  bingsatellites Mostly Ambient
Steiner Synthacon VCF
Page 3 of 3 [64 Posts]
Goto page: Previous 1, 2, 3
-minus-
PostPosted: Thu Aug 18, 2011 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
well I am now on the 5th board layout and I have had no luck Crying or Very sad . I'm unsure what I am doing wrong here. I have literally copied onto stripboard, the schematic exactly as it is on the CGS site. Are these transistors so hit and miss? Do I need a bunch of them to test and see which combination works best? I'm getting very little sound from the output, and I only get sound if I bypass the 47K resistors on the HP BP LP inputs. I just cant work this out... It IS haunting me now and I can't let it go! I have checked for solder bridges etc. I have reflowed all solder on the reverse of the board. scratch
Last night I had a go at building this on perf. I had the opamp section working fine. Then I built the transistor section to the right of the ladder. I hooked up the ladder and CV section on my breadboard to this and it worked fine. Then I soldered the rest of the circuit and it wouldn't work. Confused
I've ordered some more 2N2222's but they wont be in until next week. If this keeps failing I'll get a couple of boards from Ken and try that. It's not that I don't want to support CGS! I just like the challenge of stripboarding and would like to build my synth that way. I'll continue with this... I cant give up on this now!
-minus-
PostPosted: Sat Aug 27, 2011 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finally! After one more go at this, I have a working board! Very Happy
I had to basically cut a piece of stripboard EXACTLY in the pattern of my breadboard: 8 columns side by side of 5 hole strips, 20 strips deep. Then it was just a matter of replicating my working breadboard....
I'm a bit annoyed I couldn't figure out why the other ones wouldn't work, but I do have a working filter so I should be happy.
The sun is rising again and I'm fully tanked up on coffee.... so I might just push my luck and solder another one for good measure!
-minus-
PostPosted: Sun Aug 28, 2011 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just got a second filter working! Very Happy Had a bit of trouble at first. Was not getting any sound in low pass mode.... BUT, I reheated the solder around that area and success!
See, this is all part of the curse... talking to oneself! Laughing You have been warned!
otherunicorn
PostPosted: Sun Aug 28, 2011 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Talking to your self is one thing - expecting an answer is another!
http://www.cgs.synth.net/
Mongo1
PostPosted: Fri Dec 23, 2011 10:16 pm    Post subject:
Subject description: Another one bites the dust
Well, it appears another woolly mammoth has wandered too close to the tar pit.
I'm stuck in Synthacon hell, believing with all my heart that these two miserable little transistors have everything they need to thrive, but no dice.
Symptoms- sorta filtery response on lowpass and highpass, but very low output. Insert a signal into BP, and its about 10 times louder. "Q" pot does absolutely nothing. Op Amp stage seems to function ok. CVs seem to do about what I'd expect.
I've put a 2K trimmer in place of the 2K2. I'm using the 3906 and 3904 transistors in the amplifier, and 2n2222s in the filter core. I've used trannies from these batches in other projects with the no problem, so I don't think it's the reverse pin thing. I did insert the 04 and 06 into the board backwards.
DC voltages look reasonable according to the diagram in this thread, but I'll take another look at that tomorrow.
Here's a couple of weird symptoms:
I put a signal in the LP input, I touch a scope probe to trace that connects the collector of the first tranny to the base of the other. When I do that any sound I have coming out stops, and stays off as long as I have the probe there.
Also - when I first turn the system on, I can hear something that sounds much more 'Q'y and but that fades in to the dull sound I normally have.
I just can't believe that a board this simple is causing me so much grief.
If anyone has any ideas I'd sure appreciate it.
Thanks
Gary
otherunicorn
PostPosted: Fri Dec 23, 2011 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
The "fadey" business suggests an electrolytic is involved. Check that your 0 volt line isn't broken somewhere. I've had similar sorts of things happen in other modules with a broken 0V line.
You may have broken a track or lifted a pad on the PCB. Single sided boards do not like a lot of heat.
Ken
Mongo1
PostPosted: Sat Dec 24, 2011 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks - I'll check that....
