Basic LFO
Page 1 of 1 [3 Posts]
Thomas_Henry
PostPosted: Sat Jan 17, 2015 10:52 pm    Post subject: Basic LFO Reply with quote  Mark this post and the followings unread
Hi Everyone,
Just for the hell of it, I decided to return to the basic Schmitt trigger-integrator, just to see how much I could wring out of it without the usual stupid range-switching. I maxed out at a 286:1 sweep range, which isn't bad at all for such a simple design. This really is a reliable old warhorse. I've attached my results for the benefit of newcomers who may not have played with it before.
Outputs are triangle and square, +/-5V in amplitude, running from 0.07Hz to 20.3Hz. On the low end, that's one cycle every 14 seconds. The output impedance of the square is about 1k; to make the triangle have the same impedance, just slap in a 1k series resistor.
You can find a very complete and understandable design analysis in Bernie Hutchens' Electronotes, of course. (What can't you find there?) What I've attached is a schem from the tinkering I did with the CircuitMaker 2000 SPICE software, and then included the actual results which match those predicted very closely. I'm willing to post the CircuitMaker design file if anyone else wants to play with it. Just shout.
This may not be the sexiest circuit around, but it sure is steadfast...and simple, when a manual triangle and square LFO is all you need. I think it's the best of its class.
Thomas Henry
LFO.pdf
LFO schematic
 Filename:  LFO.pdf
 Filesize:  11.35 KB
 Downloaded:  967 Time(s)
PostPosted: Sun Jan 18, 2015 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
286:1 (sic!) Very Happy
Thomas_Henry
PostPosted: Mon Jan 19, 2015 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, when rounded it's 20.3 / 0.07 = 290.
But that would be bragging.
TH
