the_ufo
cloudscapes
Posted: Sun Nov 14, 2010 8:14 pm Post subject:
maybe I'm missing something
I'm looking at an analog filter. _________________ Sonic Crayon DIY effects lab |
yusynth
Posted: Mon Nov 15, 2010 6:14 am Post subject:
As stated by cloudscape it is a basic 6dB/octave ANALOGUE lowpass filter. The triangular component with the + and - symbols is an operational amplifier (stuffed with BJT transistors). The cut off frequency is set by R1 and C. F = 1 / (2xPIxR1xC) ; However you must be aware that the ratio R1/R2 sets the gain as well. Therefore if you vary the value of R2 to change the cut-off you must change equally R to have a constant gain. The best way to do this is to use a dual gang pot for R1 and R2.
By the way forget about valves _________________ Yves |
the_ufo
Posted: Mon Nov 15, 2010 5:23 pm Post subject:
awesome, That is what I wanted to know.
I now realize it's an analogue component even though it's made of semiconductors.
If somone could reccomend such a dual-gang pot, i'd appreciate that greatly and defo use it. i've never ordered electronic components before.
w0000000000t, get the soldering iron out! |
DrJustice
Joined: Sep 13, 2004 Posts: 2114 Location: Morokulien
Posted: Mon Nov 15, 2010 7:41 pm Post subject:
the_ufo wrote: | If somone could reccomend such a dual-gang pot, i'd appreciate that greatly and defo use it. i've never ordered electronic components before. |
Since you're in the UK, maybe Maplin is a good place to shop. You can even pop down to your local branch. Hopefully they have these dual gang pots in stock.
Oh, and to electro-music.com
DJ
yusynth
Posted: Tue Nov 16, 2010 2:11 am Post subject:
the_ufo wrote: | I now realize it's an analogue component even though it's made of semiconductors. |
Semiconductors are components, analogue and digital are working modes, analogue circuits can be built with either semi-conductors or valves and digital circuits as well can be built with either semi-conductors or valves. _________________ Yves |
the_ufo
Posted: Tue Nov 16, 2010 5:41 pm Post subject:
brilliant!
thankyou everyone!!
I am finding electro-music.com to be most welcoming!!! |
enomys
Posted: Sun Dec 19, 2010 12:06 pm Post subject:
2nd order lowpass filter |
Hi, just a question... For a 1rst order lowpass filter I can use a double pot to change the cutoff, but if I would like to change the cutoff in a 2nd order lowpass filter? thanks
Simon
yusynth wrote: | As stated by cloudscape it is a basic 6dB/octave ANALOGUE lowpass filter. The triangular component with the + and - symbols is an operational amplifier (stuffed with BJT transistors). The cut off frequency is set by R1 and C. F = 1 / (2xPIxR1xC) ; However you must be aware that the ratio R1/R2 sets the gain as well. Therefore if you vary the value of R2 to change the cut-off you must change equally R to have a constant gain. The best way to do this is to use a dual gang pot for R1 and R2.
By the way forget about valves |
yusynth
Posted: Sun Dec 19, 2010 12:18 pm Post subject:
Re: 2nd order lowpass filter |
enomys wrote: | Hi, just a question... For a 1rst order lowpass filter I can use a double pot to change the cutoff, but if I would like to change the cutoff in a 2nd order lowpass filter? thanks
Simon
It depens very much on the type of 2nd order filter you intend to use. If you intend to cascade two of the above circuit th'at's a bad idea because you would need a quad pot for this. If you use a Sallen and Key or another topology such as those explained in detail here http://focus.ti.com/lit/ml/sloa088/sloa088.pdf _________________ Yves |
enomys
Posted: Mon Dec 20, 2010 4:32 am Post subject:
thanks, i just checked the second order Sallen and Key, but my question still remians, I don't know to change the cutoff....
Simon
yusynth wrote: | enomys wrote: | Hi, just a question... For a 1rst order lowpass filter I can use a double pot to change the cutoff, but if I would like to change the cutoff in a 2nd order lowpass filter? thanks
Simon
It depens very much on the type of 2nd order filter you intend to use. If you intend to cascade two of the above circuit th'at's a bad idea because you would need a quad pot for this. If you use a Sallen and Key or another topology such as those explained in detail here http://focus.ti.com/lit/ml/sloa088/sloa088.pdf |
the_ufo
Posted: Mon Dec 20, 2010 12:30 pm Post subject:
Yusynth explained how to do it for a first order filter... I dont know its applicable to a 2nd order. I haven't had chance yet to play around with this myself, so I can't really help. |
