Posted: Wed Jun 10, 2015 11:30 pm Post subject:
FS: US/Chicago TTSH ARP 2600 clone,SOLD |
FS: TTSH "Two Thousand Six Hundred" ARP 2600 clone. SOLD
The TTSH is a 78% scale clone of the ARP 2600, sold as a DIY kit with panel, PCB, and case. I built this one and had intended it to be mine, but other circumstances have led me to the decision to sell it.
I live in the Chicago area, near west suburbs along I-290. Shipping would add $150 - $200 to the cost to be sure it's packed and insured adequately--and that's just for the continental US--so local pickupis strongly preferred.
This revision 1 unit includes the following options:
Matching steel case from the kit seller
Extended Lag time mod
Large reverb tank
Reworked Reverb return circuit for lower noise
optional AC coupling for inputs to VCF
MIDI Implant version 3.8 (MIDI input on the left side)
Add-on Gate Booster
Add-on Oscillator Sync (O1 & O2 sync O3 separately or together)
Add-on VCO power regulator (to eliminate cross-vco bleed)
Add-on LED-balance boards (so that LED intensity adjustment works as expected)
1/4" Jacks for main outputs (on the right side)
Uses "stock" DC-DC converter power supply rather than a linear supply, wall wart included
Also included are two 4 way passive multiples, as I have used the front panel mult as inputs/outputs for the gate booster.
Sound demo of some of the features at:
https://soundcloud.com/elmegil/ttsh-demos
There is some slight scratching/scuffing on the case & panel; this has been opened and closed a lot, which has led to some minor scratching (see photos).
Description: |
Filesize: |
1.96 MB |
Viewed: |
250 Time(s) |
Description: |
Filesize: |
1.18 MB |
Viewed: |
197 Time(s) |
Description: |
Filesize: |
736.61 KB |
Viewed: |
213 Time(s) |
Description: |
Filesize: |
496.07 KB |
Viewed: |
193 Time(s) |
Description: |
Filesize: |
1 MB |
Viewed: |
185 Time(s) |
Posted: Wed Jun 10, 2015 11:31 pm Post subject:
The back and one of the mults
Description: |
Filesize: |
192.68 KB |
Viewed: |
191 Time(s) |
Description: |
Filesize: |
988.45 KB |
Viewed: |
192 Time(s) |
Posted: Fri Jun 12, 2015 5:27 pm Post subject:
bump |
Posted: Tue Jun 16, 2015 6:44 am Post subject:
Posted: Tue Jun 16, 2015 8:45 pm Post subject:
bump for price drop |
