That stuff.. the hanging rocks or whatever it is.. ? A Krunkus totem thing? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
No,
not a Krunkus totem. An old ceramic windchime, which just happened to be right in the middle of the picture! I wasn't even aware of it when I took the pic, I was only focussed on the trees! _________________ What makes a space ours, is what we put there, and what we do there.
Ahh... for a moment there it managed to convince me that it was a hanging totem surrounded by trees. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Audio files: 28
Posted: Thu Jun 07, 2012 5:24 am Post subject:
Subject description: Tuesday's transit of Venus
Took this Tuesday early evening with a smallish telescope and a DIY "Funnel Projector". First time I've tried to view/photograph the Sun..I thought it turned out OK.
Venus Transit June 5, 2012
Filesize:
79.25 KB
Viewed:
354 Time(s)
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Thu Jun 07, 2012 9:26 am Post subject:
Nice! That is the best projected image photo of the transit that I have seen posted so far. It’s a better view than I got looking directly through 7x50 binoculars with a shade number 14 filter plate. _________________ varice
Audio files: 172
Posted: Sat Jun 09, 2012 1:29 pm Post subject:
After spending a couple of weeks sorting legos around here (we have a lot), I had a couple days off and between doing paperwork (which was sort of the point of the days off) and fighting the paperwork, I worked on a Lego clock (well, 3 versions of the clock so far) and having got the 3rd version to work with an electric motor, decided to try to make an escapement out of Legos.
I chose a long clock version because (a) I know how they work and (b) they are reasonably efficient (slow) tickers and take less energy to operate. Which was a concern when using Lego Technic as the gearset.
anyway, here's the escapement.
Front of the escapement. The escape wheel is from a Bionicle, some kind of saw thing. 12 teeth so 24 seconds per rotation. Usable.
Filesize:
1.99 MB
Viewed:
176 Time(s)
The gearing. 5 x 5 x 1.667 means the winding drum turns once about 15.5 minutes. Unfortunately, gearing down further just results in no force to drive the escape wheel.
Filesize:
2.02 MB
Viewed:
172 Time(s)
Winding drum, and another view of the gears. The free shaft there is the minute wheel drive, that's turning once a minute.
Filesize:
1.95 MB
Viewed:
168 Time(s)
The pendulum, and the weight, which is a sock with some Bocce balls in it (760g apiece) and some socket wrenches to get it up to 2.4kg.
Filesize:
2.25 MB
Viewed:
172 Time(s)
Joined: May 16, 2005 Posts: 8933 Location: Birmingham, England, UK
Posted: Mon Jun 11, 2012 1:52 pm Post subject:
Wonderful clock Paul! _________________ ACHTUNG!
Posted: Mon Jun 18, 2012 9:57 am Post subject:
