simple modulation of sndbuf.pos
Page 1 of 1 [4 Posts]
frank discourse
PostPosted: Fri May 13, 2011 9:22 pm    Post subject:  simple modulation of sndbuf.pos Reply with quote  Mark this post and the followings unread
Hey everyone, can someone direct me to an example of how to modulate sndbuf.pos? I am at an early stage of learning ChucK and cant work it out from the (0>p>.samples) parameter definitions int the manual.I am still at the stage of copying and modifying from the exampes folder.I used to be ok at actionscript in Flash but it has been a few years, my main platform for audio is Synthedit.
Thanks, frankie_d.
Audio files: 216
G2 patch files: 319
PostPosted: Sat May 14, 2011 5:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Moved this to the ChucK section, thats where ChuXperts hang out, hopefully Wink
alexbarbed
PostPosted: Thu May 19, 2011 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello frank
I suppose someone had better answer you...
how do you mean, modulate it? scrub backwards and forwards through the sample maybe? or put vibrato on it? or something else?
alex
Inventor
Audio files: 267
PostPosted: Thu May 19, 2011 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think LiSa is what you want perhaps.
Les
