  faux pas quartet and friends Music From Last Thursday
Audio in to a 4093-based oscillator?
Page 1 of 2 [34 Posts]
corex
PostPosted: Sun Aug 29, 2010 7:06 am    Post subject: Audio in to a 4093-based oscillator? Reply with quote  Mark this post and the followings unread
I'm really new at this so bear with me.
I've built some 40106-based oscillators and 4093-based oscillators. When I run the 40106 oscs into the 4093 oscs, interesting things result. I was thinking that it might be interesting to run arbitrary audio into the 4093 osc.
I tried to run a Speak & Math through it but the oscillator was silent. I assume that since my 4093 circuit is 9v, the input is too low to trigger the gate. I think what I need to do is amplify the input so that it's loud enough to trigger the gate. I have some LM741 op-amps, but I've never used one before. They should be suitable, right?
Does that sound plausible?
Ajax
PostPosted: Sun Aug 29, 2010 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
This website really made the use of op amps pretty easy for me: http://www.colomar.com/Shavano/intro_opamp.html It should have what you need.
corex
PostPosted: Mon Aug 30, 2010 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! This page is pretty straightforward and understandable -- seems helpful. Back to tinkering....
Any idea if this will work, sending arbitrary audio into the 4093?
Ajax
PostPosted: Mon Aug 30, 2010 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can always try it and find out Smile That's the only sure fire way to know.
fluxmonkey
PostPosted: Mon Aug 30, 2010 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
how are you connecting the external signal in to the 4093?
www.fluxmonkey.com
Ajax
PostPosted: Mon Aug 30, 2010 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 4093 has a designated "gate in" pin. When the gate is at high rates, it tends to just get all wonky, in a good way (technical terms, I know).
corex
PostPosted: Mon Aug 30, 2010 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had some problems with my amp circuit, but I've got that cleared up now (I mistakenly connected the amp's V- pin to my 4.5V reference ground instead of 0V).
I have to say that it's definitely makes noise. More experimentation is in order to get a handle on what's really going on, but I can hear a distorted version of the input signal coming out of the 4093 oscillator.
Tuning the oscillator doesn't seem to have much effect at this point, however -- that's the part I need to explore. I expect the oscillator's tuning pot to have more of an effect that it seems to have, but then I've only had a moment to play with it. I'll get back to it this evening.
corex
PostPosted: Mon Aug 30, 2010 10:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's correct. Essentially I'm outputting the NAND of the input signal and the feedback signal. Here is an example of four 40106 oscillators fed into a single 4093 oscillator (I think "wonky" is reasonably accurate):
http://phlake.org/lunetta/STE-095%20-%20four%20NOT%20oscs%20into%20one%20NAND%20osc.mp3
-minus-
Audio files: 10
PostPosted: Tue Aug 31, 2010 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
COREX! This is a pretty decent Lunetta track you have recorded here! The 40 second mark is where it sounds great to me! Are you just connecting all four of the 40106 oscillators to the 4093.... no R2R ladder in between or anything?
corex
PostPosted: Tue Aug 31, 2010 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I do have a resistor after each 40106 oscillator. I collected them and ran them through a diode (not sure why.... seemed like a good idea) and then from there to the 4093. Here's a pic (before the input circuit was added):
-minus-
Audio files: 10
PostPosted: Tue Aug 31, 2010 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah that's clear! Great photo! One of the best I've seen. Zooming in gives an insane amount of detail! Wish my eyes were that good.
I think Rich might be sorting out your deathlehem account issues... maybe PM him here if he hasn't contacted you already...
Rykhaard
PostPosted: Wed Sep 01, 2010 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Wooo! That is an excellent resolution photograph! Everything wonderfully neat and tidy on the breadboard, as well. Smile
Hey ... PCB mounting pots! They, would save me a huge amount of real estate on my 3.4"x3.4" perfboards! I shall have to keep that in mind. Smile
Minus - whaaaaaaaaatt? I can't hear ya! Put your glasses on! Surprised Laughing
Wink Done.
corex
PostPosted: Wed Sep 01, 2010 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got a handful of them specifically for breadboarding; the pots I will use when I build something are all solder-terms. I've learned that I need a bigger handful of these right-angle pots though -- I used up all my 100Ks on that design, and I could easily tack on several more oscillators. It's enough to prove the concept though.
