  faux pas quartet and friends Music From Last Thursday
[kind of] OT: WP20 by R.J.Wilson
Page 1 of 1 [20 Posts]
ladislaobiro
PostPosted: Mon May 16, 2005 2:07 am    Post subject: [kind of] OT: WP20 by R.J.Wilson Reply with quote  Mark this post and the followings unread
Hello everybody,
I just finished my first DIY synth: the WP20, an old synth project (back in the 80's) from Ray Wilson...
I'm so happy with the result that I wanted to share a picture with you DIY synth builders.
Here's a picture, bye...
ladislao
 Filesize:  44.04 KB
 Viewed:  6859 Time(s)
PostPosted: Mon May 16, 2005 2:32 am    Post subject: Reply with quote  Mark this post and the followings unread
HEY! It looks great! Those knobs look like those early 80s Roland rack gear knobbies? Shocked Very Happy
Flickr
seraph
Editor
Editor
Audio files: 31
PostPosted: Mon May 16, 2005 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
congratulazioni Exclamation how big is that box Question
The secret of life is honesty and fair dealing. If you can fake that, you've got it made - Groucho Marx
ladislaobiro
PostPosted: Mon May 16, 2005 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much elektro80!
ehm, I don't know about those knobs... they were just the cheapest knobs I've found around Embarassed Very Happy
seraph wrote:
congratulazioni ! how big is that box ?
grazie dei complimenti seraph!!!
the box is about 26cm x 26cm x 9cm wooden frame included... it is an electro-harmonix pedal case for a deluxe memory man analog delay.
the pedal was stolen Crying or Very sad so the box became useless. I was about to build a brand new wooden box for my WP20 when this lonely box came to my mind... Smile
ladislao
ladislaobiro
PostPosted: Mon May 16, 2005 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
here's a complete mini-set of pictures of my project (if it would be too heavy for this forum, please remove the picture and forgive me Smile)...
ladislao
 Filesize:  75.02 KB
 Viewed:  6831 Time(s)
Audio files: 98
PostPosted: Mon May 16, 2005 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice looking synth... Good job.
ladislaobiro
PostPosted: Mon May 16, 2005 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks mosc... really thank you Smile
ladislao
autoprod
PostPosted: Thu Aug 04, 2005 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is a nice design, Lorenzo.
Big thanks for the additional material you added to the WP20 recipee, also. (I had to build one, while waiting for the Sound Lab PCBs. Your new drawings convinced me it was doable. And it was.)
Two questions - perhaps answered elsewhere, but I couldn't find it - (Answering any of these is entirely optional).
1. What's the strength of the Resistor before the (optional) LED?
2. How is the repeat-function ment to work? Mine kicks in now and then, sending a second trigger signal, but turning it on also looses some over-all pitch. So. A bad cap in mine, perhaps?
I also seem to have quite a leak from the LFO to the outsignal. It can be heard, tapping away, when the oscilators are quiet. Also, The VCO leaks through when it's volume is set to zero.
Ah, well. Sorry. It's been a long night.
And thanks to all of you who let the WP20 survive the '80s.
- autoprod
ladislaobiro
PostPosted: Thu Aug 18, 2005 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks autoprod for your comments Smile
I'm happy that my little contribution helped you out...
if you are using a "traditional" LED (like the red ones), I think a resistor of 470ohms should work fine...
I usually mount Blue LEDS but since they work as high intensity light sources, if you don't want them to emitt a strong amount of light you will have to use higher resistance values (like 1K)... it's up to you...
