Joined: Jan 31, 2003 Posts: 18197 Location: Durham, NC
Audio files: 212
Posted: Wed Feb 23, 2005 9:47 am Post subject:
Case for the G2X? |
Anyone know of a good light hard case for the G2X? _________________ --Howard
my music and other stuff |
jamos
Joined: Jun 01, 2004 Posts: 514 Location: Eugene, Oregon, USA
G2 patch files: 41
Posted: Wed Feb 23, 2005 10:39 am Post subject:
I had one made for my G2 for a pretty good price, at http://www.groovenutcaseco.com . I need to get another one now :') |
Audio files: 212
Posted: Wed Feb 23, 2005 10:53 am Post subject:
I get:
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
You have to remove the period from the end of the URL. |
Audio files: 212
Posted: Wed Feb 23, 2005 10:56 am Post subject:
Thanks, I edited Jim's message so it will work... Is that where you got your case for your G2? _________________ --Howard
Posted: Wed Feb 23, 2005 11:12 am Post subject:
I did a bit of thinking about cases lately and one thing that occured to me is that those little suitcases that many people use are a bad idea because those will obscure your hands to a audience. This means you get the main disadvantage of a laptop without any of the advantages that go with it.
Traveling with more than two objects to carry is also a very bad idea, IMHO, and I resolved that that means that cases are more about protection then they are about making something easy to carry.
At least that´s what I resolved after my experiments with my "Nord protector". Perhaps it´ll chip some time off somebody else´s considerations... _________________ Kassen |
Audio files: 212
Posted: Wed Feb 23, 2005 11:24 am Post subject:
Well, when you have a synth that costs more than $2000 it makes sense to protect it. But I don't want a case I can't lift. Many cases are made with thick plywood. Good protection but very heavy.
I'm worried about the Clavia 61 key gig bag. Does that protect the controls and jog wheel adequately? It's probably OK for carrying around in my car, but on a plane I'd be pretty worried. _________________ --Howard
Posted: Wed Feb 23, 2005 11:37 am Post subject:
Yes, those are my concerns exactly. The problem with the G2X is that´s it´s probably too large to go into a suitcase, even a large one. This means that a case for it must be hard enough by itself to stand airtravel which basically means it must be hard enough to drive over with a car, light enough to cary next to some other bag with clothes+laptop and not look expensive or usefull (or the airplane people will steal it).
That does not leave a lot of materials that you can work yourself! Perhaps a aluminium box, reënforced with steel corners and sides and with a styrofoam inside cut to be shaped exactly to fit might do? that´s quite a few hours of work though. _________________ Kassen |
Audio files: 212
Posted: Wed Feb 23, 2005 11:46 am Post subject:
Too much work for me... _________________ --Howard
egw
G2 patch files: 8
Posted: Wed Feb 23, 2005 12:28 pm Post subject:
mosc wrote: | Too much work for me... |
I don´t blame you, it´d require a rather large toolset too. Problem is, I don´t see that many other options. There are nice fiber-based plastics but you can´t work those yourself and a wooden case of that size will not be fun to stroll around with.
Perhaps match up a off-the-shelf sollution with extra padding shaped like the knobs and jogdial and the addition of a extra wheel so you only need to lift half the weight?
You could of cource also join the "I want a tabletop model" crew, whine untill Clavia gives in, then cary that and put a midi keyboard in your tech rider? hmmmmm. :¬) _________________ Kassen |
Posted: Wed Feb 23, 2005 6:53 pm Post subject:
I have an SKB case, injection molded (very light weight). Since I have the G2 (no "X"), the 3 octave keyboard is impossible to find a fitted case that protects well. So the next size up (I think it IS made for a 5 octave board) holds both my G2 and MPC1000 very securely. Also, it fits very well on the typical "X" type keyboard stand, which allows me to use the case as a table for my MPC & laptop. So, I travel with even less.
Picked up for soemthing ~$150. Small price to protect $3000 in gear. |
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Wed Feb 23, 2005 8:23 pm Post subject:
jksuperstar, did your skb case come with foam padding on the inside? |
Tim Kleinert
G2 patch files: 236
Posted: Thu Feb 24, 2005 2:42 am Post subject:
Kassen wrote: Quote: | and a wooden case of that size will not be fun to stroll around with. |
Aww, it's actually not that bad at all.
I let a good case-builder make specially fitted heavy-duty flightcases for my G2Xs (indispensable when touring), and find lugging them around not strainful in any way.
But maybe laptop-musicians have a different weight-tolerance than Fender-Rhodes-players (like yours truly). |
Posted: Thu Feb 24, 2005 8:47 am Post subject:
Zynth: There's a dense fitted "puzzle piece" foam on the bottom half, which protects the bottom, and can be customized (& re-customized) to fit around the keyboard by adding/removing the interlocking foam pieces. Then there's a few strips of foam...like the egg-crate stuff, which holds the keyboard down when the top is closed. At first I didn't think the egg-crate foam was very good, but I like it now. There's plenty of room for my gear & extra cables in that box. |
Posted: Fri Feb 25, 2005 4:04 am Post subject:
shoshin wrote: | But maybe laptop-musicians have a different weight-tolerance than Fender-Rhodes-players (like yours truly). |
I don´t know, i´m currently restucturing my live stuff but i used to have a 5Kg laptop bag with a 20 to 25 Kg roling suitcase. I can travel with that, I can lift it to some fifth floor crash-space through tight stairs, I can even feel a perverse sense of pride if the local bellboy whom I´d rather not have touch my stuff has trouble moving the thing.
I´ve also done enoug of that to realise it´s simply not a good idea.
I wish I would´ve gone with my "micro modular + roland pma-5" plan.