The photo is huge, it's true. I like 'em that way. It captures exactly how backwards the electrolytic cap is on the 4093... Embarassed
Thanks for getting my account set up, 'ppreciate it.
corex
PostPosted: Sat Sep 04, 2010 12:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm still having a problem where the audio input through the 4093 oscillator doesn't behave the way I expect.
I learned how to use Eagle well enough to draw up this schematic. I've checked it a couple of times so I'm reasonably sure it's correct, but I'm new to this so there might still be some mistakes.
I'm not sure what Eagle wanted to do with the power to the 4093 chip (IC2) so I omitted that part. The chip's VDD pin is connected to +9V with a decoupling 0.1uF capacitor to ground, and the chip's VSS pin is grounded to the negative battery terminal.
Also in the drawing you can see that I tied the op-amp's OFFSET pins to +4.5V reference ground with 100K pull-down resistors. I'm not sure if I needed to do that or not, but the op-amp seems to be working so I think that was okay.
I was playing with it a little yesterday morning, trying to better understand what's going on. I tested the oscillator by removing the op-amp from the oscillator's input (IC2A pin 1) and connected that pin's resistor (R7) to +9V instead of ground. In this configuration, the oscillator oscillates normally, and turning POT3 changes its pitch like usual. Leaving the resistor as it was, I connected the op-amp to the input again, and as soon as the connection is made, the oscillator stops oscillating. If the op-amp's audio source is providing audio, then the oscillator outputs that audio. When the op-amp is connected to the oscillator, POT3 seems to have no effect at all.
If the oscillator's input pin is tied to ground by it's pull-down resistor (R7), then it doesn't make sound by itself (0 NAND 0 == 1 and 0 NAND 1 == 1; no oscillation). In this configuration, which should be correct for gating the oscillator by the input from the op-amp, I get the same result, which is that if the op-amp's audio source is providing audio, then the oscillator outputs that audio and POT3 seems to have no effect.
What the hell is going on here?
DGTom
PostPosted: Sat Sep 04, 2010 12:32 am    Post subject: Reply with quote  Mark this post and the followings unread
1st thing I'd suggest is putting a diode from the output of the amp to the 4093 input - just to make things neat & tidy Razz
The 2nd thing I'd try is taking the analog signal from the amp & converting it to digital. Right now it maybe sometimes, sorta, kinda makes the kind of signal the 4093 would like to use, but, not in a reliable way.
Placing a comparator, with variable threshold, in between the amp & the 4093 should get you something more like an oscillation on top of the input signal, kind of a crude waveshaper.
corex
PostPosted: Sat Sep 04, 2010 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I put a diode in there between the amp and the 4093, but it made no difference. Update: That's not completely true. With the diode in place, if R7 is connected to +9V, connecting the amp circuit to that leg of the 4093 no longer stops the oscillator.
I'm not sure about your comparator idea. It might be worth a shot. One thing I notice is that if I adjust the gain of the amp section just right, only the peaks of the audio come through the gate, which leads me to conclude that I'm hearing the level of the Schmitt trigger, and that that leg of the gate must be going on and off. That doesn't necessarily mean it's getting a clean signal, but it's hard to understand the logical behavior. (Then again, it's hard to understand the logical behavior when you leave a leg floating, too.)
Top Top
PostPosted: Sun Sep 05, 2010 12:48 am    Post subject: Reply with quote  Mark this post and the followings unread
That opamp circuit is really complicated to just get the level loud.
A really easy way is with an LM386. Check this video, it is exactly what you are trying to do:
It is essentially a guitar -> LM386 -> 4093
Check out Tim Escobedo's PWM effect for hints, the requirements for the gate are identical:
A. MAGIC PULSEWAVE ELECTRONICSA MAGIC WHISTLE
corex
PostPosted: Sun Sep 05, 2010 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
That is interesting in that there's a direct connection between the op-amp and the CMOS chip, and the LM386 circuit doesn't have a feedback loop the way that an LM741 or TL071 circuit does.
Unfortunately, I haven't got any LM386 chips on hand. To make matters worse, I currently live in the Middle East, so shipping components from the States can take a really long time.
I'll definitely get my hands on a few LM386s at some point, but for now I would greatly prefer to get something working with the LM741s and TL071s that I have on hand.
