chucK Meditation
Page 1 of 1 [4 Posts]
TommyX
PostPosted: Mon Jun 18, 2012 7:36 am    Post subject: chucK Meditation Reply with quote  Mark this post and the followings unread
my first try witch chuck! sounds meditative ->
Code:
Blit s1 =>  ADSR f1 => JCRev r1 => Gain g1 => dac.left;
Blit s2 =>  ADSR f2 => JCRev r2 => Gain g2 => dac.right;
Blit s3 =>  ADSR f3 => JCRev r3 => dac;
SinOsc s => Gain g4 => dac;
SinOsc t => Gain g5 => dac;
SinOsc u => Gain g6 => dac;
0.05 => g4.gain;
0.05 => g5.gain;
0.10 => g6.gain;
s.freq(Std.mtof(53));
t.freq(Std.mtof(41));
g1 => Gain feedback1 => DelayL delay1 => g1;
g2 => Gain feedback2 => DelayL delay2 => g2;
.25::second => delay1.max => delay1.delay;
.50::second => delay2.max => delay2.delay;
.7 => feedback1.gain;
.7 => delay1.gain;
.7 => feedback2.gain;
.7 => delay2.gain;
.2 => s1.gain;
.2 => s2.gain;
.5 => s3.gain;
.3 => r1.mix;
.4 => r1.gain;
.1 => r2.mix;
.4 => r2.gain;
.1 => r3.mix;
.4 => r3.gain;
f1.set( 05::ms, 03::ms, .5, 125::ms );
f2.set( 05::ms, 03::ms, .5, 25::ms );
f3.set( 05::ms, 03::ms, .5, 250::ms );
[29,41,36]@=> int rhythm[];
while( true )
    Std.mtof(60) => s1.freq;
    Std.mtof(53) => s2.freq;
   for (0 => int i;i<3;i++){
      Std.mtof(rhythm[i]) => s3.freq;
      Std.mtof(rhythm[i]) => u.freq;
    Std.rand2( Std.rand2(1,5), Std.rand2(1,05)) => s1.harmonics;
    Std.rand2( Std.rand2(1,5), Std.rand2(1,05)) => s2.harmonics;
    Std.rand2( Std.rand2(1,5), Std.rand2(1,24)) => s3.harmonics;
   f1.keyOn();
   f2.keyOn();
   f3.keyOn();
   120::ms => now;
        f1.keyOff();
   f2.keyOff();
   f3.keyOff();
try mdifying the bass variable sequential to "38","36","34","33","34","41";
Hey most of the units do the same so how can i reuse them?
Blit s2 => f1 => r1 => g1 => dac.right; doesn't do it..
hell of a mess..
GrandJu
PostPosted: Wed Jun 20, 2012 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tommy and Welcome to ChucK welcome
There is an error in your script line 70. It seems you forgot to disable HTML or somthing like that.
I m not sure to understand your question but even if your UGen have the same functionnality they are not part of the same audio path, so they are not processing the same audio signal.
Have fun
Ju
TommyX
PostPosted: Mon Jun 25, 2012 7:20 am    Post subject: Thanx Reply with quote  Mark this post and the followings unread
I've corrected it.. Html was enabled. =) Thank You!
mattb
PostPosted: Sun Mar 10, 2013 12:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice patch!
