karczilla
Bogus Noise
Posted: Thu Jan 08, 2015 7:19 pm Post subject:
There's minor variations, but they're all roughly similar to that.
You can also draw a new trace using conductive paint or a conductive pen.
Also Isopropyl Alcohol is great stuff for dissolving the kind of glue they used to stick the keyboard down. _________________ Circuit Bent Sonic Absurdity:
www.bogus-noise.co.uk
http://www.youtube.com/user/BogusNoise |
karczilla
Posted: Thu Jan 08, 2015 7:23 pm Post subject:
there in indeed minor variations. the replacement for parts one i bought had a slightly different keyboard matrix that did NOT go down in that region.
more importantly, the ribbon connection to the PCB was different. the traces would not line up in the same places as the old one. guess i have to buy another :/
the replacement speak and read keyboard's blue background color was very dark navy blue FWIW.
the one picture above was a lighter blue and the top has a bit of texture, for lack of better works. |
Bogus Noise
Posted: Fri Jan 09, 2015 1:23 am Post subject:
That's odd - I've always seen them with the same connection! Can you post photos of the two side by side?
I found it really difficult to plug the new keyboard in, until I discovered my Tesco Clubcard keyboard is the right width to plug into the slot while being thin enough to not stretch it out too much, and now I use that to push the keyboard ribbon in _________________ Circuit Bent Sonic Absurdity:
karczilla
Posted: Fri Jan 09, 2015 5:59 pm Post subject:
here ya go. hope it helps someone one day.
note- the dark blue one (with green matrix plastic) has these odd hex-like screws, whereas the clear matrix plastic speak and read has normal phillips screws.
Description: |
the original keyboard pad of the halfway bent speak and read. this speak and read had normal phillips screws in the back.
drilled through the bottom of the pad to add banana jacks and ended up with a half working keyboard. drilled through unknown keyboa |
Filesize: |
2.84 MB |
Viewed: |
352 Time(s) |
Description: |
Filesize: |
1.6 MB |
Viewed: |
362 Time(s) |
Description: |
drilled through the bottom of the pad to add banana jacks and ended up with a half working keyboard. drilled through unknown keyboar |
Filesize: |
2.26 MB |
Viewed: |
334 Time(s) |
Description: |
replacement, for parts, speak and read keyboard.
this keyboard was a darker blue color (see side by side comparison photo below). and was very....flat....for lack of better words. also didn't have much of a texture. this speak and read has odd hex like s |
Filesize: |
2.04 MB |
Viewed: |
335 Time(s) |
Description: |
Filesize: |
2.21 MB |
Viewed: |
342 Time(s) |
karczilla
karczilla
Posted: Tue Feb 10, 2015 5:48 pm Post subject:
indeed this worked buying the 2nd cheap, for parts, replacement i found on ebay. looking out for color, texture, and font and nailed the model i required.
my baby's alive again! |
