Simple OSC for a Bassdrum-Synth
Page 1 of 1 [8 Posts]
metal_head_82
PostPosted: Thu Aug 19, 2010 6:16 am    Post subject: Simple OSC for a Bassdrum-Synth Reply with quote  Mark this post and the followings unread
Hey there,
I'm currently trying to build a little bassdrum-synth.
My problem is that I didn't find a VCO which gives me a square and a triangle out.
So my Idea was to build my own circuit. It consists of a simple OPamp-based circuit and a n-channel FET (BF245A).
I have attached a schematic of the basic OSC-circuit so that you know what I mean. I planned to add that BF245 in Series with R (the same way Ray Wilson did in his WSG mods, see here: http://www.musicfromouterspace.com/analogsynth/YOUR_FIRST_SYNTH/WSG_Reborn/WEIRDSOUNDGENERATORREBORN.php?page=WSG )
The Problem is, that the pitch-change is pretty small and the FET seems to change my wavesforms. Now I ask myself what I'm doing wrong... Perhaps you guys could point me in the right direction.
Thy in advance.
 Filesize:  2.44 KB
 Viewed:  5880 Time(s)
"I don't care much about music. What I like is sounds."
Juno60
PostPosted: Mon Aug 23, 2010 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey metal_head,
if you need a simple VCO with Square and Tri Output you should have a look at Ray Wilsons WP20. You can find here:
http://www.musicfromouterspace.com/analogsynth/WP20/WP20_PG1.html
It offers a linear controlled core build around a LM3900 OpAmp. You can get the 3900 cheap at "Reichelt". The waveform-switch can be substituted by two outputs for tri and square waveforms or a simple mixer.
Grüße aus dem Ruhrpott,
Juno
Greetings from Germany,
Chris
metal_head_82
PostPosted: Tue Aug 24, 2010 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks very promising!
I came up with something else while doing some research.
But it became another project Wink
My current vco design offers 1V/Oct CV inputs, adjustable PW AND a square sub-octave. As it offers only saw and pulse it's better to pit it into some sort of modular device... still thinking about that.
But I'll try the WP-20 VCO as soon as I'm back home. I wonder if I could substitude the LM3900 with another OPA. I got a bunch of TL07x lying around here.
Thx for the answer.
Greetings from Bavaria.
sonicwarrior
PostPosted: Wed Oct 20, 2010 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
metal_head_82 wrote:
My current vco design offers ...
Willing to share it?
There is an asian (japanese?) guy somewhere on the web who makes incredible small circuits and solders them directly together.
metal_head_82
PostPosted: Wed Oct 20, 2010 4:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll have to look for the drawings... Until now I didn't have the time to clean them up. These are just hand-drawings AND I didn't have the time to build it.
So as soon as I find the Papers I will post them as UNTESTED here. I'll try to post them today.
PickNick
PostPosted: Wed Oct 20, 2010 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
hi!
you can use NE566 sound chip for square and triangle.
check Thomas Henry's Electronic Drum Cookbook.
Allow theex.nl
metal_head_82
PostPosted: Wed Oct 20, 2010 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
So I ran some basic simulations a while ago and they looked very promising.
But again I post these hand drawn schematics as untested.
The VCO has an adjustable PW for the SQR Out.
It's the trim-pot at the upper right opamp. This acts as a comparator to convert the SAW into a SQR...
This is the basic VCO.
As I finished the drawing I was pretty sure that I have seen something similar before...
 Filesize:  29.53 KB
 Viewed:  219 Time(s)
This is the basicexpo-converter. Again the basic simulations were very promising
 Filesize:  76.79 KB
 Viewed:  208 Time(s)
richardc64
Audio files: 26
PostPosted: Thu Oct 21, 2010 9:55 am    Post subject: Re: Simple OSC for a Bassdrum-Synth Reply with quote  Mark this post and the followings unread
You need to put the FET in parallel with R, not in series. Make R a pot for Initial Freq and the FET CV will be sweep/modulation.