DGTom
PostPosted: Sun Sep 05, 2010 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
The 386 is actually an amp-on-a-chip, its designed to drive a speaker! The genius of that cct. is the amp is smashing the guitar signal into something the logic gates can understand.
Which is why I suggested a comparator with your op-amps. Having the pre-amp (what you have now) & the analog to digital conversion (the variable threshold comparator) as seperate elements actually has another benefit; you can mix all 3 signals together.
Stack clean, digital & NAND in a mixer & you have even more options for sonic fun times! But, yeah, I'm a fan of comparators;
http://www.youtube.com/watch?v=0jEodYEdRdw
& the 4093 as waveshaper / filter;
http://www.youtube.com/watch?v=Jn3Uy2zbcLI
YMMV
Top Top
PostPosted: Sun Sep 05, 2010 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Yea, the 386 the way it is set up in that circuit is outputting a very square, smashed, distorted signal. Pins 1&8 tied together basically maxes the gain on the chip.
386 shouldn't be too hard to come by, but hard to say as I've never gone to the middle east. 386 is used commonly in computer speakers, portable radios, portable TVs, and many other common small amplifier situations. It is sort of the "go to" small amplifier chip.
That said, good luck with the op amps.
That 4093 waveshaper/filter in the video sounds great BTW DGTom.
corex
PostPosted: Sun Sep 05, 2010 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, so I built a comparator based on this one:
that I found here: http://www.swarthmore.edu/NatSci/echeeve1/Class/e72/E72L2/Lab2%28OpAmp%29.html
I switched it around so that it's non-inverting though (otherwise silence activates the oscillator). Definitely seems like it's doing something now. The oscillator seems to gate on the input, more the way that I imagined it.
I need to do some recording of the various signals so that I can inspect them (Audacity is the poor man's o-scope), but I think that's got it. Thanks, DGTom.
Your Proto Squelch video has some particularly neat sounds. I dig it.
DGTom
PostPosted: Sun Sep 05, 2010 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Replace R1 & R2 with a pot, dunno if R3 is needed in an op-amp comparator, pretty sure thats specific to the LM311 etc. comparators.
This illustration is a good example of what we're looking for;
but, with a variable threshold, not a fixed 2.5Vs you have more scope for picking up the usefull parts of your audio signal.
or you could go crazy, set-up a string of 4 comparators & drive 4 4093 oscillators Twisted Evil
corex
PostPosted: Sun Sep 05, 2010 9:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Using a pot for the voltage divider is a great idea. Thanks!
I'm not sure if I really need four signals, but I do have some TL074's handy... I could at least breadboard it...
corex
PostPosted: Wed Sep 22, 2010 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Well my comparators built around the TL071 didn't seem to work quite right, and the gain stages I built with the TL071 also never quite worked right. I don't have a scope and so it's difficult to analyze the problems. I suspect that powering them from a 0V and 9V supply (with a reference at 4.5V) coupled with the fact that they don't amplify rail-to-rail might be the root of the trouble, but I can't really confirm that. I gave up and put this aside.
Last week I got a couple LM311s (but forgot to look for LM386s, alas), however while the LM311 works fine for the CMOS circuits (for example, a 40106 oscillator can run through it almost transparently), given input from the Speak & Math, nothing happens. So I put that aside too... no way to really see the problem or do anything more than guess.
Then last night I was flipping through Nic Collins' book and I saw pretty much exactly the input circuit I need... a gain stage based on the 4049 inverter. I've got a few 4069s, so I tacked together the circuit with one of those really quick. It works great!
Finally some success. Running arbitrary audio into CMOS gates is now a reality for me, and it sounds uniquely horrible. Sweet!
Here's some guitar through a 4093 oscillator (tone changes by oscillator pitch). Pardon my poor playing:
http://phlake.org/lunetta/STE-099%20-%20guitar%20through%204093%20osc.mp3
Here's the Speak & Math through the 4093:
http://phlake.org/lunetta/STE-101%20-%20speak%20&%20math%20through%204093%20osc.mp3
stolenfat
PostPosted: Fri Sep 24, 2010 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
what are your guy's feelings towards running op-amp's out put through a schmidt trigger to square it up before slamming it into the 93'?
would that help?
http://circuitgrizzly.awardspace.com
Niio2