Gary
Paradigm X
PostPosted: Thu Jan 05, 2012 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Could you share your layout please minus?
Im a big fan of stripboard, and been meaning to try a layout at this, but quite new at stripboard layouts so always helpful to see others.
Cheers, Ben
roglok
PostPosted: Sun Jan 15, 2012 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally got my Synthacon stripboard working. I had to substitute the 2N2222A/2N2907 with 2N3904/2N3906 to get an active full range on the frequency pot. Filter sounds great!
But... I have one problem:
On the last quarter towards 15V end (filter open), the frequency pot becomes really noisy, as if there's dust on the carbon track. This happens only when actually moving the wiper. I'm using 16mm Alpha pots and have tried several of those with the same result.
Not sure what this issue related to... Are 15V too hot for my pots or is it something else?
otherunicorn
PostPosted: Sun Jan 15, 2012 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've never heard of the frequency pot doing that. The resonance pot is known to do that in the earlier designs.
15V is not too hot for the pot. If you have built it as per the diagram, there is a low pass filter (220k and 1uF) that should prevent any such pot noise from getting through.
roglok
PostPosted: Sun Jan 15, 2012 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
aaah, thanks ken! that was the hint i needed. i accidentially put a 33k instead of a 220k after the cv input. now the noise is gone! i only have to recalibrate the thing. Smile
stefanosdan
PostPosted: Sun Jul 29, 2012 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
haima wrote:
thanks for the reply ken. it seems all that my PCB (version 1.3) of the filter is correct DC wise.. there's just some problem with the AC signal part. pretty sure it's not the trimmer - i tried all positions and even disconnecting it, no change.
i've checked repeatedly for bad solder joints and track lift off problems - couldn't find anything. there MIGHT be something there, but i couldn't find it.
is your pcb version 1.3 new? has anyone else successfully built one? i couldn't see any errors in the layout but i've only traced parts of it while looking for the problem.
i've actually got a problem with my veroboard version too (i seem to be cursed with this filter! Mad ). the filter works perfectly apart from a very loud hum/buzz that seems to be picked up via the LP input. it sounds like a disconnected ground wire kind of buzz, but you can filter the buzz completely away with the frequency cut-off knob all the way down.
> it makes no difference if all the inputs are shorted to ground - still hums just the same.
> all the audio i/o wires are shielded (shield terminated at only one end).
> the entire pcb is enclosed in a grounded aluminium hobby box (i thought it might be EMI)
> it doesn't seem to be a ground loop with other modules - it still hums in complete isolation.
it's driving me a little crazy... anyone got any ideas? anyone had a similar problem with this filter?
I have EXACTLY the same problems... Has a solution been found?
chguigoz
PostPosted: Fri Sep 07, 2012 10:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
I have the same problem of hum. My eurorack have two power supply, one well filtered and the other not. The hum disapperead when my filter is connected to the good one. Check your power supply and be careful to avoid ground loop, this filter is very sensible.
MuBase
PostPosted: Sat Apr 27, 2013 9:05 am    Post subject: Ken stone Steiner VCF fix.
Subject description: Happy to say...
Just had a careful look at this forum post on Ken stone's Steiner VCF. After having one for 2 years now to put inside my WSG Redux I haven't been able to get the resonance control doing anything. It was changing the gain slighty but that is all.
I had another look today following the idea there might be a bad trace on the PCB. There was!
In between the middle resonance pot connection and the 10uF capacitor's - terminal . after having connected the cap's - terminal straight up to the pot connection I got a very lovely resonance. Smile
I am using a 2.2K resistor for the 'q' which barely rings but I might try a lower value for oscillation. absolutely beautiful filter. If I plug 3 of the WSG oscillators into the three different filter inputs (LP,HP,BP) I get some very nice panning effects when the cutoff is VC'd by the LFO...
If you want to see the WSG redux in action theres a short vid here:
http://www.youtube.com/watch?v=z22abVAWuSw
but it was filmed before the Steiner VCF fix..
All the best . Razz
Steve.
There's a crack in everything...Thats how glue manufacturers make a living.
