wxl
Posted: Fri Apr 20, 2012 2:25 am Post subject:
presenting the many sounds of wxl Subject description: aka Brownian e/Motion(s), Brownian Motion, The ERNIE 4, dj x∃n |
- howdy, i'm Walter Lapchynski.
- i'm from the sister city to the inspiration for Bart Simpson's home.
- on IRC, i'm wxl.
- as Brownian Motion, i make all sorts of racket from harsh noise to drone. often times my work is subversive, but rarely in an obvious way.
- as a member of The ERNIE 4, i help to create a dense field of all sorts of noise and ambient.
- occassionaly, as dj x∃n, i play Creative Commons electronica. it's been a while. a long time ago, i used the name to mix electronica, industrial, goth, and even classical. at the same time.
- not surprisingly, i'm an geek and worse yet, an open source one.
- i use Linux.
- i have a wee netlabel called Brownian e/Motion(s) which has mostly put out Brownian Motion and The ERNIE 4.
- there are two compilations that i have put out-- one revolving around contact microphones and one that has to do with open source software.
- two more volumes of this open source compilation are planned-- one with 100% open source used and a similar one with open source hardware, too. please get in touch regarding contributions!
- have a nice day.
_________________ Brownian Motion happens. |
EdisonRex
Joined: Mar 07, 2007 Posts: 4449 Location: London, UK
Audio files: 168
Posted: Fri Apr 20, 2012 4:10 am Post subject:
... _________________ Garret: It's so retro.
audiodef
Audio files: 27
wxl
Posted: Sun Apr 22, 2012 11:32 pm Post subject:
hey peeps. yep, i use Linux for my audio everything. listening, producing, mixing, broadcasting, databending, you name it  _________________ Brownian Motion happens. |
audiodef
Audio files: 27
onewayness
Joined: Jun 16, 2011 Posts: 107 Location: Erie, PA, USA
Posted: Tue Apr 24, 2012 9:46 am Post subject:
Yaaaaaay, more Linux geeks in the house.
Hi Walter.
adh _________________ handmade music for machines | onewayness.com |
wxl
Posted: Fri Apr 27, 2012 10:06 am Post subject:
lubuntu over here but i also like me some arch. _________________ Brownian Motion happens. |
audiodef
Audio files: 27
Posted: Sat Apr 28, 2012 9:38 am Post subject:
Arch is nice. I wish I had a spare machine to run it on and play with it. _________________ Audiodef
Synthetronica
Gentoo Studio |
wxl
Posted: Sat Apr 28, 2012 11:32 am Post subject:
you don't need a spare machine to play with other distros; that's what virtual machines are for  _________________ Brownian Motion happens. |
audiodef
Audio files: 27
Posted: Tue May 01, 2012 10:41 am Post subject:
Heh, that's true! I guess what I need is some spare time for it. If I could only snag a tardis along with a VM, I'd be set for life. _________________ Audiodef
Synthetronica
Gentoo Studio |
onewayness
Posted: Thu May 03, 2012 8:18 am Post subject:
kxstudio for me, or crunchbang if I'm traveling light.
Acoustic Interloper
Joined: Jul 07, 2007 Posts: 1508 Location: Berks County, PA
Audio files: 26
Posted: Fri May 04, 2012 9:03 am Post subject:
| audiodef wrote: | | If I could only snag a tardis along with a VM, I'd be set for life. |
One of my goals for planetarium visuals is to generate a Tardis  _________________ "Time is a ruler across the knuckles of eternity."
Dale Parson
"Just say no."
Nancy Reagan |
audiodef
Audio files: 27
Posted: Fri May 04, 2012 11:40 am Post subject:
| Acoustic Interloper wrote: | | audiodef wrote: | | If I could only snag a tardis along with a VM, I'd be set for life. |
One of my goals for planetarium visuals is to generate a Tardis  |
Just have K-9 emit a tardis video from his nose. _________________ Audiodef
Synthetronica
Gentoo Studio |
