PIC based CV Quantizer (now with variable modes)
Page 3 of 3 [51 Posts]
Goto page: Previous 1, 2, 3
Clack
PostPosted: Thu Sep 29, 2011 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD wrote:
Could someone explain the whole AGND / GND thing to me? I'm not getting the explanation in the documentation at all... I assume it is like this...
with 15V source, use (+15V & AGND)
with 5V source, use (+5V & GND)
is that right?
I'm now wondering which GND/AGND I use to ground the sockets, or is this intended for banana jacks?
If someone could make a simple wiring diagram that would be great, as I'm not translating this from text at all.
Thanks in advance Smile
A normal reason for GND and AGND (analogue ground) is because you want to separate the ground planes for analogue sections and digital sections. This is theoretically to reduce interference - they do directly connect - usually with a link near the power source. This is because digital circuits swing quite hard (weeeee!) between the rails and it intermittently feeds current into GND - along thin PCB traces (with slight resistance) this can create noise each time a digital circuit moves (i think) which is normally at audible speeds! it sounds like clicking - computers suffer with this loads - I get clicking through my speakers when I move my mouse.
In this circuit all the digital stuff is on 5v so you are right. Use AGND for the jacks.
Clacktronics.co.uk