hey autoprod, my electronic skills are pretty limited so these information are coming from the guy at the electronic store near here, so I cannot be completely sure about the reliability of these infos... Wink
as I told you, my electronic skills are pretty limited, so unfortunately I don't have any answer to give you... I'm sorry Sad
ladislao
[/b]
Pehr
PostPosted: Sat Aug 20, 2005 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Is it possible to mod the WP-20 so it runs on +/- 9 V instead of +9/+18 V? Confused
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
dnny
PostPosted: Sat Aug 20, 2005 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
it looks like it runs on two 9V batteries
the batteries are connected in series so in the other end you get (9V+9V) 18V and from the middle you get 9V
daniel
www.koelse.org
flickr: cable porn group
Pehr
PostPosted: Sat Aug 20, 2005 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
yes I know, but I wonder if its possible to run on the same power supply as the SL I'm going to build... Confused
YouTube channel
flickr photostream
dnny
PostPosted: Sat Aug 20, 2005 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry i did´t understand the question in the first place Confused
hmm.. maybe someone knows better but it seems to me that only the noise source is using the 18V all other circuits run on +9V so maybe if you replace the noise source for Ray's "Pink Enough For Me" Noise Generator and you get the sort of pink noise as bonus.
daniel
www.koelse.org
autoprod
PostPosted: Fri Aug 26, 2005 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lorenzo -
Thanks for the input. All information is useful, at this level.
18V?
Blast. I thought it was regular +/- 9V. I hereby declare interest in the above predicament. Mine eats batteries, making it hard(er) to keep in tune. Not to mention the AR loosing sustain (Going instead for an occasional early decay) after an hour of play. I could do well with a power supply, and have started building one, albeit it might seem I didn't do my homework prior to buying parts.
- autoprod
j.frad
PostPosted: Sun May 28, 2006 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I think you could use a dual -9/+9 Volts if you separate the transformers ground and the ouputs ground, then you can wire the -9V as ground, 0V as +9V ,and +9V as +18V.
Please tell me if I'm wrong!
toppobrillo
PostPosted: Sun May 28, 2006 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
all you need is a regular [no need for a CT] power transformer rated at around 22-25 VAC, rectify and regulate that with a 7818, then regulate that with a 7809. they are really cheap. oh but yeah, -9 and +9 in series is obviously 18 from -9, just like batteries Very Happy
j.frad
PostPosted: Sun May 28, 2006 11:50 am    Post subject:   Reply with quote  Mark this post and the followings unread
glad I wasn't wrong! sometimes I just wonder...
your idea does sound better though!
MickMad
PostPosted: Fri Sep 01, 2006 6:03 am    Post subject:  Lorenzo!!! Reply with quote  Mark this post and the followings unread
Lorenzo!
Proprio a te cercavo!!!
Ho visto sul sito del wp20 che c'era un lorenzo che ne aveva fatto uno, ma non pensavo fossi un italiano!!
Visto che sono italiano, parlerò italiano con te:
prima di tutto, complimenti! Hai fatto un ottimo lavoro, e mi hai "copiato" pure un idea (infatti io non sapendo come mettere un gate in al wp20, prima di iniziare a costruirlo ho visto se era possibile metterci anche un theremin OTTICO come terza forma d'onda)...
ora i fatti:
chiedo a te che "sai la mia lingua" se va bene quello che voglio fare io: voglio mettere uno switch spdt affianco a quello della selezione forma d'onda collegando il polo del pulsante da attaccare al punto R al polo centrale del secondo pulsante...infine collegare il punto R a uno dei due poli laterali e attaccare il collegamento da saldare sull HOT del jack di output del theremin (vedi questo sito: http://www.oldtemecula.com/theremin/rs-opticaltheremin/rs-opticaltheremin.htm
) all'altro polo del pulsante, mentre la terra dell output del theremin la collego al polo centrale dello switch di accensione del synth (quello dove si attaccano anche i fili delle batterie)... poi volevo chiederti: come hai fatto a mettere il gate in?? perchè vorrei creare un audio to gate converter (http://www.musicfromouterspace.com/analogsynth/signaltogate.html)...solo che non so sia come fare il gate in, sia non capisco molto lo schema del converter...se mi potresti dare una mano...te ne sarei grato..
seraph
Editor
Editor
Audio files: 31
PostPosted: Fri Sep 01, 2006 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
ragazzi
se volete parlare in italiano va benissimo ma forse converrebbe passare ai PM (private messages) visto che questo e' un forum in inglese. che ne dite? buon lavoro a tutti e due Very Happy
MickMad
PostPosted: Fri Sep 01, 2006 7:45 am    Post subject: ... Reply with quote  Mark this post and the followings unread
che posso dire...
SORRY! Laughing
