G1 and Windows XP?
Page 1 of 1 [16 Posts]
JonTerp
PostPosted: Sun May 08, 2005 12:44 pm    Post subject: G1 and Windows XP? Reply with quote  Mark this post and the followings unread
I am considering picking up a micro modular to play around with, and I noticed that on the Clavia site, it says the minimum requirements are Windows 95/98/NT4.0. I'm just wondering would I be able to run it on XP, and if I did, would I have any conflicts or complications. Some feedback right away would be nice, cause the auction is almost up. Thanks in advance.
Jon
diskonext
PostPosted: Sun May 08, 2005 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got a fully working XP and MM setup here. No problems.
-diskonext
:wq
diskonext
PostPosted: Sun May 08, 2005 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
And good luck on the auction, the MM is sweet little box!
-diskonext
:wq
JonTerp
PostPosted: Sun May 08, 2005 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks diskonext
diskonext
PostPosted: Sun May 08, 2005 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
No problem,
let us know whether you succeeded!
-diskonext
:wq
andy c
PostPosted: Mon May 09, 2005 1:03 am    Post subject: Reply with quote  Mark this post and the followings unread
just remember to run the editor in 'compatibility mode' i pulled out a lot of hair finding that one out.
Andy C
::Now We Are six::
the new album by the glimmer room
out and available now
egw
G2 patch files: 8
PostPosted: Mon May 09, 2005 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I've had no trouble using my micro with XP.
But I don't recall anything about "compatibility" mode. What's that?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon May 09, 2005 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Clicking on the Icon and choosing 'Windows 98 compatibility mode' makes it run more stable or run at all...
Wout
Kassen
PostPosted: Mon May 09, 2005 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Indeed, in my case the editor would only remember what ports to use when in compatibility mode. Just set it, it can´t harm that I know of.
Kassen
cappy2112
PostPosted: Mon May 09, 2005 1:24 pm    Post subject: Re: G1 and Windows XP? Reply with quote  Mark this post and the followings unread
Jon
Same here. I use XP too. I think I had a quirk a while ago, now I'm using Compatibility mode, and it works well.
Many posts come from XP users.
Axiom
G2 patch files: 28
PostPosted: Mon May 09, 2005 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use my micromodular with XP without problems.
see ya
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
Audio files: 116
G2 patch files: 317
PostPosted: Mon May 09, 2005 4:59 pm    Post subject: Re: G1 and Windows XP? Reply with quote  Mark this post and the followings unread
For compatibility mode right click on the editor's executable file, select properties from the popup menu, select the compatibility tab then check "run this program in compatibility mode" and select "windows 98 / windows me"
The editor's executable normally is : "C:\Program Files\Clavia\Modular Editor 3.03\ModularEditor3_03.exe"
Jan.
JonTerp
PostPosted: Tue May 10, 2005 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, now the price has been pushed up to $305, which I'm thinking might be a bit much, especially since there is a G1 rack for the same on ebay right now. Maybe I'll just wait and get my G2 engine.
egw
G2 patch files: 8
PostPosted: Tue May 10, 2005 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
The G1 rack is a steal if you can get it for $300, unless there is something wrong with it.
JonTerp
PostPosted: Tue May 10, 2005 9:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
nope, but it still has a couple days left on it, so my guess is it will still go up alot. What should I expect to pay for a G1 rack? I can never make up my mind, I'm considering a G1 rack over a G2 engine just because I can get it for cheaper, and it has built in controlls.
egw
G2 patch files: 8
PostPosted: Wed May 11, 2005 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
The G1 rack takes a lot of rack space, if that's an issue. The G2 engine will give you the reverbs, delays and sequencer midi out, plus a few other goodies. However with the engine you'll still need an external box to control it. So, it depends on how you want to use it and what other gear you have.
Niio2
