 Forum index » Instruments and Equipment » Percussa Audio Cubes
AudioCubes Firmware update and MIDIBridge 3.0 now available
Post new topic   Reply to topic Moderators: bschiett
Page 1 of 1 [2 Posts]
bschiett
PostPosted: Mon Mar 16, 2015 3:16 am    Post subject: AudioCubes Firmware update and MIDIBridge 3.0 now available Reply with quote  Mark this post and the followings unread
Last month, I've released a firmware update for the wireless AudioCubes as well as a new MIDIBridge verion: MIDIBridge 3.0
One of the new features we've built-in to MIDIBridge is topology mode. Toplogy mode is a very powerful mode that allows you to send MIDI note trigger information as well as distance data (MIDI CCs) at the same time for up to 16 cubes simultaneously! Imagine having a star network with 1 master cube and 15 wireless AudioCubes, each cube giving you trigger information as well as distance per cube face...
Salamanderanagram well known for his work with Reaktor made cool videos about topology mode and Reaktor.
You can check out the videos below.
Part 1
http://www.percussa.com/2015/03/05/percussa-audiocubes-topology-mode-part-1
Part 2
http://www.percussa.com/2015/03/14/salamanderanagram-audiocubes-topology-and-reaktor-part2
Also, check out the new updated MIDIBridge manual:
http://www.percussa.com/manuals/midibridge-manual
Any feedback or questions are highly appreciated!
percussa mSSP - digital modular in a eurorack module - 8 in/4 out @ 48/96/192khz DC coupled - 25+ DSP modules https://www.kickstarter.com/projects/percussa/percussa-micro-super-signal-processor-eurorack-mod
bschiett
PostPosted: Mon Apr 13, 2015 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Salamanderanagram made some more videos about topology mode. In a series of 2 videos, he explains how you can set up an effect matrix in Reaktor, in which he can change the routings as well as effect intensity simultaneously, using a few AudioCubes. When an cube detects another cube, a connection is made, and when you move the cubes closer together the modulation depth changes.
You can checkout part 1 of the video below
https://www.percussa.com/2015/04/08/salamanderanagram-reaktor-effect-patching-and-modulation-using-audiocubes-topology-part1
