audio files: 22
PostPosted: Mon Jun 27, 2011 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
As far as common grounds and bus voltages, we are not talking any significant current carrying wires here so it's quite OK to daisy chain where possible along the front panel, ground as example, then bring it to a common point to the PC board. The 15 volt supplies can also be daisy chained since they are only biasing potentiometers of fairly high value so no high currents are flowing through those either.
Daisy chaining, however, is usually not recommended when the wires carry higher currents. For example, power supply lines. It is then prudent to run a unique wire to each circuit being powered along with it's return.
Bill
Niio2
