TB-303 VCF
Page 1 of 1 [8 Posts]
furio
PostPosted: Mon Jul 11, 2011 11:54 am    Post subject: TB-303 VCF Reply with quote  Mark this post and the followings unread
Is it possible to modify the Minimoog VCF or the EMS VCS3 VCF, to get sounds like TB-303?
forshee
PostPosted: Mon Jul 11, 2011 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't built either but the diode ladder is way closer to what you want I think. The synthacon might also be a good choice for that type of sound. Any slight modifications probably won't radically alter the sound. You want to start with something that sounds like what you want.
furio
PostPosted: Wed Jul 13, 2011 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
forshee thanks!
I own three DIY TB-303 VCO's (1:1 clones) and a Doepfer A-103 VCF6 (18dB LP) ... I would like to find a better filter ... I also have a GCS Syntacon VCF, but I do not really like it ... I'll try to build a Yusynth Syntacon VCF
yusynth
PostPosted: Wed Jul 13, 2011 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
furio wrote:
forshee thanks!
If you like cgs' synthacon VCF then chances are the Yusynth's Syntacon VCF, because they are basically the same. The EMS filter might be a closer match of the TB303 filter because both are diode based (thought the TB303 uses tansistors wired as diodes) and are 18dB/octave low pass filters.
Yves
furio
PostPosted: Wed Jul 13, 2011 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Yves!
I have a EMS VCF and sounds very nice vith all VCO's ...the only problem is the sourcing of the polarised 16uF/50V caps, I have found only 16uF/400-500V to big caps... so I have installed a 22Uf. which malfunctions can arise by using the 22uF instead 16uF (C15)? I am certainly going to build one more EMS VCF! Though without question I am still going to try and find a TB303 filter.
yusynth
PostPosted: Wed Jul 13, 2011 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
furio wrote:
Thanks Yves!
22µF instead of 16µF is alright. No malfunction to expect. This is only an AC coupling for the output buffer stage.
Yves
wmonk
Audio files: 12
PostPosted: Sun Jul 17, 2011 5:11 am    Post subject: Re: TB-303 VCF Reply with quote  Mark this post and the followings unread
I know this is the YuSynth forum, but people have got close to that sound using the Oakley Diode SuperLadder VCF. Cool
http://www.oakleysound.com/super-d.htm
Weblog!
Kits for synthesiser modules in Europe
furio
PostPosted: Sun Jul 17, 2011 6:59 am    Post subject: Re: TB-303 VCF Reply with quote  Mark this post and the followings unread
Thanks wmonk !
It is good to know, though is it possible to configure them as 18dB?
I will be buying one or two Kits from you seeing that I cannot match the transistors.
